Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > People Talk
Reply
Thread Tools Display Modes
Old 6th of April 2012 (Fri)   #1
javierz0509
javierz0509's Avatar
Default portrait setting for canon 7d
hi everyone, i would like to know what would be the best setting for portrait photos, i currently have a canon 7d and the lens that came with it 28-135mm i also have an orbis flash ring that was given to me as a gift. Also when i have my flash wireless the 430exii
the flash zoom is always set to manual how can i set it to auto? or is this feature only on when the flash is on the hotshoe?
javierz0509 is offline   Reply With Quote
Old 6th of April 2012 (Fri)   #2
alexcaro
Default Re: portrait setting for canon 7d
There is no "best setting"; a bright lit area will have a far different "setting" for a dark lit area. Throw your lens on take a couple shots and adjust your settings according to what preference is. I generally use M or AP for portraits.
For the flash, you can use ETTL.
Good luck and have fun.
5d MKii : Canon 24-70mm L : Canon 70-200mm L : Canon 135mm L : Canon 100mm f2.8 Macro : Sigma 50mm f1.4 : Sigma 85mm f1.4 : Tokina 12-24mm f4
alexcaro is offline   Reply With Quote
Old 7th of April 2012 (Sat)   #3
javierz0509
can someone tell if there is a lost in feature by having the external flash wirelessly?
Old 10th of April 2012 (Tue)   #4
drmaxx
I don't think that there are any features lost - at least not ETTL.
You might want to check out this site:
http://neilvn.com/tangents/flash-pho...tography-tips/
Has some very useful tips how to use the flash. The big revelation for me was that with ETTL only the flash compensation matters. The other settings (exposure time, aperture, iso) only affect how strong the background shows up in your pic.
(hope that is not overly simplified - but I am sure that somebody will fill in the details ).
Donate if you love POTN
drmaxx is online now   Reply With Quote
Old 10th of April 2012 (Tue)   #5
meeko031
meeko031's Avatar
came across this on youtube, it's a beginner video for portraiture lighting presented by B&H
lighting for portraiture
also check these other two videos for off camera flash
off camera flash
lighting and control
visualdesignform.com
meeko031 is offline   Reply With Quote
Old 10th of April 2012 (Tue)   #6
gonzogolf
You cannot use the flash in HSS mode using the 7D in wireless controller mode. What you need to undestand is that you essentially have 2 different exposure values when you use a flash. The first is the ambient exposure (the area not lit by the flash, the background) and the flash exposure. You can control the ambient by using your camera in M mode and adjust the shutter speed up and down to control how much light you get in the background. The flash power then controls the brightness of the area lit by the flash.
gonzogolf is offline   Reply With Quote
Old 10th of April 2012 (Tue)   #7
HughR
HughR's Avatar
To the op:
I use the pop-up on my 60D with two 430EXs to control wireless flash all the time, so here is the answer to your question. When your 430EX is mounted in the hot shoe and the flash head is pointed forward (not bounce position!), auto zoom works perfectly (unless you choose to switch it to manual zoom). If your 430EX is in the hot shoe, but you tilt the head upward or to the side for bounce, zoom defaults to 50mm. This is generally a good setting for bounce, and Canon chose wisely. If you use your 430EX wirelessly, the zoom defaults to 24mm. This is very convenient, as I generally put a softbox on the 430EX when using it wirelessly, and 24mm is ideal for that. In these last two cases, the camera cannot know how far the light is traveling to the subject, so auto zoom makes no sense. In any case, you can manually zoom to whatever focal length you want.
When the 430EX or 430EX II is used wirelessly, the following features are not available:
Auto Zoom as discussed above
Second curtain sync is lost.
High Speed sync is lost.
If you want either HS sync or 2nd curtain, the 430EX must be on camera or connected with the camera by an ETTL cable.
Finally, as drmaxx has said, ETTL works perfectly with off camera wireless flash controlled by the pop-up. I use it all the time.
Hope this helps.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
HughR is offline   Reply With Quote
Old 10th of April 2012 (Tue)   #8
meeko031
meeko031's Avatar
Originally Posted by HughR View Post
Hope this helps.
i don't know if it helped the OP but it definitely helped me!
thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Couples portrait shot w/ 24-70L - what setting to use? tagakweens People Talk 4 12th of February 2011 (Sat) 13:27
Portrait Setting for a 1D Mk II JeffreyVB People Talk 5 19th of January 2009 (Mon) 22:24
Help desired in setting a location portrait mattograph People 9 24th of February 2008 (Sun) 17:06
Portrait setting on S2 IS...I give up! mommytomjm Small Compact Digitals by Canon 17 13th of December 2006 (Wed) 13:13
