Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 20th of April 2012 (Fri)   #1
Shoayb Hesham
Default 18-200mm or 50mm
i have 18-200mm and 50mm 1.8 , just wanted to know which is better for cars photography
will the 18-200 at 200mm f/5.6 give me more dof than the 50mm at f/1.8 ?
thanks
Shoayb Hesham is offline   Reply With Quote
Old 20th of April 2012 (Fri)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Re: 18-200mm or 50mm
Both will work.
Yes, generally. DOF Field tables.
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 20th of April 2012 (Fri)   #3
DC Fan
DC Fan's Avatar
Actual car pictures from a real Canon 18-200mm image stabilizer lens.
Focal Length: 18.0mm
Aperture: f/3.5
Exposure Time: 0.025 s (1/40)
ISO equiv: 1000
Exposure Bias: none
Metering Mode: Matrix
Exposure: program (Auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Aperture: f/3.5
Exposure Time: 0.033 s (1/30)
ISO equiv: 400
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Aperture: f/3.5
ISO equiv: 100
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
When used at car shows indoors and outdoors, the Canon 18-200mm image stabilizer lens has always easily handled the job of rendering images with no shortcomings. These images were generated with a Canon 60D, framed through the camera's articulating screen, using Live View. All of the effort in creating these images went into framing the shots. The camera handed everything else.
DC Fan is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #4
Shoayb Hesham
thank you guys for your help
Old 21st of April 2012 (Sat)   #5
z0diac
thanks
Depends on how far away your background is. The 18-200 gives nice subject isolation if the background is far away, especially when you're farther away from the subject and zoomed in a bit on it (with the background far away), the 50mm 1.8 really isolate the focus point down very narrow. That 18-200 is such a versatile lens.
Canon T2i / 70-200 2.8 IS II / 10-22mm / 50mm 1.8 / 18-200mm / 18-55mm / 55-250mm / 1.4x extender / filters / tripod / monopod / lightning trigger / Nikon Coolpix P90
z0diac is offline   Reply With Quote
Old 24th of April 2012 (Tue)   #6
Ando27
Ando27's Avatar
18-200 is a really underrated lens, especially at F7.1 or F8.
Use the long end & stand back you can isolate the background 7 compress it forward while cutting out any extras on the sdies..
Check my smugmug out. all my hotrod shots taken with my 18-200...
Al
Ando.
"Down Under"
Canon 1Div / 7D gripped / 50D gripped / 300f2.8 IS L / 100-400f5.6 L / 70-200f2.8 IS II L / 18-200IS / 24-105 f4 IS / 10-20 f4 / 580EXII /1.4 TC III / 2 TC III / DIY 15' Rig
www.AAA-Photography.smugmug.com
Ando27 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: 50mm 1.4 EF, 70-200mm F4 (non-is) circusofcrows Classifieds: Buy 1 15th of November 2010 (Mon) 05:36
50mm/1.8 mk1 and 50-200mm/3.5-4.5 mix_ts Canon EF and EF-S Lenses 11 4th of January 2010 (Mon) 22:41
WTB 200mm 2.8L , 50mm 1.8 , 2x ext. wally0206 Classifieds: Buy 0 14th of April 2008 (Mon) 09:33
