Thread started 18 Feb 2012 (Saturday) 18:32
"Recording Stopped Automatically" - help?
brighambartol
Joined Feb 2012
Feb 18, 2012 18:32 |  #1
First off, I'm a bit of a camera noob, but I'm a musician and I saved up for a camera that I could shoot HD videos of my music with (plus I wanted to take up photography as well), so I picked up a Canon Rebel T3i.
The problem is, half the time when I record video the camera stops about a minute in and says "recording stopped automatically". I've seen a couple threads of people with this same problem, but no very helpful responses. I have a class 10 memory card that I bought from Henry's, so I'm pretty sure the card isn't the issue.
So far as I can tell after searching, this has something to do with overheating. Is there any way to solve/combat this issue? I feel kind of ripped of having bought and expensive (by my standards) piece of equipment that I can't use half the time....
lannes
Feb 18, 2012 18:43 |  #2
Usually with recording problems it is the card speed, what brand is your card, some don't perform to their stated class.
Something like a genuine Sandisk extreme pro SDHC card, would guarrantee you have the card performance.
Also try reformatting the card in the camera.
what settings are using for video ?
brighambartol
Joined Feb 2012
Feb 18, 2012 18:45 |  #3
lannes wrote in post #13921682 (external link)
It's a "Lexar Professional" 16GB, class 10
lannes
Feb 18, 2012 19:12 |  #4
I'm assuming you have enough spare space on the card for the video file, it will be using about 330mb per minute.
I'd try another card to discount a card problem, Lexar and Sandisk have been the target of fakes.
At 1080p trying using a lower frame rate like 24fps, or even try 720p
Does the red temperature icon appear on the LCD before the movie stops, this indicates heat is a problem ?
pkilla
Joined Jan 2012
Feb 18, 2012 20:31 |  #5
Its the card I had the same problem get a Sandisk extreme pro SDHC
And u should be good with over heating and your
Recording stopping
T3i griped - rokinon 8mm/rokinon 35 1.4/rokinon 85mm 1.4/
sigma 17-50/nikon 50mm 1.2 ai-s/nikon 28mm ai-s 2.8/
helios 40-2/helios 44-2/mir 1b 37mm 2.8/supertak 135/
trioplan/http://www.flickr.com/​photos/pkilla617/ (external link)
CHECK OUT MY BLOG PICS http://pkilla61.blogsp​ot.com/ (external link)
brighambartol
Joined Feb 2012
Feb 18, 2012 23:47 |  #6
lannes wrote in post #13921792 (external link)
I haven't seen the temperature icon on the screen. Although if I let the camera rest for a while before shooting it seems to start working again, which suggests to me that it is a temperature problem and that it just needs to cool down.... maybe I'm just not noticing the icon. I'll fool around with it tomorrow and try to notice
brighambartol
Joined Feb 2012
Feb 18, 2012 23:49 |  #7
pkilla wrote in post #13922080 (external link)
Recording stopping
I may try that out. Thanks.
kawi_200
Joined Jul 2011
Feb 19, 2012 00:03 |  #8
Cameras are limited to record only 29min 59sec of video before auto stopping. This has to do with a tax that goes on cameras recording 30min or longer. Are you recording for 30min or more? Or is it stopping less than 30min?
5D4 or 6D2..... Waiting to find out which I buy | 8-15L |24-70mm f/4L IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
John ­ from ­ PA
Joined May 2003
Feb 19, 2012 09:34 |  #9
OP stated "The problem is, half the time when I record video the camera stops about a minute in and says "recording stopped automatically"." This should not be an overheating issue.
As others have pointed out, it is likely the card. Also, be aware there are some limitations on how much you can record, even with the best of memory cards. More than 12 minutes can be recorded but there are some limitations. When the file size reaches 4 GB, recording will automatically stop. That means that at 1920x1080 dpi and 1280x720 dpi the maximum recording time of a single movie clip is about 12 minutes. At 640x480 dpi it is about 24 minutes. I think there is also an auto-restart function in the 60D so it will start again and you loose only a few seconds of video.
