Thread started 01 Nov 2001 (Thursday) 08:47
How can I bend this picture?
GenDEM
Joined Sep 2001
Nov 01, 2001 08:47 |  #1
You can see the problem here...I took these three pictures to make a panorama...however, the camera was not level. When I ttok these shots about 4 months ago I just decided that I'd re-take the shots properly...for obvious reasons that's no longer possible.
So, after much work, i have the pictures aligned OK, but the panorama is massively curved. For the life of me I can't figure out how to fix this in shop, or any other tool. Can someone point me along a (hopefully) simple right path?
Here is the pic:
Thanks for the tips!
TulsaRod
Joined May 2001
Nov 03, 2001 05:57 |  #2
Try the "spherize" option under "filter", "distort" in photoshop.
Don ­ Ellis
Joined Sep 2001
Nov 03, 2001 06:42 |  #3
I've never tried this before, so this is a suggestion from left field. I spent ten minutes to get this image...
I selected the left half of the image with the Marquee Tool, hit Ctrl-T for transform and chose Skew. Pulled the top and bottom left sides down to make the horizon level.
Hit Ctrl-Shft-I to invert the selection (which selects the right half of the image), and did the same thing.
This left me with the center of the image going up slightly in a V. Chose Image, Liquify and used a large brush in the center, half in and half out of the water, and gently pulled it down. You can then use smaller brushes to pull other things in line.
I hope someone who really knows how to do this responds to you. I'll be interested in learning a better way.
DWerner
Joined Sep 2001
Nov 03, 2001 18:18 |  #4
The best software that I know for this is a photoshop plugin called panorama tools.
http://www.fh-furtwangen.de/~dersch/ (external link)
It is free, but somewhat complex...
I use it for barrel distortion correction, bending, warping, and yes... panoramas too.
If you have the energy and fortitude, give it a try.
Good Luck!
6,094 views & 0 likes for this thread
Latest registered member is DouglasAZ
704 guests, 362 members online
