Thread started 01 Mar 2012 (Thursday) 08:54
Canon 60D: Suggestion to improve focus hit with back AF button and focus priority
fe1ixs
Mar 01, 2012 08:54 |  #1
I'll be shooting my sister wedding next week. I would like to have last minute tips how to get the most out of my canon 60D and increase the keeper pics percentage rate.
I read about using AI-Servo instead of one shot for moving subject and it seems make sense to me. in order to do this, do I have to set the camera to use back button AF?
I also read it might be useful to set the shutter priority to focus instead of release priority. that way you can be sure the camera only take picture when the subject in focus.
btw, my lenses that I'm going to use is tamron 17-50 and sigma 30 f.1/4
thanks guys!
Owned : Sigma 30 f/1.4 - Canon EF 50 f/1.8 MKii - Tamron/Promaster 17-50 - Canon EF-S 55-250IS MK II - Metz 58AF-1 Flash - Case Logic DCB-309 Backpack - Canon S95
Previously Owned:Canon EOS 60D - Canon EF 28 f/1.8 - Sigma 10-22 - Tamron 28-75 - Canon EF 50 f/1.4 - Canon EF 50 f/1.8 MK I - Canon EF 80 f/1.8
John ­ from ­ PA
Joined May 2003
Mar 01, 2012 09:47 |  #2
Check out http://learn.usa.canon​.com …s/eos_60d_tutor​ials.shtml (external link). These are 60D specific tutorials that Canon has put together. There are 8 topics as I recall, one of which it titled back button focusing. Select that and then watch. I put all these tutorials on an old and slow 8 GB card so that I can watch them on-screen in the 60D.
fe1ixs
Mar 01, 2012 10:35 |  #3
John from PA wrote in post #13996966 (external link)
thanks John.
That is an excellent tutorial! I appreciated.
Keyan
Joined Mar 2011
Mar 01, 2012 10:58 |  #4
Where is the setting to change it to focus priority?
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
fe1ixs
Mar 01, 2012 11:44 |  #5
Keyan wrote in post #13997581 (external link)
these are for 7D but I guess applied the same for 60D:
One-shot AF - also called single auto focus and focus priority allow the photographer to press down the shutter half way and set the focus point at that time. Then you can move the framing, while holding down the shutter button and take the picture by pressing the shutter the rest of the way.
AI-Servo AF - also known as continuous auto focus is the mode to use for fast moving sports, animals or other objects. The camera refocuses as the subject moves to keep a moving object in focus. This mode is also called release priority because if the shutter is pressed down all the way the camera will take the picture whether it is in focus or not. This mode takes the most battery power.
AI-Focus AF - this is a combination of both one shot and AI-Servo where the camera locks in the setting like in One shot AF, but if the subject moves it will revert to AI-Servo mode.
Snydremark
my very own Lightrules moment
Gallery: 43 photos
Mar 01, 2012 11:52 |  #6
There is no option, in the 60D, for changing shutter priority, etc. That's a custom function on the 7D.
OP: No, you don't HAVE to set the camera to back button AF to use AI Servo; it does help, though. If you leave AF on the shutter button, with AI Servo set, the camera will continue to focus as long as you hold a half press of the shutter button. If you move AF to rear button, then it will continue to focus as long as you are holding the rear button down.
I strongly recommend against using AI Focus AF; it will choose the wrong mode *most* of the time. Just pick between One Shot and Servo as needed.
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
Keyan
Joined Mar 2011
Mar 01, 2012 11:57 |  #7
...that is what I thought, I had looked for it before on the 60D but it wasn't there.
Interestingly one user once said that the sports mode auto mode won't fire unless the camera hits focus first, so obviously the firmware itself can support this but the feature is locked out, probably to once again to protect the 7D.
Cameras: 7D2, S100
Snydremark
Gallery: 43 photos
Mar 01, 2012 12:06 |  #8
Probably. I wonder if Magic Lantern is available for the 60D nowdays; and if IT would enable that....
canadave
Mar 01, 2012 12:30 |  #9
There is indeed a working version of ML for 60D (the "Unified" version)...not sure if it enables the function in question though.
