FORUMS Photography Talk by Genre Sports Talk
Thread started 10 Apr 2012 (Tuesday) 10:43
Football gear advice
dachness
Joined Dec 2011
Apr 10, 2012 10:43 |  #1
I would like to shoot Gridiron football as a hobby. My brother in law plays for one of the teams and I would like to primarily get shots of him and his team.
Its my understanding that 1-2 photographers cover the games. I sent an email to the league asking what is necissary to gain sideline access.
The locations of the games are typically HS fields with two of the games being at our Aloha Stadium. The games are late afternoon to evening. From what I have read it seems like a 300-400mm FL is typically used for football.
My proposed equipment:
60D
EF 70-200 2.8 IS II
Keno 1.4x PRO DGX
Monopod(+QR attachment?)
Rain protection gear
Battery grip
The 70-200 2.8 will be purchased refurbished from canon. Is the 1.4x TC needed? Also would a monopod be reccomended? I am 5' 8", any thoughts on a QR system or do I screw directly onto the lens mount? What's a cheap rain protection solution? Also I assume a grip would be beneficial for the portrait orentiation.
For the last three items I assume they are mostly optional but highly reccomended. Budget for all three would be ~$200, the less I can spend the better.
Daniel
60D |10-18 f/4.5-5.6 IS STM | Σ 17-50 f/2.8 OS | 70-200 f/2.8L IS II | 430EX II
DC ­ Fan
Apr 10, 2012 21:26 |  #2
U.S. gridiron football with a 70-200mm f/2.8 lens, a non-stabilized Sigma unit, and a Canon 60D.
Focal Length: 118.0mm
Aperture: f/3.2
Exposure Time: 0.0010 s (1/1000)
ISO equiv: 3200
Exposure Bias: none
Metering Mode: Matrix
Exposure: shutter priority (semi-auto)
White Balance: Manual
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Focal Length: 144.0mm
Aperture: f/2.8
Exposure Time: 0.0025 s (1/400)
ISO equiv: 4000
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Focal Length: 154.0mm
Aperture: f/3.5
ISO equiv: 2000
Exposure Bias: none
Exposure: Manual
Exposure Mode: Manual
White Balance: Auto
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
A 70-200mm f/2.8 lens is a good basic coverage lens for all sports. As shown in the example images, the lens' light-gathering ability, along with use of a high ISO, is useful for night games.
A 70-200mm f/2.8 is on the short side for U.S. gridiron football, where lenses in the 300mm-500mm range are in common use. Using the 70-200mm will require you to stay in constant motion on the sidelines to maintain a distance that leads to properly framed images, while a longer lens offers the luxury of staying in one spot. A teleconverter may help, as long as it doesn't slow the system's autofocus response, which is vital for a fast-moving game.
While larger primes require monopods for support, it's not likely that a 70-200mm f/2.8 is going to need one. That kind of lens is usually considered small and light enough to be operated by hand with no additional support.
dachness
Joined Dec 2011
Apr 11, 2012 10:49 |  #3
Thank you for sharing. I think I will start out hand held and only get a monopod if I truly need one. What was the process for sideline access? Are there any rules/limitations for photographers?
What are your pictures used for?
Daniel
dachness
Joined Dec 2011
Apr 19, 2012 16:51 |  #4
I purchased the EF 70-200 2.8 IS II. I hope to be shooting my first game this Sunday. I have yet to speak with the league about side line access. Any one have any advice?
I plan to shoot AV and adjust ISO to keep shutter speed 1/640 or higher, AI Servo w/ BBF. I will be shooting hand held with out an extender.
What do people suggest regarding IS modes? Any one have suggestions on shooting landscape vs portrait orientation for football?
Daniel
clarence
Apr 20, 2012 10:40 |  #5
dachness wrote in post #14294581 (external link)
Av mode is a good place to start, but if you have fairly stable light, use Av to get a starting point for exposures and then switch to M with those settings.
Av metering can be thrown off by the different jersey colors. One team is usually wearing a dark jersey and the other team is usually assigned a white or light-color jersey. Auto exposure will tend to underexpose for the light jersey and over-expose for the dark jersey... you'll want to expose consistently for the faces regardless of the uniform. M mode will help you do that.
But M mode also requires a little more monitoring on your part. If the ambient light is fading (dusk/sunset), or you have clouds rolling in and out during the game, or if part of the field is in the shade or shadows, then Av mode can be useful.
My rule of thumb is that IS is most useful with SS < 1/focal length. So if you're shooting 200mm, even if you factor in the sensor crop factor of 1.6x, as long as your SS is faster than 1/320 (which it should be since for sports you'll want to be faster than 1/640, ideally closer to 1/1000"), then you don't need IS.
