Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 18th of February 2012 (Sat)   #1
hkim1389
Default anyone use metz flash 58af as master and 48af as slave?
I have 5D and Metz 48af now.
I guess I need to add 1 more flash to use in big church.
My questions is that can I set 58af as master in camera hot shoe and
add 48af as slave in flash bracket?
If I set 58af e-ttl, second flash, 48af, work as e-ttl as well? or should I use it
as M mode? any sync or adapter need to use two flashes e-ttl mode?
thanks.
Canon 5D + 50.8
hkim1389 is offline   Reply With Quote
Old 18th of February 2012 (Sat)   #2
PacAce
Moderator
PacAce's Avatar
Default Re: anyone use metz flash 58af as master and 48af as slave?
The Metz 58 AF-1 (and 58 AF-2) supports the Canon wireless system and can serve as a master or a slave for that a system. The Metz 48 AF-1 also supports the Canon wireless system but can only serve as a slave. So, to answer your question, yes, you can get the 58 AF-1 and use it as a master for your 48 AF-1. You can set the flashes in either E-TTL mode or in manual mode. There are no additional adapters that are required to work the flashes in wireless mode other than for mounting the remote flash on to a stand.
...Leo
PacAce is offline   Reply With Quote
Old 18th of February 2012 (Sat)   #3
hkim1389
Great! thanks for the info.
Canon 5D + 50.8
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
580 EX II as master, Metz 58 as Slave issue Jimconnerphoto Small Flash and Studio Lighting 2 12th of October 2010 (Tue) 22:42
Flash Extender per Metz 48AF-1 Marknot Small Flash and Studio Lighting 2 9th of October 2010 (Sat) 07:20
Metz users help. *master / slave* Jonny Small Flash and Studio Lighting 8 26th of May 2008 (Mon) 10:45
