Reply
Thread Tools Display Modes
Old 21st of February 2012 (Tue)   #1
cameraperson
cameraperson's Avatar
Question Have any of you used the Metz Mecablitx 28 CS-2 Slave Flash??
I just found this today. I've been looking for something to use with my superzoom, and I think I'm going to get it, but I was wondering if anyone had any experience with it. I wish I could post it in the point and shoot discussion too.
http://www.bhphotovideo.com/c/produc...2_Digital.html
Thanks.
edit: I think maybe I should have posted there. The G series has a hotshoe doesn't it? I have a Sony HV-100X and don't have that (want a Canon dslr one day though.)
edit: maybe someone can move this to the flash discussion?
cameraperson is offline   Reply With Quote
Old 21st of February 2012 (Tue)   #2
denncald
Default Re: Have any of you used the Metz Mecablitx 28 CS-2 Slave Flash??
I have the 28 CS-2. I got it in Dec 2010, and had to send it in for repairs in Oct 2011. It was fully covered by their one year warranty, so it is back to working great. I like this flash for it's size, convenience and power. I use it with our A620, G9, and G11. It allows you to have a sort of bounce flash by holding in your hand and pointing at the ceiling. I generally reduce the output power of the on board flash to minimum, so the slave will do most of the lighting. I also have the Canon 430EX II external flash, but I don't always bring it with me. The 28 CS-2 is easy to carry with you for times you need some extra power, or a bounce result, or an extra off camera flash for various situations, limited only by your imagination. It's easy to adjust the power settings as needed.
Dennis
denncald is offline   Reply With Quote
Old 21st of February 2012 (Tue)   #3
cameraperson
Could it be put on a light stand or do you just hand hold it for most things?
edit: do you think it could be used to make nice portraits?
Old 22nd of February 2012 (Wed)   #4
denncald
The folding arm on the side allows you to attach it to the camera by it's tripod mount. The knurled nob that you turn to screw into the camera tripod mount also has a tripod mount thread in it. So, yes, you can use that to allow you to attach to screw thread on another tripod head.
I don't use it for portraits, but it's power can be adjusted up and down quite a bit.
Dennis
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
anyone use metz flash 58af as master and 48af as slave? hkim1389 Small Flash and Studio Lighting 2 18th of February 2012 (Sat) 14:42
Slave triggering for Metz 48? Matt-l Small Flash and Studio Lighting 1 26th of February 2009 (Thu) 11:43
Flash Slave and Metz flash! Ryan W Small Flash and Studio Lighting 16 6th of January 2009 (Tue) 11:03
Slave with Metz 58 and Canon 580 EX I JCIG Small Flash and Studio Lighting 4 17th of August 2007 (Fri) 11:37
Metz 28 CS-2 Digital Slave Flash ??? wilerty Small Flash and Studio Lighting 0 17th of May 2005 (Tue) 09:31