The capacity of the card differs in recorded time; at 1920x1080 dpi or 1280x720 dpi you can stuff 44 minutes total of video onto a 16 gig card. At 640x480 dpi or crop 640x480 dpi this goes up to 1 hour 32 minutes. However, the 60D English manual movie section states "The maximum recording time of one movie clip is 29 min. 59 sec. Depending on the subject and the increase in the camera's internal temperature, the movie shooting might stop sooner than 29 min. 59 sec.' [60D manual, page 181]
This is not just the Canon line, Pentax for instance states "Like competing DSLRs, the Pentax K-5 also monitors sensor temperature during recording, and will halt capture if the temperature rises beyond a certain threshold." A reputable source also states "This limitation is due to the different (European) import duty rates for still and video cameras." There is no reference made to differing duty rates of product entering the United States however. So there may really be two limitations, one the 29 min 59 seconds limitation imposed legally, and a sensor temperature issue that might also be reached in some rare circumstance.
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Feb 19, 2012 10:28 as a reply to  @ John from PA's post |  #10
Not all Class 10 cards are equal. A C10 card must maintain a minimum write speed of 10 MB/s which is too slow for 1080p recording. Under the C10 umbrella speeds can go from 10 MB/s on the cheap side up to 90 MB/s on the high end. I'm guessing the Lexar card you have is a C10 133x or 20 MB/s, barely enough and only if the card can actually meet it's claims(rarely do they). For video I would spend a little more and get an SD Card up to the task. A SanDisk Extreme 45MB/s will fit your needs quite well.
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
RTPVid
Feb 19, 2012 10:44 |  #11
-dave-m- wrote in post #13924143 (external link)
...a minimum write speed of 10 MB/s which is too slow for 1080p recording. ...20 MB/s, barely enough....
Wrong, wrong, all wrong.
Contrary to the apparent consensus belief on this board, HD video recording is not very demanding of card performance at all. Check your manual, or just do the math.
The 60D, at the highest definition video setting, only requires 5.5MB/s, and, as the manual states, a Class 6 card will suffice.
Now, does the card itself actually perform up to its class designation? That's another question, but there is no need to overpay for the high-zoot SD cards merely to record video. You only need one that performs as labeled.
To the OP: It certainly sounds like your card is not performing properly. Stopping after a few seconds indicates a card that is too slow. A few minutes? That means it did record longer than it takes to merely fill the buffer, so there may be something else going on. The fact that it records sometimes and not other times means it may be something else as well ... perhaps a loose connection, or the card does not seat properly?
Tom
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Feb 19, 2012 11:22 |  #12
RTPVid wrote in post #13924212 (external link)
I am talking real world performance and what the cards have printed on them. I have yet to use a card listed at 10 MB/s or 20 MB/s that will reliably keep up with 1080p recording. In theory they should, I guess if I wanted to make a theoritcal movie they would be OK. In the real world, they haven't worked in my experience, but I haven't had a problem with a SanDisk Extreme 45 MB/s.
My experience was with a 60D I had rented(prior to buying a 5D MkII), I tried all my SD cards, ranging from a Class 6(in theory fast enough) to a Lexar Professional Class 10 133x 32G(20MB/s). Each one of them failed to keep up, recording shut down automatically when the buffer was full.
I went back to the camera store to have them check the camera, camera worked fine. The manager suggested I try the SanDisk Extreme 45 MB/s card and said she would give me a refund on the card and rental if it didn't work out. Camera recorded 1080p without a problem.
Bottom line is most cards do not have the performance they say they do and theoritical speeds are meaningless in the real world.
aquaforester
Joined Nov 2011
Feb 19, 2012 11:32 |  #13
Agree. I had same issue with a PNY 16g class 10 card 20mb. I swamped out a old 1g card class 4 and it recorded fine.
Current Gear
Canon 60D, 10-18, 24 Pancake, 60 macro, 70-200 F4
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Feb 19, 2012 11:48 |  #14
aquaforester wrote in post #13924420 (external link)
I should have worded my original post a little different, but we are basically saying the same thing. Not all cards are equal and not all cards perform as they are listed. Nor will they perform the same in all bodies. Buying a quality card that performs at it's listed speed is more important than buying a cheap "fast" card.
RTPVid
Feb 19, 2012 14:55 |  #15
-dave-m- wrote in post #13924376 (external link)
I am talking real world performance and what the cards have printed on them. ....
And I was talking about specifically what I quoted., namely your statements that
These statements are false, wrong, incorrect, balderdash, etc.
As I also said, the issue of whether a card performs as marked is a separate issue, but the 60D does NOT produce a video bit stream any faster than 5.5MB/s.
Tom
38,407 views & 0 likes for this thread
version 2.0 /
Latest registered member is insurfr
751 guests, 385 members online