Canon 60D
- EF-S 18-55mm
ƒ3.5-5.6 IS • Tamron AF 70-300mm ƒ4-5.6 SP Di VC USD XLD • Pentax SMC-M 50mm ƒ1.4 (via adapter)
- Kenko Teleplus MC4 DG 2x teleconverter
- Manfrotto 055XPROB • Manfrotto 496RC2
fe1ixs
Mar 01, 2012 12:56 |  #10
Snydremark wrote in post #13997985 (external link)
thanks for clarifying. that is why I did not found the shutter priority setting on the canon tutorial.
regarding back focus button, I'm still not clear what is the advantages over using half-press shutter.
I read over here:
http://www.digital-photography-school.com …ips-for-tack-sharp-images (external link)
this guy obviously preferred to use back focus button. anybody knows how to explain this better?
amfoto1
Mar 01, 2012 13:34 |  #11
"Shutter Priority" is an exposure mode (Tv), unrelated to the auto focus mode choices. If you choose to use shutter priority, it's still auto exposure, except you set the ISO and the shutter speed and the camera chooses the aperture automatically. Usually shutter priority would be used with moving subjects, where the photographer wants to insure a high enough shutter speed to stop movement. You still have to watch that the apretures the camera is using are appropriate, give enough depth of field or even allow for enought exposure (it will blink in the viewfinder if outside the range). Adjust ISO, if needed, to get an appropriate range of apertures.
For wedding photography, among the various auto exposure modes I think most folks would use aperture priority exposure mode. This way, you set the ISO and the aperture and the camera chooses an appropriate shutter speed automatically. This allows you to control background blur and depth of field. Most wedding subjects are not moving (well, except maybe for dance shots at the reception, in which case you might want to change exposure modes). So the shutter speed, within reason, is less critical than the aperture. In this case, you might need to adjust ISO to keep within a usable range of shutter speeds, with the aperture you want to use.
Back Button Focusing is largely a sports photographer's trick, but certainly is usable for any type of photography. It separates the focusing function from the shutter release, which allows for more accuracy, recomposing and avoiding obstacles... It's often used in conjunction a single AF point, manually selected (usually the center point, which is more sensitive than the rest).
You don't have to use AI Servo for most wedding photography. Perhaps only for the dancing at the reception or the dash down the steps when the B&G are leaving. One Shot is more accurate and fine for posed shots, certainly. Also for many candid shots, when there is little or no movement.
And you don't have to use Back Button Focusing to use AI Servo. It is just one technique, though it can be a good one to learn... pretty quickly becomes second nature to control AF with that button. In a sense, it puts the photographer back in charge of where the camera focuses, rather than leaving it up to the camera to choose. It's a lot like manual focus, except that using the AF system this way is faster and more accurate (assuming reasonably good lenses, particularly those with USM for example) than manual focus ever was.
When you use All Points and let the camera choose where to focus, there's no telling where it might lock on... Usually it's the closest object, which might not be where you want focus. But it also might lock onto movement when using AI Servo.
It takes a little whille to learn to use BBF. Not sure I'd recommend it if you have an important shoot coming up in a week or so, unless you practice a lot. I use BBF all the time and almost exclusively for all types of shooting... it works equally well with either AI Servo or One Shot. (Note: I never use AI Focus, it's not really a separate focus mode at all and has a delay while the camera is deciding whether or not the subject is moving, then switches to using One Shot or AI Servo, whichever is appropriate. Haven't tried it again in years, but when I did it caused a lot of missed focus shots. The pro Canon camera models don't even have AI Focus mode at all... that alone should tell you something.)
