Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Sports Talk
Reply
Thread Tools Display Modes
Old 20th of January 2012 (Fri)   #1
Rudy2112
Default Aperture question
What is the lowest aperture while still keeping the whole body in focus, from head to toe.
Rudy2112 is offline   Reply With Quote
Old 20th of January 2012 (Fri)   #2
dwarrenr
dwarrenr's Avatar
Default Re: Aperture question
Too many variables to give you a short answer. What you are trying to do is create a large enough depth of field so that the whole body is inside of the DOF. Your DOF is determined by the the distance the subject is from your camera, the lens focal length, your sensor size and the f-stop. So as you can see there are a lot of variables to get to your answer.
The size of your DOF will then depend on the sport you are shooting, and what the player is doing when you take your shot. If it is basketball and the player is just standing you can get buy with a DOF of 12". If he is running full speed that may double the required DOF you need.
Does that help? Yeah probably not.
D. Warren Robison
"All guys feel the need to compensate. Most compensate with sports cars. I compensate with a 400mm 2.8"
Flickr - Home Page - MaxPreps Gallery - Razzi
Equipment List
dwarrenr is offline   Reply With Quote
Old 20th of January 2012 (Fri)   #3
elrey2375
elrey2375's Avatar
Aperture and focal distance are the two biggest determining factors in depth of field. A larger F-stop (smaller number) and close distance will produce a shallow depth of field, meaning the focal plane or what is in focus will be very minimal. The farther you are from the subject, regardless of F-stop, the plane will expand and your depth of field will not be as shallow. Focal length doesn't have hardly any effect on DOF. If the subject takes up the same amount of space in a photo, the DOF is basically constant in regards to focal length.
elrey2375 is offline   Reply With Quote
Old 21st of January 2012 (Sat)   #4
JeffreyG
JeffreyG's Avatar
If you are framing an adult from head to foot (with a little space on each end) with the camera in vertical orientation then f/2 to f/2.8 will do it for most common print sizes.
My rule of thumb for maximum aperture for medium (up to 16x20) prints:
Tight headshots - f/11
Head and shoulders - f/8
Waist up vertical - f/4 to f/5.6
3/4 person - f/4
Full body vertical orientation - f/2 to f/2.8
Full body horizontal orientation - f/1.2 to f/2
My personal stuff:http://www.flickr.com/photos/jngirbach/
Commercial sports:http://girbach.zenfolio.com/
I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550
JeffreyG is offline   Reply With Quote
Old 21st of January 2012 (Sat)   #5
hegi
What are you shooting?
7D · 50D · SIGMA 30MM f/1.4, CANON 85MM f/1.8, CANON 17-55MM f/2.8, CANON 70-200mm f/2.8 IS · SPEEDLIGHTS, ELINCHROM SKYPORTS AND OTHER LIGHTING STUFF · MANFROTTO 055XPROB, 488RC2 · LOWEPRO Classified Sling 180 AW · FLICKR · WEBSITE
hegi is offline   Reply With Quote
Old 22nd of January 2012 (Sun)   #6
kenjancef
kenjancef's Avatar
3/4 person - f/4
Nice info, thanks!! I always get worried shooting basketball at f/2 that I only get one part of the player's body in focus. Most of the time I do ok.
kenjancef is online now   Reply With Quote
Old 27th of January 2012 (Fri)   #7
Joe300
Joe300's Avatar
yeah, I know what you mean. If you shoot center AF point you might not get face in focus, if you move AF point up above center one tow clicks you might miss more shots hoping to get face in focus..
If you move the AF point down below center to get more of the player full body in focus, its a hit or miss there..
There is no way I can shoot F4 in my gym...
Happy TGIF,
Joe
Joe300 is offline   Reply With Quote
Old 30th of January 2012 (Mon)   #8
AntonLargiader
Originally Posted by elrey2375 View Post
...Focal length doesn't have hardly any effect on DOF. If the subject takes up the same amount of space in a photo, the DOF is basically constant in regards to focal length.
If a subject takes up the same amount of space in a photo, the FL is the same.
T2i . 18-55 IS . 70-300 IS USM . 70-200 2.8L IS . 28mm 1.8 . 100 Macro . 430EX II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
AntonLargiader is offline   Reply With Quote
Old 30th of January 2012 (Mon)   #9
arich
arich's Avatar
f/400
Check out my blog!
arich is offline   Reply With Quote
Old 2nd of February 2012 (Thu)   #10
rockdog63
rockdog63's Avatar
Both I used the back focus button, center focus point, and Auto Servo
Model: Canon EOS REBEL T3i
ISO: 3200
Exposure: 1/640 sec
Aperture: 2.2
Focal Length: 50mm
Flash Used: No
Model: Canon EOS 60D
ISO: 1600
Exposure: 1/640 sec
Aperture: 2.0
Focal Length: 85mm
Flash Used: No
here it is cropped
60D |T3i with Zeikos Grip|18-55mm 3.5-5.6|55-250mm 4-5.6|85mm 1.8 USM|50mm 1.8 II| 600EX-RT SPEEDLITE |Quantaray 500mm lens f/8+2X converter |Σ 70-200mm F2.8 II APO DG MACRO |Previously owned: T2i,Zeikos Grip for 60D
Flickr~Facebook Football~Facebook Non Football
rockdog63 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Aperture question wacjac Macro 3 9th of May 2008 (Fri) 06:04
Sort EXIF in Aperture 2 - Aperture guru question... rrrize RAW, Post Processing and Printing 1 29th of April 2008 (Tue) 13:01
Aperture question sgogula Canon EOS Digital Cameras 15 2nd of February 2008 (Sat) 09:22
Aperture question 90blackcrx General Photography Talk 2 6th of October 2006 (Fri) 20:14
Another aperture question 90blackcrx Canon EOS Digital Cameras 3 28th of September 2006 (Thu) 21:48
