Thread started 05 Feb 2012 (Sunday) 23:09
Prev/next
Need to upgrade computer! (kind of newb)
k.CHU
City of Angels
Feb 05, 2012 23:09 |  #1
Ok, so i desperately need to upgrade my computer.. i cant handle the lag im getting from lightroom/photoshop... things im looking at right now is
i7 2600
gskill 16gb ram
and a new mobo..
I would love to upgrade these parts only and avoid buying other stuff... i want to use the other old parts i currently have like the videocard/sound/etc.. my case is big enough as well. I need to upgrade these parts only because my current mobo only supports up to 4gb of ram max... anyone can help me out here on what will/wont work?
Kevin Chu Photographyexternal link
Canon 5DII | 85 1.8 | 50 1.8 | B800(x3)
Flickrexternal link (Jan 2011) | Facebookexternal link
Cygnusx1
Putnam County, NY
Feb 05, 2012 23:30 |  #2
You want DDR3 RAM capability. Almost all motherboards come with on board surround sound now, so no card needed for that.
What video card are you planning to re-use. If it's not a PCI-express interface, it's not worth keeping.
I like ASUS for their BIOS and this one has a lot of capability:
http://www.newegg.com ...aspx?Item=N82E16813​131786external link
-If you can get 2 x 8GB sticks or RAM instead of 4 x 4GB each, then you can add two more 8GB sticks later (DDR3 1600 is the latest stuff). You buy in pairs to take advantage of dual channel architecture.
-You will need a 64bit operating system (Win7 -64bit) to take full advantage of the RAM.
-Don't forget that most older drives are not SATA interface. Make sure you have, or get a SATA 6Gb/s hard drive.
- You will also need at least 750watt power supply.
If you want me to build you a parts list, let me know, along with your budget, and parts you already plan to keep. ;)
Canon 20D(sold), EOS 7D, Bower 8mm, Canon f/2.5 Macro, Sigma 18-50mm f/2.8, Sigma 80-400mm EX/DG/OS.
http://www.cafepress.c​om/singlelensreflexexternal link
http://dcer.smugmug.co​m/external link
k.CHU
City of Angels
Feb 06, 2012 03:53 |  #3
Sweet, thank you Cygnusx1. I think you've answered my question.. just need to research myself a bit more. Ill get back to you with my part list and what not to confirm! Thx!!
tim
Light Bringer
tim's Avatar
Wellington, New Zealand
Feb 06, 2012 04:30 |  #4
Imho 4x4gb it's fine, 32GB not necessary within next few years. 400 power supply is fine if it's a good brand.
Cygnusx1
Putnam County, NY
Feb 06, 2012 07:22 |  #5
4x4G is fine, but for a few extra dollars, you can leave two slots open for optional upgrades later. Careful with your power supply, 400 vs 800 cost is not a big difference these days. Check the wattage requirements of the CPU. If you ever want to put in a good video card, you will need the power. Most decent cards today easily support multi monitor too.
tim
Light Bringer
tim's Avatar
Feb 06, 2012 14:17 |  #6
My i7 2700K, 3 hard drives, 2 SSDs, nVidia 520 uses 120W under full load. I suspect I had my monitor running off the same power connection when I tested it, and maybe a compact fluroescent light bulb too.
Peak draw is probably higher, and playing games might be higher again, but PCs use much less power than most people think. Still a good quality power supply is a good investment, but you don't need a monster power supply.
k.CHU
City of Angels
Feb 06, 2012 22:17 |  #7
My current computer specs -
CPU/Processor - Intel Core 2 Duo @ 3GHz
RAM - 4GB
Graphics - NVIDIA GeForce 9600 GT
Motherboard - Gigabyte GA-G31M-ES2L
HD - WD Caviar Black
Power supply - 680W
Computer i want to upgrade to -
CPU/Processor - Intel i7 2600 http://www.newegg.com ...aspx?Item=N82E16819​115071external link
RAM - G.skill 16GB http://www.newegg.com ...aspx?Item=N82E16820​231429external link
Graphics - NVIDIA GeForce 9600 GT (Would like to keep this to save money if possible)
Motherboard - ???????????????? (Need help here.. completely lost on what to look for)
HD - WD Caviar Black (Would like to keep this as well, but will install SSD's/more drives in future)
Power supply - 680W (keeping this i assume.. seems to be enough power?)
What motherboard should i look for????
k.CHU
City of Angels
Feb 06, 2012 22:19 |  #8
My budget for the motherboard is maybe 100-200$??? Lower the better if possible? (but at the same time, i dont know what to look for / what i need).
tim
Light Bringer
tim's Avatar
Feb 06, 2012 22:32 |  #9
Check the power supply connectors, they sometimes change between generations of motherboards - I have no idea. Any good brand motherboard is fine, Asus and Gigabyte are both good. Existing WD black drive is fine. 9600GT should be fine.
If you get a Z68 (I think that name's right) motherboard it has built in video. Not sure how good it is, or if it shares video ram, which I consider a bad thing.
k.CHU
City of Angels
Feb 06, 2012 22:47 |  #10
is ASROCK a good brand? seems to have alot of reviews. or shall i stick with gigabyte/asus which i know are good brands?
http://www.newegg.com ...1&Description=Z68&x​=0&y=0external link
tim
Light Bringer
tim's Avatar
Feb 06, 2012 23:58 |  #11
I think ASrock are reputable, someone here recommends them. Check out the newegg reviews.
k.CHU
City of Angels
Feb 07, 2012 01:46 |  #12
cool, thanks. if anyone else wants to share their opinions feel free! ill be purchasing near the end of the week :P
1,358 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00297 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is gkefalas
839 guests, 448 members online
