Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Still Life, B/W & Experimental Talk
Reply
Thread Tools Display Modes
Old 22nd of March 2012 (Thu)   #1
PTone
Default How Do I Photograph a Painting?
I have a friend with an old, original painting which is worth quite a lot of money.
He would like me to photograph it and produce a faithful and accurate reproduction so that he can put the painting in a safe and hang the photo in his office.
The first thing I need to consider is the lighting – and I’ll worry about finding the right print paper later on.
I have a couple of Elinchrom studio strobes, 2 continuous lights and 3 flash units.
Does anyone know how I can best use these in the studio or home to bounce the light onto the painting so that I can render an accurate representation of the painting without hot spots etc?
I though that I should use the continuous lights, facing forward and from behind the painting, through a softbox and then bounce the light off white reflectors onto the painting. It’s a best guess but I would appreciate any other ideas if anyone has actually photographed a painting before .
Paul
PTone is offline   Reply With Quote
Old 25th of March 2012 (Sun)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Re: How Do I Photograph a Painting?
The wider the source, then the broader the highlights from the edges of the brush strokes will be, so I think I'd use direct light on the art.
Shooting artwork(paintings)
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 25th of March 2012 (Sun)   #3
johneo
johneo's Avatar
I took a photography class last quarter where we discussed a lot of different tecniques of how to get a photo of different sorts. One of my favorite parts of the class was when we discussed (and did) "Painting with Light".
I have "tried" taking photos of paintings and there always seems to be a glare from a flash or even other light sources. Having read your question, I'm going to give it a try by setting up the painting and paint the painting with a pen light while in Bulb mode. What I have learned is that it may take a few tries to get a subject right doing it this way but when you do get it right, WOW!
So, if you have access of the painting for a period of time, maybe give it a shot. If I have the chance, I may give mine a shot this afternoon just out of curiosity! (My painting isn't anything special, in fact it's a photo of mine printed as a painting ... but I guess it's still a painting??
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
johneo is offline   Reply With Quote
Old 28th of March 2012 (Wed)   #4
Jim60D
Some threads on POTN using search function:
Shooting art-work
reflection problem. paintings behind glass
Shooting art
& lots more. Try search function using "artwork" or "painting" plus "photograph" etc.
Jim60D is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cell phone painting!!!! (light painting) Nappy Still Life, B/W & Experimental 11 23rd of July 2009 (Thu) 00:03
Do you Photograph your vacations or vacation to photograph? Chrisedge The POTN Lounge 22 11th of November 2008 (Tue) 06:03
C+C please on CS3 oil painting Advocate RAW, Post Processing and Printing 10 12th of April 2008 (Sat) 00:55
Photograph or painting ? Olegis Still Life, B/W & Experimental 17 21st of April 2006 (Fri) 12:06
