Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 17th of April 2012 (Tue)   #1
calypsob
calypsob's Avatar
Default using an objective lens
I was looking on surplus shed and noticed some microscope objective lens for sale. they are threaded for 1.25" and I suppose they are universal, not to sure on this one. They are so cheap I would buy one but I need to know if there is an EOS adapter to add an objective lens without the microscope itself? Is it even possible to do this? I plan to use a heavy velbon video tripod and a macro focus rail to operate, but after some research I was unable to find an adapter so I thought id ask on here. thanks.
calypsob is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #2
LordV
LordV's Avatar
Default Re: using an objective lens
Think you can get M42 fit cone adapters so you would just need an EOS/M42 adapter too.
This type of thing http://www.ebay.co.uk/itm/RMS-Thread...-/350352400700
I did a DIY version with some old ext tubes and fitted the objective lens to a body cap I put on the end of the ext tubes
Brian v.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #3
calypsob
calypsob's Avatar
Thanks man, glad you came through on this one. How did your pictures turn out with this experiment?
Old 19th of April 2012 (Thu)   #4
LordV
LordV's Avatar
Here's some shots using a 10X objective- all have been focus stacked to give greater DOF.
Brian v.
Rhododendron anther at 10X by Lord V, on Flickr
Bluebell stigma 10x by Lord V, on Flickr
Damp springtail - Entomobrya intermedia #2 by Lord V, on Flickr
Old 19th of April 2012 (Thu)   #5
gmillerf
Here is a similar adapter I have used:
http://www.edmundoptics.com/products...Num=1#products
You'll also need a t-thread adapter for your camera too.
The quality of the objective really matters. I used my 4x and was pretty happy with it, but photos with my 10x were pretty poor. I later changed to using a reverse ring which gave me much better results IMHO and is a much cheaper solution even if you already have the objectives.
gmillerf is offline   Reply With Quote
Old 19th of April 2012 (Thu)   #6
calypsob
calypsob's Avatar
yep after learning that key word "RMS" adapter I found an entire world of super macro photography. Apparently with objective lens the Nikon M-plan series are the way to go because they were designed to attach to a camera and not have chromatic aberration. From what i understand so far. I am going to try some cheap ones off of surplus shed for now until I can fit 150-200 bucks back into my budget.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Why are the objective lens of macro lens so deeply recessed in lens barrel? HoT.Shek Macro Talk 11 14th of September 2011 (Wed) 22:07
OBJECTIVE LENS CARL ZEISS JENA PLANACHROMAT 5 x racketman Macro Talk 9 9th of January 2011 (Sun) 00:51
OBJECTIVE LENS CARL ZEISS JENA PLANACHROMAT 10 x racketman Macro Talk 2 7th of January 2011 (Fri) 10:09
Microscope objective (lens) with Canon EF mount pieq314 Canon EF and EF-S Lenses 29 20th of November 2007 (Tue) 09:57
Can I Use Eclipse On A Lens Objective? canonloader Canon EF and EF-S Lenses 12 21st of June 2007 (Thu) 15:35
