FORUMS Photography Talk by Genre Nature & Landscapes Talk
Thread started 15 Apr 2012 (Sunday) 11:05
Lens for Antelope Canyon and Horseshoe Bend
IShootThings
I thought I was special.......
Apr 15, 2012 11:05 |  #1
Hello. I'm about to purchase a 7d and 24-70L lens before taking a trip through the Grand Canyon and Page. Is the 24 end of the 24-70 going to be sufficient for Antelope Canyon and/or Horseshoe Bend? If not I'm trying to save money so I'm not sure which of the following options I should go with on the 7d:
1. Use my 18-55 is kit lens from my xti
2. Rent a 10-20mm Canon from an online rental shop for $100
3. Buy the Sigma 10-20 f 4-5.6 for $375 used
4. Buy the Tamron AF 10-24mm f/3.5-4.5 SP Di II LD used for $300 used
Any help or other suggestions are appreciated.
Canon 5D3, Canon XTI (IR converted), 24-70 f2.8L, 16-35 f4L, 50 1.4, 70-200 f2.8L, 100 2.8 macro, 430 ex & 580 exII speedlights.
irishman
Apr 15, 2012 12:04 |  #2
The only thing I can tell you for sure is that on the 7D the 24 will not be wide enough for either place. How you budget your dollars for a wide angle is going to be up to you.
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
Cali_PH
Joined Apr 2012
Apr 15, 2012 12:11 |  #3
I have the Canon 10-22 and use it quite a bit, more than any other lens for landscape. I haven't tried the Sigma or Tamron, but I've heard the image quality isn't as good.
I did a quick look at some of my Antelope Canyon shots and I found almost all were at 10mm or close to that; I was shooting with a T2i (1.6 crop factor), especially in Lower Antelope which can get quite a bit tighter than Upper. Sometimes I did a few shots with a 24-105, but only once, because I was so worried about the dust being blown into the canyon. Next time I'll take two bodies with different lenses.
For some perspective, here's one of my shots of Horsehoe Bend at 10mm. I was very glad for the wide angle here; you can't really stand further back and still include river, and even with 10mm I cut off the river and still keep as much of the sky I wanted in the shot. Later, I thought about stitching but by then that was too late. I also may not have picked the best ledge to photograph from, but I felt decently safe on that one lol.
EDIT -Sorry, had to shrink the file a lot to fit within forum limits
argyle
Apr 15, 2012 13:06 |  #4
irishman wrote in post #14269586 (external link)
What Bruce said. You'll need at least 10mm on a crop body to capture most of the bend. OTOH, you can also consider renting a fisheye along with the 10-22 for a totally different look. The fisheye gets it all, and then some:
MCAsan
Joined Jun 2010
Apr 15, 2012 22:12 |  #5
For inside upper Antelope Canyon, a lens that can be sealed with a clear fiber. Otherwise that lens likely has to go to a repair shop to have the sand removed. For a FF body, use a 17-40 or similar.
irishman
Apr 16, 2012 10:07 |  #6
MCAsan wrote in post #14272346 (external link)
McAsan--what does this mean? Maybe I've been lucky, but I've shot there several times and have never had to take a lens to the repair shop. I certainly don't CHANGE lenses once inside.
Argyle--great shot!;)
Numenorean
Apr 16, 2012 10:11 |  #7
On a crop camera, the 17-55 will be much more useful than the 10-22 or 24-70...though the 24-70 would be more useful than the 10-22. Wide is good for some things in antelope, but there are a lot of things you can zoom in for detail shots on as well. You DO NOT change your lens in there. There is basically dust/sand flying around all the time from the guides tossing it up in the air. Pick your lens and stick with it.
Geonerd
Apr 16, 2012 11:44 |  #8
You'll probably want something wider than a 24. That said, last time I was at Lower Jackalope, I got a bunch of nice pics with a Drebel and 28mm Olympus MF lens. Shooting with a fixed focal length is sorta fun!
The kit lens does OK if you stop it down (something you'll probably do anyway, given the DOF requirements.)
Yea, the cliche' Horseshoe shot needs a ~17mm equivalent. Time to rent one of those super-wide zooms.
"Consulting the rules of composition before taking a photograph is like consulting the laws of gravity before going for a walk!" - E. Weston
IShootThings
Apr 16, 2012 17:05 |  #9
Thanks for all the help guys. I think I'm going with renting that Canon 10-22... Anyone know a good place with a decent price on renting?
argyle
Apr 16, 2012 17:19 as a reply to  @ IShootThings's post |  #10
I wouldn't limit myself to an ultrawide only in Upper Antelope...just depends on your compositional goals. I've seen folks in there shooting with a 24-105L to get a different perspective on some of the formations. Two bodies would be ideal...no need to change lenses. But once inside, if limited to a single body, I wouldn't change lenses (and I've never had to have mine cleaned or sent in for repairs). Keep a filter on the lens, and have a blower handy to get the dust off in between shots.
MCAsan
Joined Jun 2010
Apr 16, 2012 21:06 |  #11
Exactly.
IShootThings
Apr 16, 2012 22:45 |  #12
MCAsan wrote in post #14277967 (external link)
Exactly.
Can anyone recommend a good blower/lens cleaning in general? I need to upgrade from the cheap Canon one I bought a few years ago.
Geonerd
Apr 16, 2012 23:38 |  #13
For gritty dust, the best in-field cleaner is none at all. Use a blower to get the easy / coarse stuff and ignore the rest. When you get back to civilization you can very gently clean any dust etc. Wiping and worrying during the shoot will only lead to scratched glass.
What section of Jackalope are you aiming to visit? The lower section can be reasonably dust free if the wind above isn't blowing. (If it is, you'll be subject to an intermittent rain of sand and dust.) Upper has a much higher density of dust-kicking tourons and, if the dumb light beams are going, the guides will be tossing bucketfuls of sand into the air. In this environment, changing lenses on a digital camera is not suggested. I don't suppose you have an old, unloved film body laying about?
Cali_PH
Joined Apr 2012
Apr 16, 2012 23:56 |  #14
msclman99 wrote in post #14278557 (external link)
I saw the Giottos Rocket mentioned by a lot of people, so I bought two (one large for home, one medium for my bag). Been very happy with them, and I found it pretty essential in Antelope, like many people here are saying.
IShootThings
Apr 17, 2012 17:19 |  #15
Geonerd wrote in post #14278818 (external link)
Thanks for the response. If the weather is good, I'm going for upper and lower. I do have an old film body but I'm using it so it isn't unloved. I won't be bringing it on the trip though...
Thanks also Cali.
11,494 views & 0 likes for this thread
version 2.0 /
Latest registered member is Cliodiver
699 guests, 403 members online
