Thread started 14 Mar 2012 (Wednesday) 14:18
Can I monitor my 5D Mark II/Mark III video recording on an iPad?
InterMurph
Joined Nov 2011
Mar 14, 2012 14:18 |  #1
I will (hopefully) be receiving my Canon 5D Mark III in enough time to record a school play.
I understand that the 5D Mark III will not auto-focus during video recording, so it's up to me to get the focus right. I don't want to rely on the small LCD screen on the camera, so I plan to bring a monitor with me.
Can I use an iPad for this? I see that the iPad has an AV adapter with HDMI:
http://www.bhphotovide​o.com …A_Digital_AV_Ad​apter.html (external link)
But this appears to be for output only.
Is it possible to monitor the video being recorded on a 5D Mark II or Mark III on an iPad?
Thanks.
ben_r_
-POTN's Three legged Support-
Mar 14, 2012 18:16 |  #2
There is no video in on the ipads that I know of. So unless there is some remote view app I dont think there is a way to do it.
InterMurph
Joined Nov 2011
Mar 14, 2012 19:16 |  #3
My Google searches have turned up a lot of references to wireless tethering, but those solutions seem to require a jailbroken iPad, and an EyeFi card.
Looks like I'll have to lug a monitor to the school, along with all of my other gear.
laselvasurf
Joined Aug 2011
Mar 15, 2012 12:33 |  #4
There is currently not way to do this. I would recommend getting a nice production monitor (marshall, tv logic, smallhd). Though they are atleast $500 for something decent.
5D MKII, T2i, 24-105L, 100-400L, 12-24 Sigma, 20mm F1.8 Sigma, 28mm F1.8 Sigma, 35mm F1.4 Rokinon, 50mm F1.4 Canon, 85mm F1.4 Vivitar
InterMurph
Joined Nov 2011
Mar 15, 2012 12:47 |  #5
Alas, my budget for this is $0.
I tested my 5D Mark III and my Dell 24-inch monitor, and it works. The resolution is pretty crappy, but at least I can get a decent feel for the focus.
I am tempted to curse Apple's obstinacy on such things, but I don't think there is an Android table that does this either.
laselvasurf
Joined Aug 2011
Mar 15, 2012 13:03 |  #6
InterMurph wrote in post #14091663 (external link)
This may be the best way to do it. If you were using a 7D, the resolution would remain higher resolution, even during record mode. Did you just use the HDMI input on your Dell?
InterMurph
Joined Nov 2011
Mar 15, 2012 13:07 |  #7
Yes, I connected the HDMI output on the camera to the HDMI input on my Dell.
I hope to get my 5D Mark III before the shows (March 29th). Is there any reason to believe that the Mark III will output the full HD resolution to this monitor?
Thanks.
ben_r_
Mar 15, 2012 13:17 |  #8
InterMurph wrote in post #14091790 (external link)
Thanks.
Do some research online about it. Rumor is that it will. All the bodies since the 5D2 have I believe.
laselvasurf
Joined Aug 2011
Mar 15, 2012 18:00 |  #9
ben_r_ wrote in post #14091851 (external link)
The only Canon body that does that you can purchase right now is the 7D. The 60D, t2i/t3i, 5dmk2 all only do the 480i res once you're recording. It seems that the 5D MK3 will have the capabilities to send atleast a 720 signal through hdmi while recording, should be the same as the 7D actually. So, you should be able to get a nice sharp image on your Dell with that camera.
InterMurph
Joined Nov 2011
Mar 15, 2012 19:18 |  #10
From the 5D Mark II manual (http://www.canonrumors​.com …/eos5dmkiii-im-c-en.pdf): (external link)
If you have a High-Definition TV set and connect your camera with an HDMI cable, you can watch Full High-Definition (FULL HD: 1920x1080) and High-Definition (HD: 1280x720) movies with higher image quality
This passage is in reference to watching an already-recorded movie on TV. I assume that it also applies to the signal passed during the recording, but I can't be sure.
ChasWG
Mar 16, 2012 15:52 |  #11
ben_r_ wrote in post #14087339 (external link)
Sorry Ben, I just picked your response because it was first. Others said the same thing, but you guys are wrong. There is a way to view video and audio on an iPad. I work with a guy that has a system to do this with his iPad as a producer monitor. It works very well, but again, I work at a pro level so my fix isn't going to be cheap, but it works! We us it with a Panasonic HDX-900 and transmit HD video via Wifi.
Look into the Teradek Cube.
http://www.bhphotovide​o.com …00124&Q=&is=REG​&A=details (external link)
http://www.teradek.com​/gallery/img_1.png (external link)
It's a Wifi encoder and if you have a iPad with Wifi abilities you have the receiver and monitor built into one. There is a very slight delay (1/4 second or less), but it actually is very clean and solid if you have it set up properly.
This is all predicated on the 5D III can output a signal while recording.
Chas Gordon
7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8
http://www.flickr.com/​photos/chaswg/ (external link)
http://vimeo.com/user9​461302/videos (external link)
ben_r_
Mar 16, 2012 17:09 |  #12
ChasWG wrote in post #14098979 (external link)
Crap... Youre right, and I KNEW about that box too, which makes it worse. I was thinking like HDMI in or analog video in when I said no. But thats unit utilizes an entirely different route. Probably out of OPs price range though...
InterMurph
Joined Nov 2011
Mar 16, 2012 17:24 |  #13
The OP doesn't want to buy a third device to get the first two to talk to each other.
I think I will just use my monitor.
ben_r_
Mar 16, 2012 17:27 |  #14
When youre ready, I have and highly recommend a SmallHD monitor. I use the DP6 with my 5D2 and 60D and love it. Its pretty much the industry standard for DSLRs. You can find used DP1x models too for great prices some times. They dont have all the features but are still great monitors that handle the up scaling well.
ChasWG
Mar 16, 2012 18:42 |  #15
I did say it was expensive. Oh well, just pointing it out as an option. people always want everything on the cheap around here. Problem is, video and audio isn't exactly cheap really. ;)
Chas Gordon
25,938 views & 0 likes for this thread
Latest registered member is jainlemos
752 guests, 418 members online
