FORUMS Photography Talk by Genre Macro Talk
Thread started 29 Feb 2012 (Wednesday) 18:13
Prev/next
Pixel density on APS-C sensors and diffraction
gatorlink
gatorlink's Avatar
Joined Mar 2011
Los Angeles, CA
Feb 29, 2012 18:13 |  #1
Consider the following hypothetical situation: I am shooting a shot of a fly's head with the MP-E 65mm at 4:1 magnification. The fly is dead, so it isn't going anywhere. I am in the studio with constant light, camera on a tripod, etc. I take one shot at f/11 and ISO 100 with the 450D. Then, I take another shot from the exact same position at f/11 and ISO 100 with the 550D. I upload both shots onto my computer and ensure that the settings for everything related to raw file rendering (especially sharpening!) are set exactly the same. I then downsize both files to be 1024 pixels on the long side using DPP. When I view the exported, 1024-pixel-wide photos at 100%, do I see a difference in sharpness?
The sensors in these two cameras have a different pixel density, but theoretically, the engineering quality of the sensors should be very close. The issue at hand is the diffraction limited aperture (see first table in this link for details about these and other current and recent DSLRs: http://www.the-digital-picture.com ...al-SLR-Camera-Review.aspxexternal link). In other words, particularly when shooting very high-magnification macro (i.e., greater than 1:1), is it actually better to have a camera with fewer pixels covering the same sensor size when it comes to photos that are printed small or re-sized? Obviously the answer will change if you start changing sensor size (i.e., let's leave the 5D out of this!), and it will also change if you view the two photos at 100% WITHOUT re-sizing them first. Let's set those issues aside. The key question is: is the extreme macro photographer who wishes only to show web-resolution photos actually doing him/herself a disservice by getting the highest density APS-C cameras out there, because he/she will need to shoot at a slightly narrower aperture to get the same pixel-level sharpness after re-sizing to 1024 pixels on the long side?
The answer to this question may come down to something I don't really understand: the algorithm used by most software to re-size photos. In a purely hypothetical example, imagine one camera literally had twice as many pixels covering the same exact sensor size. The DLA would be pretty low in the high-density camera when compared to the low-density camera, but images from both would have to be re-sized significantly to fit into a 1024-pixel width. When downsizing, do two slightly blurry pixels on a super-dense sensor equal the same re-sized quality as one sharp pixel on a less-dense sensor? I would guess that they do, but I feel like anecdotal examples I've seen suggest otherwise.
If this has already been answered, please feel free to point me in the right direction. A quick search did not turn up much. If you don't know the answer but still want to be helpful, and you own multiple APS-C cameras released within a couple years of each other, you could actually run this test and post some photos. Then you would be a hero, and who doesn't like that?? :)
Ryan
Flickrexternal link
Facebookexternal link
gmillerf
Joined Jan 2012
Feb 29, 2012 22:11 |  #2
If you're resizing from 5000+ pixels to 1024, the density probably isn't going to matter. You may be biasing your results by knowing what you're looking for, a more scientific test would be to have others say which one looks better, who don't know which is which.
You also need to be aware that even for the same quality of sensor, larger pixels are more sensitive to light, and will generally have less noise.
It's also not likely to be helpful to compare images that haven't been sharpened in any way. And applying sharpening can be very subjective, so it's really going to be difficult to compare results in a truly unbiased manner.
Greg -- http://www.flickr.com/​photos/79652823@N00/external link
gatorlink
gatorlink's Avatar
Joined Mar 2011
Los Angeles, CA
Mar 01, 2012 10:34 as a reply to gmillerf's post |  #3
Thanks for the input, gmillerf. I agree that any visual comparison from real cameras is likely to be flawed in at least a few ways. Ideally, what I would love is for someone to come along who has a good understanding of the physics of optics and exactly how DLA works, because I suspect he/she can simply give an academic example that negates the need for visual inspection of actual photos.
Ryan
Flickrexternal link
LordV
LordV's Avatar
Worthing UK
Mar 02, 2012 01:16 |  #4
Not sure if this thread on another forum will help
http://photomacrograph​y.net ...fraction+limited+ap​ertureexternal link
Macro Hints and tips
gmillerf
Joined Jan 2012
Mar 02, 2012 12:32 |  #5
gatorlink wrote in post #13997359external link
I doubt that. I know exactly enough about optics to shoot myself in the foot, but I know this problem is too complex to be solved in a general sense without limiting the discussion to an exact set of hardware.