I use BBF almost exclusively... And usually leave my cameras set to AI Servo by default and will switch to One Shot occasionally when shooting a static subject and wanting even more precision (Live View is even better yet, more precise, though it's considerably slower.) With One Shot the AF system locks onto the subject, then stops. And you get Focus Confirmation (the green LED lights up and, if enabled, you get a "beep"). With One Shot, if you want to change the point of focus, you have to lift pressure off the button (either the back button or the shutter release, whichever you have set up to use), then repress the button to re-focus. AI Servo, on the other hand, never locks and you don't get Focus Confirmation. There's nothing to confirm because it never locks, in fact. AI Servo continuously updating as long as you keep pressure on the button (either one you've set up). If you want to stop focusing for some reason, lift pressure off the button.
With either mode, it's important to keep the AF point you're using right where you want the camrea to focus. With AI Servo you have to do this continuously. If you let the AF point slip off the subject in AI Servo, even momentarily, the camera will refocus. But, if there is an obstruction between you and a moving subject, that the subject is going to pass behind, you can lift off the button to stop focusing, then reapply pressure to restart focusing after passing the obstruction.
When using a back button to turn AF on and off, you can make AI Servo behave as if it's One Shot, simply stopping focus at any time by lifting pressure off the button. This is why I use AI Servo as my default mode most of the time. One Shot cannot be made to act like AI Servo, but AI Servo can be made to act like One Shot. If not using BBF, you are more restricted... Can't really make AI Servo behave as if it's One Shot and stop focus. The camera will always refocus and continue focusing, as long as the shutter release is half pressed. This makes it pretty much impossible in AI Servo to focus and recompose, for example, when not using BBF.
This article at Canon Learning Center (external link)discusses more about using Back Button Focus with various camera models, general info about why and how. I suggest you read it carefully. I've been using BBF for years and am to the point where I get probably 95-98% of my shots in acceptible focus, even with difficult, faster moving subject (and some of my focus misses are user error, perhaps shooting too fast, or a thumb cramp or just missed pressing the Back Button.... others are down to the camera such as when a moving subject changes direction and the camera fails to keep up with it). BBF puts me back in full control of where the camera focuses, but it does require some concentration and takes some practice to learn to do really well, until it becomes second nature to control focus actions with your thumb.
But if you don't have time to practice and get good with it before an important event, you might want to just stick with what you've been doing.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - EXPOSUREMANAGER (external link)
Snydremark
Gallery: 43 photos
Mar 01, 2012 13:40 |  #12
Basically, it gives you much more control over when the camera attempts to focus/refocus. On the shutter button, the camera will attempt to focus every time you press the button. This means that you have to wait for the camera to search for focus with every shot you take.
This really can come into play for, say, a stationary subject or multiple subjects at the same distance. If you're shooting a person that is standing 10ft away and you focus on them with a certain framing, you can take that one shot. Then, in order to take another shot you have to wait for the camera to refocus again before taking that followup shot.
If you're using the back button to focus, you can acquire focus the first time and then take as many shots as you want without the time and potential for error around the camera changing focus in each shot. You simply don't engage AF until you're ready to focus on something else.
Camo ­ 757
Mar 01, 2012 13:41 |  #13
Thanks amfoto1 for that.
60D gripped/Tamron 17-50 VC 2.8/Tamron 60mm Macro 2.8/Canon 70-300mm IS
fe1ixs
Mar 01, 2012 14:02 |  #14
Snydremark wrote in post #13998781 (external link)
that is the most simple but clear explanation I ever read. thanks Snydremark!
Alan - I've used BBF while ago but ocassionally I missed the shots because i forgot to press the focus button! I know it will take time to learn new things. How long for you to get familiar with this practice?
Keyan
Joined Mar 2011
Mar 01, 2012 14:04 |  #15
Conversely, if the camera missed the first time, all of your shots are now out of focus ;)
If you don't fully release the shutter button and return to the half pressed position the camera will NOT refocus and you can fire again immediately too.
Cameras: 7D2, S100
25,507 views & 0 likes for this thread
version 2.0 /
Latest registered member is mason.snipes
774 guests, 406 members online
