Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Nature & Landscapes Talk
Reply
Thread Tools Display Modes
Old 18th of April 2012 (Wed)   #1
JersFocus
JersFocus's Avatar
Default Will a 15-85mm be wide enough for landscapes?
I am wondering if the 15mm side will do it for mountain landscapes. I have lr 4 and have never done a pano but I guess thats and option as well.
I am not sure buying a UWA is worth it if ill only use it at limited times. I could always get a cheap sigma 10-20 i guess, but wonder if 15 is enough.
Thoughts?
Gear & Feedback
Go Oilers!
JersFocus is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #2
MNUplander
Default Re: Will a 15-85mm be wide enough for landscapes?
Thoughts?
You might get more responses in the Lens section, but I saw it here so Ill take a stab. 15mm is pretty wide on a crop body, roughly equivalent to the 24mm FOV on a FF body. Many find that this FOV is plenty wide for them and never need any more, others are ultra-wide junkies and for them, wider = better.
Plus, not all landscapes have to be wide angle shots either - I think you'll be perfectly happy with just the 15-85 for now. If you find yourself becoming a wide angle junkie then pick up an ultra-wide down the road.
MNUplander is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #3
duane0524
duane0524's Avatar
Thoughts?
I see that you own it, so I would ask you a question. When you are using it for landscapes, do you wish it was wider?
Canon 50D | Canon 10-22 | Canon 24-105 | Sigma 30 1.4 | Canon 70-200 2.8 | Canon 85 1.8 | 580EX ll | ST-E2 | Canon TC 1.4x II | Benro Travel Angel C1682TB0
duane0524 is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #4
highergr0und
It's all relative to how much of the scene you want to photograph and how often it's a problem. Stitching is always a possibility. I really enjoy my Sigma 10-20, but I like to use it for interesting perspectives more than big landscapes.
T3i, Sigma 10-20, Sigma 30 1.4, 18-55 kit, 55-250, YN-565, a few books, some software, and a desire to get good.....
highergr0und is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #5
JersFocus
JersFocus's Avatar
Well i just got it, and havent had a chance to get out with it. I live in a very flat land and want to be sure i take a trip to the mountains this summer.
After some research, by, i am sure pixel peepers the 15-85 may have issues at 15mm. For the price I think I will close out my lens kit with a Tokina 12-24... then i wont be second guessing.
I should stop reading reviews though because i am sure i am in the 97% that isnt affected by the small things.
Gear & Feedback
Go Oilers!
Old 18th of April 2012 (Wed)   #6
ejenner
Wider isn't about how much you want to get in, but about how close you want to get to your foreground. How much space in the frame do you want the flower(s) to take relative to the mountains for instance?
At least that's JMO.
I'm definitely a wide-angle junkie.
__________________________________
5DII, 7D, S95. 10-22, Sigma 15mm FE, TS-E 17, 17-40, 24-105, 70-200 f4 IS, Sigma 85 1.4,100L,135.
http://www.flickr.com/photos/48305795@N03/
ejenner is offline   Reply With Quote
Old 18th of April 2012 (Wed)   #7
smmokan
Yes, the 15-85mm lens is wide enough for a very large majority of landscape images. In fact, it was wide enough (for me) that it allowed me to get rid of the Sigma 10-20mm lens. I haven't looked back, it's an amazing lens that's as sharp as you'll find.
www.SteveMokanPhotography.com
smmokan is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #8
Jim60D
Default New Digital Photo Prof does digital lens optimazation on it (Re: Will a 15-85mm...)
The just released new version of Canon's free Digital Photo Professional will do Digital Lens Optimizing to correct for loss in image quality caused by diffraction or lens aberrations, and sharpens the image to compensate for any loss of resolving power. At present it does this for about 25 Canon lenses and the EF-S 15-85mm is one of them.
Article demonstrating it.
I think you will find it wide enough. On the occasion it is not, that's why I have a tripod with a panning clamp on the head, a $15 Ebay focusing rail, and an L-bracket I made with steel corner braces from Home Depot, some bolts, T-nuts, a hex head bolt handle, and some scrap wood as a nodal rail for single row panoramas. Using DPP's lens corrections also helps the photomerge.
Jim60D is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wide for FF, landscapes. Entu Canon EF and EF-S Lenses 74 27th of October 2010 (Wed) 15:10
Need a Wide Angle for Landscapes JoeTwelvePack Canon EF and EF-S Lenses 31 23rd of September 2005 (Fri) 00:46
Best wide zoom for landscapes wpthedp Canon EF and EF-S Lenses 5 1st of July 2005 (Fri) 18:27
Wide for landscapes Mr. Fogle Canon EOS Digital Cameras 3 7th of March 2003 (Fri) 00:56
