#1 |
I finally got around to playing with my new Canon T3i and I've discovered that the stock lens it comes with (18-55mm) is very limiting. What is a good, inexpensive lens for a newbie that will give me more flexibility?
Thanks, Kelly |
| sponsored links |
#2 |
What is limiting about it? Knowing what you find limiting will help with recommendations.
Tom |
#3 |
What do you want to shoot? Do you need more reach? Better low light performance?
Camera Kit: 60D, S100, 17-55 f/2.8 IS USM, 18-135 IS, 50 f/1.4 USM, 55-250 IS, 2x 430 EX II, 70-300L IS USM Other Stuff: Luma Labs Cinch, Satechi RF Trigger, Stofen Omni-Bounce, Lowepro Fastpack 100 & 350 |
| sponsored links |
#4 |
Sorry, I should have provided you with more details.
Basically, I was out shooting an old statue with a crane on top of it. The statue was about 15 feet high and I was about 5 feet away from it. When I zoomed in to photograph the crane (bird) on the very top I thought I had taken a pretty good shot. However, when I got home and viewed the crane on my Mac it was very grainy. I should note that I was shooting on an overcast day with the automatic settings and highest jpg resolution. I attributed this to the lens, but perhaps it's something else. Nevertheless, I'm finding that I would like to have a little more reach. |
#5 |
Get the 55-250, it picks up right where your 18-55 leaves off and is very inexpensive.
I wonder though if you aren't instead seeing noise from the sensor, did you zoom in on your mac on the bird? On fully automatic the camera can sometimes choose settings that might not get you the very best shot.
#6 |
It could be. I'm still learning this thing. I even took a course on lynda.com, so at least I now know what the buttons do.
I am trying to use the Program and Manual modes, but because I'm new I really don't know how to a address each situation. So given the parameters above (overcast day, light rain, old statue) how would you have setup your camera? |
#7 | |
1) Getting the well reviewed Canon 55-250mm will help you with the reach portion. 2) What ISO did the automatic mode set the camera to? A high ISO will give you more grain. Try to learn how to use the Av, Tv, and M modes instead of the automatic modes. Gives you a little more control over the ISO. Do you do any post-editing of pictures? If so, shooting in RAW will give you a lot more flexibility in the picture quality, at the cost of using more storage.
Canon 60D | Sigma 30mm f1.4 | Canon 55-250mm f4-5.6 | Canon 85mm f1.8 | Canon 50mm f1.8 II Flash: YN465 | RF602 Triggers Other Stuff: Gorillapod SLR-Zoom w/ Manfrotto 484RC2 | Other tripods and ballheads |
#8 | |
http://www.amazon.com/Understanding-...9946041&sr=8-1
#9 | |
Yes, I usually post edit my images in Lightroom 3 or PS. |
#10 |
First of all you likely aren't at this stage going to create (in JPG) that absolutely stunning once in a lifetime shot! Set up your camera to save a high resolution RAW image and a reasonable size JPG. The RAW will give you the advantage of creating a zoomed JPG image and tweak the lighting paramaters as well. The JPG just doesn't give you much flexibility.
A analogy from film days would be the RAW is the negative and the JPG is the print. If you didn't like the print you took the negative bacck to the store for a reprint, hopefully correcting what you didn't like about the original. |
#11 |
Statue was 15 feet high, you were 5 feet away, and shot at ISO 100, 0 EV, f/8, 1/200. Probability is high that the camera exposed for the sky and the crane is dark and lacking detail. Is that correct? Can you attach a sample?
#12 |
Wow, very good advice guys. I appreciate everyone's help and timely responses. I am looking forward to learning about photography so I can capture some great images like I see people on this forum shooting.
Yes John, you are absolutely right. I'll try to attach the image. |
#13 |
15-85 IS
#14 |
Looking at the picture
1. Looks like the camera chose to focus on the base of the crane because it looks sharper than the crane itself. Choose a single point instead of letting the camera decides. Put that point on the intended subject. 2. It exposes too dark because the camera meters the sky. Go to manual mode or dial +1 exposure compensation to get a proper exposure 3. The lens is too wide, you'll need a longer lens, a 55-250mm will do nicely here 4. It may be a better composition if you use the portrait orientation instead of landscape Last edited by ahendarman : 22nd of February 2012 (Wed) at 16:17. |
#15 |
Great suggestions. Thank you. Where is the best place to buy lenses? Is there anything wrong with buying a used lens?
| Thread Tools | |
| Display Modes | |
| Just got the Nex-7, 3 lenses, and a Fotdiox lens adapter for Canon EF Lenses | jason324 | Photography Industry News | 85 | 8th of March 2012 (Thu) 04:50 |
| CANON 7D WITH L-GLASS LENSES TO PANASONIC LUMIX GH2 WITH NEW LENSES PRO's AND CON's | produce12 | Canon EOS Digital Cameras | 134 | 22nd of March 2011 (Tue) 05:14 |
| Are lenses interchangeable and will SLR lenses work on a Canon Powershot sx20is? | AprilArchambeau | Canon EOS Digital Cameras | 8 | 13th of April 2010 (Tue) 17:53 |
