Reply
Thread Tools Display Modes
Old 2nd of December 2005 (Fri)   #1
jamil
Default 100-400mm L lens
Hi m8s i have just bought 100-400mm L lens which is second hand and no box or instructions with it.Could someone please tell me what the stabilizer mode 1 and 2 does and also stabilizer 1 and 0.There is also another setting with 1.8m and 6.5m.Thanks in advance.
jamil is offline   Reply With Quote
Old 2nd of December 2005 (Fri)   #2
nitsch
Default Re: 100-400mm L lens
Welcome to the forums!
Stabilizer mode 1 is "normal" mode, which provides both vertical and horizontal stabilization. Mode 2 is "panning" mode which you would use if you were tracking a moving subject.
The I and the O are the on and off switch for the stabilizer. You will want to switch it off if you are using the lens on a tripod for example. I = ON, O = OFF.
The other switch is the focus range switch. When set to 1.8m the lens will focus throughout it's entire range. When set to 6.5m the lens will only focus on subjects more than 6.5m away, but will hunt less and (in theory at least) be able to focus a bit quicker.
Hope this helps. Enjoy the new lens, share some of your shots sometime.
nitsch is offline   Reply With Quote
Old 2nd of December 2005 (Fri)   #3
jamil
Thanks very much nitsch.
Old 2nd of December 2005 (Fri)   #4
lomond
lomond's Avatar
Welcome to the forum.
1-0 Simply means on - off. 1 is on 0 is off.
The difference between 1 & 2 is ...1 can be used for general shooting and 2 for panning.
The 1.8 and 6.5 is the distance scale for speed of focus.
If the subject is further than 6.5 mtrs then use that setting.
Cameron........My Images
lomond is offline   Reply With Quote
Old 2nd of December 2005 (Fri)   #5
lomond
lomond's Avatar
Oops too late.
Old 2nd of December 2005 (Fri)   #6
jamil
Thanks lomond
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1.4x and 2x extenders w/ 100-400mm lens? pitabread Canon EF and EF-S Lenses 26 24th of August 2006 (Thu) 09:43
Canon EF 100-400mm f/4.5-5.6L IS Lens neil.robinson Canon EF and EF-S Lenses 9 12th of January 2006 (Thu) 15:39
Canon - 100-400mm f/4.5-5.6L EF IS Lens shannonb Canon EF and EF-S Lenses 25 16th of October 2005 (Sun) 17:30
Please recommend a 100-300L or 100-400mm L lens Kirik Canon EF and EF-S Lenses 18 20th of October 2004 (Wed) 14:25
telextender with 100-400mm L lens frederica Canon EF and EF-S Lenses 6 25th of June 2003 (Wed) 19:40
