#1 |
I'll be shooting a series of games behind the net. Well not directly behind, but off to the side. I usually shoot events, pj, etc so this is new and failure is not an option.
I wish I could use the various focus points on the 5D II but need to stick to the center point for obvious reasons. I'll shoot a little wide to leave a some room for cropping since the main subject will be in the middle - no time to lock and recompose. How's this sound? Gear: 5D II, Canon 70-200 f/2.8, Canon Grip with 2 batteries (higher FPS) Camera setting - this is where I can use advice: mode: manual shutter speed 1/2000+ 1/3200 minimum? f/2.8 to f/4 - ISO - dunno - low as possible Autofocus - AI SERVO Continuous shooting mode JPG (for faster FPS) I can imagine the shoot will involve 99.99% of inactivity - maybe some crowd shots, punctuated by .01% of furious shooting as the players approach the net. Thanks for the help!
5D II Gripped 50mm f1.8 Mk I~85 f1.8~17-40L~430 exII Last edited by ilikeglass : 19th of April 2012 (Thu) at 11:04. Reason: added details |
| sponsored links |
#2 |
Is this paid work? I only ask because if it is, 70-200, especially on a FF camera, is going to be very limiting. The field is huge.
#3 |
Its tough to shoot soccer with only a 200mm lens on a FF body. Can you rent a converter? As for camera setting. Manual. Unless you have some quickly changing lighting conditions spend some time dialing in the manual exposure so that you dont have to be concerned with a white or black jersey screwing with your metering when you will be all worried about focus.
| sponsored links |
#4 |
Good point - but I'm only going after shots of players at the goal. I was told that 70-200 is good for this purpose. Thanks.
5D II Gripped 50mm f1.8 Mk I~85 f1.8~17-40L~430 exII |
#5 |
Were you told by anyone who had actually shot soccer with a full frame camera? The width of a field is more than you would imagine, and you may go an entire game without a close in shot.
#6 |
I wish I had a 300 for shots inside the penalty area on a 1.3 crop body. Remember you are another 10-15 yards behind the goal line at some stadiums because of the advertising boards and the space in front of them.
#7 | |
I hear what you're saying but I need to get the few key players - close shots at the goal on defensive side. True, I could be SOOL I could rent a a 400mm but the shots probably won't be of use. Any comments on the camera settings/mode? Is 1/2000 enough?
#8 |
1/2000 is crazy overkill.
#9 | |
If you get good exposure on your first few RAW, then shoot .jpg Yup, AF drive should be on AI Servo. Continuous mode, yup. Since you will be near the net, you should have another camera with another short focal length i.e. 24-70mm, though one as wide a possible is good (celebration shots are good)
Bodies: Canon 50D, Canon 5DMKII Lenses: Canon 50mm 1.8, Canon 85mm 1.8 USM, Canon 16-35mm 2.8L USM II Canon 24-70mm 2.8L USM, Canon 70-200mm 2.8L IS USM II Compact: Canon G12 |
#10 |
I forgot to mention that this would be the case if you are shooting in daylight that my advice would be correct, haven't shot with floodlight, though that depends on how well it is lit up
#11 |
Can you post some of your shots from that match you shot from 1/250th to 1/500th?
#12 |
#13 |
I shoot my two sons soccer (U13 and U9) with a 40D and 70-200 f2.8. I find I need 1/1000 or faster. I think you should be ok with that lens if you're sticking to action shots in the goal square.
For the U9 on smaller pitch the 70-200 on a crop is fine. On a full size pitch the lens is way too short. I could really do with 400 mm of reach. |
#14 | |
Take one to three pages back from here and you will see a sample I had good light, and yes it was a Canon 50D.....so what, it shouldn't matter because exposure has nothing to do with the body http://photography-on-the.net/forum/...0#post14300750
#15 |
Not really, are you one of these posters on here that tend to disagree with me all the time no matter what?
| Thread Tools | |
| Display Modes | |
| Major advice needed | L.Morey | Canon EF and EF-S Lenses | 3 | 3rd of January 2009 (Sat) 21:52 |
| Major league/Minor league Baseball | onel0126 | Sports | 2 | 30th of June 2008 (Mon) 18:00 |
| Advice Needed for shooting 6pm soccer game on Wed 10/11 | nickybegood1998 | Sports | 33 | 18th of October 2006 (Wed) 16:57 |
| Night football (soccer) advice needed please | LMP | Sports | 14 | 8th of October 2006 (Sun) 18:51 |
