Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 19th of April 2012 (Thu)   #1
calypsob
calypsob's Avatar
Default reversing troubles
i have a sigma 70-210 uc zoom f/4 for a pentax, and I decided to get an eos mount reversing ring for this lens. It is a macro/tele and I thought it was going to be functional as a good macro but when I reversed it I could only focus about 5 ft. away and thats it, no macro, and when I zoom it seems to go way out of focus , I have no idea what is going on with it. Are telephoto lens supposed to be reversed? What am i doing wrong?
calypsob is offline   Reply With Quote
Old 20th of April 2012 (Fri)   #2
LordV
LordV's Avatar
Default Re: reversing troubles
No tele lenses will not give increased mag if reversed to the camera body. People normally reverse a 50mm or shorter focal length lens.
A reversed 50mm lens gives around 1:1 mag and a reversed 28mm lens gives around 3:1. If you got a kit lens try reversing that.
Brian v.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is online now   Reply With Quote
Old 20th of April 2012 (Fri)   #3
Techuser
Techuser's Avatar
With a telephoto you're better off using close-up filters
Canon XSi | 18-55 IS | 50 1.8 | 70-300 IS | 300 2.8 FD
Techuser is offline   Reply With Quote
Old 23rd of April 2012 (Mon)   #4
gmillerf
You could also use extension tubes to let you focus on things closer using the magnification already in the lens.
gmillerf is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Reversing EF-s 18-55 3.5-5.6 II, Help KarlosDaJackal Canon EF and EF-S Lenses 8 13th of March 2009 (Fri) 10:30
Reversing lenses on each other? Muskydave22 Canon EF and EF-S Lenses 4 9th of March 2009 (Mon) 21:32
Reversing a lens pagnamenta Macro 3 16th of March 2007 (Fri) 01:11
reversing cinci-photo Macro 5 20th of October 2006 (Fri) 23:48
lens reversing smasraum Macro 5 3rd of September 2005 (Sat) 22:30
