Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Astronomy and Celestial Talk
Reply
Thread Tools Display Modes
Old 19th of April 2012 (Thu)   #1
lifeofbrian2007
lifeofbrian2007's Avatar
Default Best iso performance in the 550d price range or less?
I am on the verge of getting my first ever DSLR, and i'm pretty sure i've settled on the EOS 550D. The main reason i want it is for night/astro photography, does anyone know if this is the best choice, i hear that its not that great in low light?
Thanks.
lifeofbrian2007 is offline   Reply With Quote
Old 19th of April 2012 (Thu)   #2
canadave
Default Re: Best iso performance in the 550d price range or less?
To be honest, although some bodies may be a bit better than others in low light from a sensor point of view, I think you'll see an even more pronounced difference as a result of your lens choices. For instance, the 60D that I have isn't bad in low light, but with slow lenses, the sensor's low-light quality would be moot anyway. Conversely, if you have good quality fast lenses, that's probably more important than any differences in the various bodies.
My recollection may be faulty on this, but when I was looking at the various cameras and comparing for low-light performance, the differences between them were fairly minor--nothing that made me sit up and go "omg, this is HORRIBLE in low light."
If you think the 550D "isn't that good in low light," go to Google Images and search for "550D astrophotography" and see what kind of pics there are. They look all right to me...
Canon 60D
- EF-S 18-55mm
ƒ3.5-5.6 IS • Tamron AF 70-300mm ƒ4-5.6 SP Di VC USD XLD • Pentax SMC-M 50mm ƒ1.4 (via adapter)
- Kenko Teleplus MC4 DG 2x teleconverter
- Manfrotto 055XPROB • Manfrotto 496RC2
canadave is offline   Reply With Quote
Old 20th of April 2012 (Fri)   #3
cyberon
cyberon's Avatar
I use the 500D and 1100D and they work fine for me. Of course some of the more expensive bodies can give you a little higher ISO performance with less noise but there are ways around this.
500D, Speedlite 430EX II, Lens : 15-85mm; 50mm F1.8 II; 100mm F2.8L IS Macro; 70-200mm F4L; Samyang 8mm F3.5
U/W : G11, OEM Housing, Inon S2000, Inon D4 Tray, Inon UCL-165 Close up lens
Astro : Modded 1100D, ES 80ED, Skywatcher HEQ5 Mount, Astrotrac TT320X-AG, Astronomik CLS Clip in filter
cyberon is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #4
the jimmy
the jimmy's Avatar
Thanks.
I believe your biggest "performance" gain will be in post processing, also your technique, i.e. if you stack, if you have a good mount to track, there are many ways to take astro photo's and good results can be had with nothing but a tripod, all the way thru spending thousands on equipment.
I also agree with previous posts, the 550D will be good, but your choice of lens is more important.
the jimmy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best iso performance in the 550d price range or less? lifeofbrian2007 Canon EOS Digital Cameras 10 20th of April 2012 (Fri) 03:12
5DIII fails to improve low ISO dynamic range performance? k1csi Canon EOS Digital Cameras 41 5th of April 2012 (Thu) 11:29
Tamron 17-50 non-vc performance within the 17-25mm range? HansSteinert Canon EF and EF-S Lenses 10 16th of May 2011 (Mon) 17:15
upgrade from 20D to 550D - AF performance blackcoffee Canon EOS Digital Cameras 23 28th of July 2010 (Wed) 06:52
70-200mm f/4L Non IS best performance range? hramakers Bird Talk 15 3rd of March 2010 (Wed) 05:22
