Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 15th of March 2012 (Thu)   #1
Etherealdc
Etherealdc's Avatar
Default Issue shooting video w/ 5dMii
Was just out shooting some tests with my 5D and came across some issues. In the first clip (and this is evident in pretty much every clip I've shot), I'm seeing a definite jitter at the edges of moving objects. The second clip has a tear in the middle of the clip. Both clips were shot at 24p with a 1/50 shutter on two different CF cards (the first was some with an 8gig and the second with a 16gig). Are these common faults or do I have a bum camera?
http://youtu.be/t_XFd4ue4ZM
Ethereal Pictures
5DMkII
Canon Nifty Fifty 1.4 | Canon 24-70mm 2.8 | Canon 70-200mm 2.8 | Canon 100mm 2.8 macro
Etherealdc is offline   Reply With Quote
Old 15th of March 2012 (Thu)   #2
dfinn
Default Re: Issue shooting video w/ 5dMii
Mine definitely does not do that. Are you seeing that with the files straight off the camera?
dfinn is offline   Reply With Quote
Old 15th of March 2012 (Thu)   #3
Etherealdc
Etherealdc's Avatar
I saw it when I was shooting, during play-back on the camera, in the movie viewer on my iMac, and in Premier Pro before and after rendering,
Further info: I'm using SanDisk Extreme compact flash cards, 60MB/s UDMA.
Ethereal Pictures
5DMkII
Old 15th of March 2012 (Thu)   #4
Kento
Kento's Avatar
I'd try downgrading and then reupgrading your firmware. Then, if you haven't already, install Magic Latern's most recent version. Seems like a internal processing issue, which should hopefully be cured with a refresh of the firmware.
My Tools
-Jesse
Kento is offline   Reply With Quote
Old 15th of March 2012 (Thu)   #5
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
What Firmware Version are you running?
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\
ben_r_ is offline   Reply With Quote
Old 15th of March 2012 (Thu)   #6
Etherealdc
Etherealdc's Avatar
I'm using firmware version 2.0.9
Ethereal Pictures
5DMkII
Old 15th of March 2012 (Thu)   #7
ben_r_
ben_r_'s Avatar
Hmmm, the latest version is 2.1.2... Perhaps try updating? LINK
Old 15th of March 2012 (Thu)   #8
artyman
artyman's Avatar
Looks like rolling shutter to me http://en.wikipedia.org/wiki/Rolling_shutter
Art that takes you there. http://www.artyman.co.uk
Ken
artyman is offline   Reply With Quote
Old 15th of March 2012 (Thu)   #9
laselvasurf
The first part isn't too far from normal. Though it looks pretty nasty. The second is obviously a glitch of some sort. Issue shouldn't be caused by the 60MB/s UDMA cards, though I would try a full deep format on it before using again.
5D MKII, T2i, 24-105L, 100-400L, 12-24 Sigma, 20mm F1.8 Sigma, 28mm F1.8 Sigma, 35mm F1.4 Rokinon, 50mm F1.4 Canon, 85mm F1.4 Vivitar
flickr
laselvasurf is offline   Reply With Quote
Old 15th of March 2012 (Thu)   #10
Etherealdc
Etherealdc's Avatar
Yeah, I thought it looked pretty bad... It looks like a buffering error to me rather than shutter (speed or rolling). I've been doing tests all day and haven't had another tear as dramatic as the one in the second clip, but I'm going to go through frame by frame on a few of these tonight or tomorrow and see if there are smaller dropouts.
My camera should still be under warranty until July; I'm trying to decide if I should get it replaced or what...
Ethereal Pictures
5DMkII
Old 16th of March 2012 (Fri)   #11
Etherealdc
Etherealdc's Avatar
I went through a lot of the tests I've been doing the last few days; no more dropframes. I'm kind of at a loss for where this jutter is coming from.
Ethereal Pictures
5DMkII
Old 16th of March 2012 (Fri)   #12
Etherealdc
Etherealdc's Avatar
I guess this issue I'm having is fairly common, from some of the other threads I've come across on these boards and others around, but they don't seem to be universal? I've got the jutter, and I feel like there's these weird speed ramps during pans, too (maybe those two phenomenon are synonymous). But is this something that just occurs with the 5D in general? Are some individual 5ds better than others with this?
Ethereal Pictures
5DMkII
Old 16th of March 2012 (Fri)   #13
ben_r_
ben_r_'s Avatar
So upgrading the firmware didn't help?
Old 17th of March 2012 (Sat)   #14
Etherealdc
Etherealdc's Avatar
Apparently not; the jutter is very distinct, even in relatively slow pans.
http://youtu.be/Sw5mLepHNpE
First two clips are the ones I've already shown, the second two are post firmware update.
Ethereal Pictures
5DMkII
Old 17th of March 2012 (Sat)   #15
Etherealdc
Etherealdc's Avatar
Made a DVD with the files, watched it; the jitter/lurch is still there, so it doesn't appear to be a problem with the playback, either.
Ethereal Pictures
5DMkII
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
5DmII VS. T1i Video Nevilleblack Canon EOS Digital Cameras 2 9th of May 2009 (Sat) 18:46
5DMII Video: Bigger than 4G's? PubUltraStar Canon EOS Digital Cameras 4 3rd of February 2009 (Tue) 00:10
SX1: Focus issue while zooming shooting HD video? mkdevo Small Compact Digitals by Canon 1 12th of January 2009 (Mon) 11:55
Zoombrowser Install issue - 5DMII notsovery RAW, Post Processing and Printing 0 8th of January 2009 (Thu) 18:17
Why not a real test of 5DMII video? davidfig Digital Video 8 20th of December 2008 (Sat) 16:22