But aside from battery life, there's no real harm in keeping IS on. The older lenses with IS (like 100-400) take a while to spin up, but the newer IS like 70-200 II do much better. IS can also be useful with super-teles (400L, 600L) to keep the viewfinder stable, making it easier to keep the focus point on the subject.
I prefer portrait mode 90% of the time. Fill the frame with the subject. Football players are standing/running. But if you aren't close enough to fill the frame with a single player, then horizontal/landscape orientation can allow you to include defensive/opposing interaction.
Avoid amputating limbs. If you can't get the toes and fingers, then go much tighter. If you can't include both feet in the frame, then compose/crop above the knees.
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
dachness
Joined Dec 2011
Apr 20, 2012 11:32 |  #6
Thank you for the advice. My lens didn't ship yet so it looks like I will have to wait til next week for shooting my first game.
Daniel
Hannya
Apr 20, 2012 12:14 |  #7
Get a seat, a fishing or camping stool. More important than a monopod, since you ought to be shooting at a high ss.
“Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson
Sports Pics (external link)
clarence
Apr 20, 2012 12:19 |  #8
Hannya wrote in post #14298921 (external link)
I've never seen a seat on the sidelines of a football game. I doubt it would be allowed. Even if it was, I don't think it would be safe. Plus, since the OP only has a 200mm max, he should remain mobile to stay with the action as it moves up and down the field.
Get low, yes. But kneel. Stay mobile and stay safe.
dachness
Joined Dec 2011
Apr 20, 2012 13:57 |  #9
I had not thought about perspective change of standing vs kneeling.
Sounds like knee pads would be highly reccomended? I have seen these mentioned before: Alta Tactical (external link). Do you have any suggestions.
Also with portrait orientation being the goal it seems like a grip might be useful.
Daniel
kenjancef
Gallery: 20 photos
Apr 20, 2012 19:08 |  #10
dachness wrote in post #14299411 (external link)
Yes, it is VERY useful. And also for the fact that you can pop 2 batteries in there. When I had my gripped 7D I never ran low on any job.
dachness
Joined Dec 2011
Apr 28, 2012 02:42 |  #11
Just wanted to give everyone an update. I spoke with the league http://gridironhawaii.​com/ (external link) and they will give me sideline access with a catch. They would like one shot from each game I shoot(for use on their website for weekly recaps etc). If they use my image they will give me credit for the shot. Any suggestions, on what resolution file I should provide?
I didn't want to do it initially, but they were pretty set on it. I am primarily there to get shots of my brother in-law playing so its a small price to pay for being able to get better shots from the sideline.
My current setup will be a gripped 60D and 70-200 f/2.8L IS II. Don't have knee pads, so not sure how kneelling will work out. I may try to find some at the hardware store. I am still debating on picking up 1.4X. There is a 1.4X II available for $225 locally but the seller hasn't responded.
I will be shooting my first game this Sunday at 4PM.
Daniel
Hannya
Apr 29, 2012 11:07 |  #12
Let's see how you got on.
I came across this
http://thediscerningph​otographer.com …l-american-football-game/ (external link)
Might be helpful.
One pic from a game is doable, and if you're not earning money from it, why not?
Envying you in Hawaii from the rain-soaked UK ...
dachness
Joined Dec 2011
Apr 29, 2012 13:23 |  #13
Hannya thank you for the link. Kick off is about 7 hours away.
Daniel
dachness
Joined Dec 2011
Apr 30, 2012 19:01 |  #14
The game went will. I shot a little over 900 photos. I shot RAW using manual mode and checked the histogram often. Kept shutter speeds of 1/1000 or higher. I found that center FP worked best for me as using the higher FP resulted in too much field in the frame. I am extremely happy with my results for my first time. I improved alot from the beginning of the game. I had a some OOF shots, one which would have been the MONEY shot (a catch).
Things I need to work on include: anticipating the action(ie: a catch), using FL wisely and preserving my memory buffer for when its truly needed.
This is the shot that I sent to the league. I will try to post more shots when I have a chance.
3443
x
2295
TOO LARGE!
EMBED PREVENTED, IMAGE TOO LARGE:
http://img717.imagesha​ck.us …iluastormvsewab​eachca.jpg
Click here to see our image rules.
Daniel
4Bucks
May 03, 2012 15:26 |  #15
nice.
4Bucks does not = photo for $... Four Buckleys in the family
A must read for all new to photography: Ben's Newbie Guide http://photography-on-the.net/forum/showthre​ad.php?t=414088
My stuff: 7D, some lenses, and OCFs
Facebook (external link)
3,769 views & 0 likes for this thread
Latest registered member is gary gruber
744 guests, 356 members online
