Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 15th of April 2012 (Sun)   #1
stoat
Default 430Ex help
Ok I've tried everything but I'm obviously missing some vital element! I want to do high speed sync (freezing motion, water droplets etc) photography. I have a Canon 5d Mk11 and a 430 ex speedlite. I have set the speedlite (off camera) to M, checked that the zoom range is the same as the focal range of lens (although can't seem to see the range of the flash showing on the screen as mentioned in the manual) checked the H with arrow symbol is showing on flash. And yet when I try anything above 250 I get the black curtain. As far as I was aware with these setting I could use any shutter speed (obviously adjusting my aperature of course ) but nothing above 250 seems to work. What am I doing wrong ? Btw I also have the young uno trigger which works fine. Any help greatfully accepted
stoat is offline   Reply With Quote
Old 15th of April 2012 (Sun)   #2
iLvision
User is banned from forums
Default Re: 430Ex help
If all of your settings are right then it's the problem with your trigger.
NOTE: not all triggers have a high speed sync! I didnt know this before but unfortunately we all learn. Make sure your trigger is capable with high speed sync. (there's only a few that are)
iLvision is offline   Reply With Quote
Old 15th of April 2012 (Sun)   #3
ELT_Photo
In order to use HSS, your radio triggers must be ETTL capable - PW mini/flex, Phottix
Odin are two of the top of my head.
Good luck,
Eric
Passion - Dedication - Inspiration (and some gear)
ELT_Photo is offline   Reply With Quote
Old 15th of April 2012 (Sun)   #4
oldvultureface
oldvultureface's Avatar
You can also use an E-TTL cord connecting your flash to the camera. That will carry all the signals necessary for HSS.
oldvultureface is offline   Reply With Quote
Old 15th of April 2012 (Sun)   #5
stoat
wow thank you so much for your quick responses. I can't believe something so simple as not using my trigger was the answer - this has been annoying me for ages !. Time to buy a dedicated trigger I guess, or at least a cord . In the meantime I'm going to be, hopefully, improving my water splashes greatly!
Old 15th of April 2012 (Sun)   #6
iLvision
No problem
I went with the Phottix Odin solution and couldn't be happier. Best E-TTL stuff out there. A lot of people have problems with E-TTL Pocketwizards. (flex/mini) so I would skip on PW.
I suggest you to get Phottix Odin set instead and you're set for 1/8,000
Old 15th of April 2012 (Sun)   #7
stoat
one more question - any recommendations for best triggers and best sites to buy from (U.K)
Old 15th of April 2012 (Sun)   #8
Matt Peters
Matt Peters's Avatar
You don't need HSS to get water drops, this was taken at 1/200 @ f/8 with a 430ex using RF-602 wireless triggers from eBay.
Water, week 8 by Matt Peters Photography, on Flickr
Matt Peters is offline   Reply With Quote
Old 15th of April 2012 (Sun)   #9
AntonLargiader
Originally Posted by iluxa007 View Post
... A lot of people have problems with E-TTL Pocketwizards. (flex/mini)
Some people have problems with the 580EXII flash. Otherwise, I don't know of any widespread problem anyone is having with them.
However, the real point here is that HSS isn't needed nor even desirable for this sort of shot. By using low-power sync flash, you get a faster exposure because the shutter time isn't very important. A low-power flash pulse is shorter than your fastest shutter speed. With HSS, the lighting pulse is longer, so you get more motion blur.
T2i . 18-55 IS . 70-300 IS USM . 70-200 2.8L IS . 28mm 1.8 . 100 Macro . 430EX II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
AntonLargiader is offline   Reply With Quote
Old 15th of April 2012 (Sun)   #10
stoat
and I have done that Matt but, with all due respect, it doesn't give a crisp sharp finish and that is what I now want to do, so by getting a shutter speed of 8,000 I can attempt to actually freeze those droplets
Old 15th of April 2012 (Sun)   #11
AntonLargiader
That doesn't look very frozen to me. The available data for flash duration isn't consistent, but all indications are that the effective speed of low-power flash is in the 1/10,000 to 1/40,000 range.
Would love to see some comparisons.
Old 15th of April 2012 (Sun)   #12
stoat
it isn't frozen - which is why I want the facility to use a high shutter speed - hence my post !! Now I have the information I can save up for a descent trigger and hopefully get that frozen appearance !
Old 15th of April 2012 (Sun)   #13
AntonLargiader
What was the flash power in that?
Old 15th of April 2012 (Sun)   #14
stoat
don't have that info I'm afraid
Old 15th of April 2012 (Sun)   #15
oldvultureface
Looking at the EXIF (f/22, ISO 200) and guessing at the flash to subject distance, I'd say 1/8 to 1/4 power.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: CANON EOS 40D OR 50D BODY... 430EX, 430EX II, 540EZ, 18-55mm IS... jonathanslam Classifieds: Buy 1 29th of March 2011 (Tue) 18:12
Difference between Canon 430EX and 430EX II Flash bigguytf Small Flash and Studio Lighting 7 18th of December 2009 (Fri) 14:06
Sto-Fen Omni-Bounce for the Canon 430EX & 430EX II Nightowl64 Small Flash and Studio Lighting 20 12th of May 2009 (Tue) 08:42