There are actually different methods for calculating the diffraction limit, the most simple is the Airy disk. This method only applies to the ability of a telescope to determine if two stars of the same brightness, seen in a telescope, are in fact two stars as opposed to appearing to be one. It does not mean that the image of the two stars are perfect and non-overlapping. So any attempts to use this method for computing diffraction limitation is useless for evaluating image quality. And unless the calculator you're using asks for distances of optical elements, it's using the Airy method (or something similar).
Other methods for computing diffraction can be better, but are useless without very specific information about the entire optical system. One of the big details you need to know is the angle of a given pixel from the center of the field stop. So, diffraction doesn't affect all pixels equally, and which pixels are affected and by how much is determined by the size of the field stop opening and the distance it is from the sensor. Complicating matters is the fact that the field stops in lenses aren't circles, they are usually about 6 or so pieces of metal with straight edges, so you'd need an algorithm specifically designed for that case.
And even if you knew that information, it's only accounting for one factor causing diffraction. Each element of a lens will also cause diffraction, and the diffraction patterns of other optical elements will interact with each other. So, at a minimum, you'd need to know the exact size and spacing of every element in the optical system, just to get started. Then you can move on to what the actual glass elements of the system are made up of and how that affects diffraction (the manufacturer will never give you this information).
Now that you've got all that, you need to account for the fact that diffraction affects different wavelengths of light at different amounts. And then on to the fact that the sensor in your camera is really just a black & which sensor with a Bayer Array laid over top of it. So blue light will be more affected by the diffraction of a system, but most Bayer Arrays have green pixels closer together than blue ones, so you're likely to get diffraction on green objects before you see it on blue objects.
I actually had the rare opportunity to see the diffraction model of a 24" Celestron Ritchie Chretien telescope when I met a Celestron engineer installing one at the University of Louisville Moore Observatory. Even though all of the optical elements are round, I was surprised to see the diffraction pattern was actually more like an elongated figure 8. And, it took his computer a good 5 or so seconds just to render it, even though there's only about three optical elements.
So, needless to say, computing an actual diffraction limit is probably far beyond what can be done at an amateur level. You can put upper limits on it, but it's impossible to know which parts you can ignore without actually measuring and computing them. I think the short answer is, if you have to result to such elaborate calculations to determine if one image is better than another, then it probably doesn't matter. If you can't actually *see* a difference, who cares?
Just a final note. You can actually measure the diffraction of an optical system using a technique called flat fielding. The general idea to to take a photo of something that's perfectly evenly illuminated, and then measure the difference in pixel values across the sensor. Even though the concept is simple, actually doing it is pretty tough. Just getting something evenly illuminated is tough enough (a lot of people use the sky, and it's good enough). But then, there are a lot of other factors that will cause differentiation in pixel values like noise and dust. So it'll be hard to tell if you're actually seeing the diffraction pattern, or something else.
gatorlink
gatorlink's Avatar
Joined Mar 2011
Los Angeles, CA
Mar 02, 2012 20:27 as a reply to gmillerf's post |  #6
Thanks, Brian, for that helpful link, and thanks, gmillerf, for the detailed response. Both your posts help me clarify my rather muddy thinking on this issue and helped me realize the ways in which I was somewhat missing the forest for the trees. It occurred to me that there is a simpler way to think about things than had previously occurred to me. If you take a lens off a camera and set it to f/11, the image coming through the lens is the same no matter what camera you attach to the end of it. That is a constant. Of course, an APS-C camera will record less of the image than a 35mm frame, but we're only talking APS-C right now, so that fact doesn't matter. The DLA of a high-density APS-C sensor is lower than the DLA of a low-density sensor simply because the high-density sensor can pick up finer changes in resolution that occur as the lens is stopped down.
These facts may seem perfectly obvious to you guys, but they didn't seem perfectly obvious to me until now. Now that I am thinking about the issue in this manner, things are simpler. Basically, given that an identical image is hitting both a high-density and low-density sensor, the question is whether the two will recorded images will look noticeably different after being downsized to 1024 on the long side. gmillerf, as you mentioned, actually calculating some sort of "absolute" difference is very complex and really not worth doing. I also agree that what really matters is whether a difference is obvious to the eye. I suspect that in my example, the difference would not be obvious if it was even detectable at all. I think people generally agree that even a downsized image from a low-density sensor will have less noise than a downsized image from a high-density sensor, and this can make a noticeable difference at high ISOs, but I'm not concerned about that. I'm generally shooting at ISO 100 or 200 when shooting at greater than 1:1, so better performance at ISO 3200 is not of much interest to me.
Thanks again for your help, folks :)
Ryan
Flickrexternal link
2,246 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00252 for 4 database queries.
PAGE COMPLETED IN 0.01s
Latest registered member is mwas
847 guests, 357 members online
