Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 28th of November 2005 (Mon)   #1
tiagosays
Default Info Canon Eos 5D vs Nikon D200
hello to you all
this is a canon foum but i thing we should open the discution to make some reviews bettween cameras from diferent manufactures, because is necessary to improve canon features.
Can you say what you thing about these two cameras? the pros and cons of them.
what is the best camera?
the best price/features?
your choise and why?
lens? compatibility?
the camera with more options for future ?
thanks
tiagosays is offline   Reply With Quote
Old 28th of November 2005 (Mon)   #2
Tancor
Default Re: Info Canon Eos 5D vs Nikon D200
Unfortunately, until its released (the D200 I mean) - it will be impossible to make a judgement between the two. Besides, it might be more fair to compare it to the 20D rather then the 5D (and even that isn't terribly fair as the 20D is > 1yr old). IMHO, it's kind of hard to compare a FF camera to a crop camera - the differences there are already astounding due to the way lenses act on the two different cameras - and some people prefer the crop and "longer" equivilant lenses, and some people prefer wide, true length lenses.
The earliest hands on we might even see in terms of a review is sometime this week, and it still might not be a production camera yet, and that's assuming that someone who writes good balanced reviews goes to that event in the UK and gets some real hands on time with the D200 (unlikely).
JMHO
-Tony
FOR SALE Fuji Pictrography 3500,
FOR SALE Mitsubishi CP-3020
Tancor is offline   Reply With Quote
Old 28th of November 2005 (Mon)   #3
Longwatcher
obsolete as of this post
Longwatcher's Avatar
Can you say what you think about these two cameras? the pros and cons of them.
Both are good cameras (or at least the D200 may be when it people can get it).
5D is full frame with more pixels and better buffer.
D200 is 1.5x with a faster FPS and a built in flash. Oh and it has a better battery indicator, which is the only think I wish Canon would incorporate.
That's about it for the facts. research indicates the 5D has better noise reduction at high ISO, while the D200 may produce a better jpeg out of the camera. I usually shoot RAW, so the jpeg doesn't matter to me much.
Canon 1DsMkII...
oh you mean between 5D and D200. Depends on what you need a camera to do, I lean towards 5D for portraits which is what I shoot most of. As to D200 it's real Canon competition will be the replacement for the 20D (if it is released as expected Feb/Mar)
Toss up, depends on what you need the camera to do. The D200 (when it is available) has some great features if those meet your needs, but the 5D's main feature is that it is a relatively low cost 35mm format FF camera in a small body.
5D for the image quality and full frame (but it would be a step down for me from the 1DsMkII I have).
lens?
Mixed as to lenses, except Canon has better telephoto and tilt-shift and with a FF camera you can actually use a Fisheye as intended.
compatibility?
Nikon lenses will fit a Canon EF mount with an adapter, it won't work the other way around. Think about it.
Canon system because they have already adopted FF and produce more of their equipment in house.
Having re-read this, I appear a bit grumpier then normal. So I will re-imphasis both are great cameras and I recommend the following link from DP Review to do your own comparison.
http://www.dpreview.com/articles/nikond200/page12.asp
Just my opinion,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Old 28th of November 2005 (Mon)   #4
Tancor
I unfortunately, don't want to speculate yet. What appears good on screen now for feature set may be different in a production camera - on dpreview it did specify it was a pre-production camera so some things might have changed between pre production and production.
I wouldn't want to count the chickens before their hatched as the saying goes. Nikon people will probably say the D200 is better, canon people will say the canon product is better. I'd just rather wait and see what it can do in peoples hands and what features are truely there before I judge.
If I were forced with gun to head to judge, I'd say pull the trigger as I'm not going to guess until I've really seen it.
Old 28th of November 2005 (Mon)   #5
Jon
Moderator
Slayer of Trolls
Jon's Avatar
Between the Canon EOS 5D and the Nikon D200? One's available and the other isn't. Any comparison between them at this point will be between a real camera and a press release. And you can't take pictures with a press release, so the advantage has to be to the Canon. The D200, based on its specs, is aimed more at the 20D than the 5D. Nikon doesn't have a 5D-equivalent, or any indication it's going to produce one. So the fairer comparison would be with the 20D, or the 20D replacement that's widely expected to be released in February.
Jon
EOS, PowerShot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Marketplace Changes *** IMPORTANT! ***
Jon is offline   Reply With Quote
Old 28th of November 2005 (Mon)   #6
tiagosays
JMHO
-Tony
FF camera and a crop camera ?? where i can see the diference? some site explaining the specs. lenses, technical issues.
also where i can find some documentation or site explaining and talking about this?
the main diferences, examples, photos
what event is this one? can you post the name of the event?
whem you see some info about hands on on the D200 please post the site ok
thanks
Old 28th of November 2005 (Mon)   #7
Jon
Moderator
Slayer of Trolls
Jon's Avatar
thanks
The difference between full-frame and crop? Same as the difference between a 5D and a 20D,or the 1Ds II and the 3050D as far as effect on the lenses goes. The D200's going to be, like every other Nikon DSLR, a 1.5x crop sensor. The 1.6x crop of the Canon xxD/xxxD line is close enough that that will show you the difference.
