#1 |
Hey all,
So I'm a n00b to the forums and this is my first post. I did not find a more appropriate category to post this in so here goes. I've recently started becoming interested in automotive photography and have one quick question; how are shots like this (below) achieved with manual settings and no PS? ![]() Thanks, guys! |
| sponsored links |
#2 |
not possible. that has to be an HDR shot. A combo of a slow shutter shot and a fast shutter shot. Unless the clouds are moving at the same speed as the car.
image creating thingamajiggy, size and charge addition, Lens that doesnt move, wider lens that doesnt move but less deep like, an even wider lens that doesnt move and even less deep like, zoomy lens, Better zoomy lens, bigger zoomy lens, excellent bigish zoomy Lens, light maker, excellent zoomy Lens magnifier My Photo Blog: http://joetakesphotos.com/ |
#3 |
Really? I've heard of people achieving this without HDR. Maybe I misunderstood...
| sponsored links |
#4 |
I cant see how its possible to not have the clouds moving, even just a little bit. i see some of it on the edges but right in the middle is static. I mean, I dont know everything there is but I just cant imagine a way to do it otherwise.
#5 |
Hopefully someone else chimes in.
#6 |
You can achieve this type of shot without HDR. You can simply boost clarity or use the adaptive exposure slider in Topaz Adjust. Or you can work in layers and adjust contrast and saturation.
The clouds have no motion because of perspective. At the distance that the sky is in relation to the foreground it will appear not to move. Think of an airplane that's flying in the same direction that you're driving. You watch the airplane, as the scenery between you and the plane moves the plane stays stationary relative to you. It's just a matter of perspective.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill My Gear - Flickr - Facebook Smoke Photography - Sound-Activated Paint |
#7 |
so this is a car to car shot?
#8 | |
Seems like it. It's what I was thinking originally as most automotive photographers do this.
#9 | |
#10 | |
Also that looks like a rolling shot from a chase car, as opposed to a rig shot.
Flickr |
#11 |
I found out that that's what it is.
#12 |
Glad i could help
Flickr |
#13 |
This shot is quite simple to setup if you know what you are doing. I however do not. I have been the driver of the chase car a couple times a long time ago(7-9 years). This was before I was even into photography.
The first setup was basically hand held from the passenger seat of my 328is. The results were cool but nowhere near this level. I would say camera shake, lack of knowledge/ability and rough roads were the downfalls. The second and third time were shot from an SUV(explorer) that I was driving with a camera on a tripod in the back seat. A ten pound weight was attached to the tripod to hold it down and foam under the feet to give shock absorbtion. The results were way better but still not at this level. Very hit or miss type of results probably due to bumps, low level equipment and lack of knowledge. The fourth and final time I participated was using a large SUV(yukon) with someone in the back seat. This photog knew what he was doing and nailed it. He shot handheld with a 1d2 and a 70-200 f2.8 IS. Only reason I know this is because 5 or 6 years after, i had gotten into photography and I had the same setup. I have never attempted this type of photography so I have no clue what setting are/were used. |
#14 |
It could be a composite of different shots as well.
Avangard Photography | Toronto Wedding Photographer |
#15 |
Rig shot??
| Thread Tools | |
| Display Modes | |
| need help on how to achieve a shot | charlie_merrifi | Small Flash and Studio Lighting | 10 | 7th of October 2011 (Fri) 23:35 |
| How do i achieve this type of shot | Subfightersandman | Glamour & Nude Talk | 18 | 13th of November 2009 (Fri) 02:47 |
| Trying to achieve A GLAMOUR shot. | Nino Gallego | Critique Corner | 11 | 17th of September 2009 (Thu) 14:51 |
| how can i achieve this shot... | Nino Gallego | RAW, Post Processing and Printing | 13 | 27th of August 2009 (Thu) 19:59 |