Don't expect to get "real hands-on time" with a D200 at a camera show or trade fair. You'll be just one of hundreds of others with the same goal.
As for "hands on" reviews - have you tried Googling for "D200 Nikon Review"? It's far from clear when the reviewers have actually had their hands on a straight production model, not a pre-production or prototype (or a spec sheet they've drooled over so much it's turned into papier mache in the shape of the camera).
Jon
Old 28th of November 2005 (Mon)   #8
Tancor
There is a ton of discussion here on PoTN on the differences between FF and crop. Crop cameras have sensors smaller then a standard 35mm film frame - when you look at the specs of cameras, like the 20d at a 1.6x crop or the D200 which I assume is a 1.5x ratio (which as I recall is common on the nikon design), where as the 5D, 1Ds and 1DsMkII are all full frame cameras.
What does this mean? This means that with a 28mm lens on a FF camera, it is capturing at the 28mm length exactly what a single frame of 35mm film would capture. On a crop camera, with a 28mm lens, it will capture a smaller area giving the appearance of a longer lens being used, the crop factor gives you a number to figure out what the equivilant lens length is (ie: on the 20D @1.6 crop factor, a 28mm lens will cause an image to be recorded that is equivilant to a 44.8mm lens on a full frame camera.)
I suggest you look at the links here:
http://www.photography-on-the.net/fo...ht=crop+factor
for more discussion on the cropping factor.
See above.
http://www.dpreview.com/news/0511/05...utionsexpo.asp
That is brief announcement of the event.
thanks
There are a few hands on previews, but so far the previews appear to be pre-production cameras (see dpreview, or a google search on d200 review or d200 preview)
-Tony
Old 28th of November 2005 (Mon)   #9
Mark_Cohran
Moderator
Mark_Cohran's Avatar
I can't really see the utility of comparing specific Nikon and Canon cameras in a Canon forum. There may be some value in comparing general capabilities, but only if the information was somehow fed back to Nikon and Canon - which I don't believe will occur with this particular thread.
I guess I just don't understand the need to compare Nikon and Canon specific cameras unless one is just starting out in photography and changing systems. Most people have considerable investment in lenses, flashes and other accessories and aren't going to change systems just because one manufacturer leapfrogs the other.
Mark
Some primes, some zooms, some Ls, some bodies.
Bodies come and go, glass is forever.
My Complete Gear List
G&N FORUM ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 29th of November 2005 (Tue)   #10
puttick
puttick's Avatar
I like apples and oranges. Which is best? Hard to say. Sometimes I prefer a Kiwi fruit.
Dr Nigel Puttick
North Yorkshire, UK
puttick is offline   Reply With Quote
Old 29th of November 2005 (Tue)   #11
liza
User is banned from forums
Here's a chart that compares the new Nikon to the Canon 5D, Canon 20D, and Nikon D100. I thought it was rather interesting. Of course, Canon will wait for a bit while everyone praises Nikon's new offering and then will promptly give Nikon a swift kick in the groin by announcing an incredible new product or two in the spring at PMA. Seems like it always happens that way.
http://www.letsgodigital.org/html/re.../dslr_EN3.html
liza is offline   Reply With Quote
Old 30th of November 2005 (Wed)   #12
Andy_T
I see that different. As the question 'which camera to get' gets asked very often, I think it is an important question to ask ... for the sake of those in the decision phase.
Although, in this case, the comparison does not make much sense, as they are two very different beasts, as Longwatcher already pointed out... how do you compare a Porsche 911 to a Hummer? If you want good track times, the 911 is going to win, if you need it for off-road adventures, you might want the Hummer...
It makes more sense to compare the D200 to the 20D ... in about 4 months from now . Because, if you need the camera now, it's the 20D for you.
If you can wait, you might want to compare the 200D to the 30D or whatever Canons successor model will be called ... that will be at least presented by that time.
Best regards,
Andy
Andy_T is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTT: Canon 30D for Nikon D200 Ksorbe Classifieds: Buy 0 23rd of July 2007 (Mon) 13:11
WTB: Canon 1DMKII (N), Nikon D200, Nikon D2XS keropipi Classifieds: Buy 1 21st of June 2007 (Thu) 14:13
what is the canon equivilant to the nikon D200?? georgio petkovic Canon EOS Digital Cameras 31 17th of September 2006 (Sun) 19:32
New Nikon D200 info leaked i2iSTUDIOS The POTN Lounge 22 2nd of November 2005 (Wed) 13:35
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
