Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Astronomy and Celestial Talk
Reply
Thread Tools Display Modes
Old 21st of April 2012 (Sat)   #1
Maverick530
Default what am i doing wrong.
Hey everyone im new
Im a Film Major but like photography, and the other day i was taking pictures of the sky though i think im doing it wrong, My pictures never come out very good and clear.
my settings are normally f22-f15 with iso set at like 1500 and a 30 second exposure. im using a 60D with the kit lens (im kind of Poor)
should i use that or a 50mm 1.8 (i do have one of those)
and also something about merging layers on photoshop, is that what people do?
Ps. i dont think i can send PMs just yet so im trying to get my post count up, im trying to buy a flash on here.
Maverick530 is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #2
Tiberius
Default Re: what am i doing wrong.
What problem exactly are you having? It's probably best if you post examples. But I'd suggest you start with a lower ISO and a wider aperture. f11 or f16 should be the highest you should go in general shooting.
My Tutorials
PhotoNotes
Tiberius is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #3
Maverick530
well, the pictures are just grainy, and the sky looks like it isnt black, it looks brownish
Old 21st of April 2012 (Sat)   #4
gewb
gewb's Avatar
Your profile doesn't say where you live. You need a dark sky area for long exposures. See this post and check the links:
http://photography-on-the.net/forum/....php?t=1168924
Regards,
GEWB
60D / Pro1 / A85
gewb is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #5
Gojira1976
User is banned from forums
Whatever the situation is, just keep on shooting! I would follow my own advice to, but alas, I can't, so as they say over exposure is better than under exposure, or your photos will end up like these
also have you tried manual mode?
_DSC2042 by Americo.Rodriguez., on Flickr
_DSC2059 by Americo.Rodriguez., on Flickr
Gojira1976 is offline   Reply With Quote
Old 21st of April 2012 (Sat)   #6
Maverick530
Yeah I'm shooting in M mode, sorry I haven't updated my profile yet, just busy lately
Old 22nd of April 2012 (Sun)   #7
cyberon
cyberon's Avatar
Maverick530, start by reading this thoroughly http://photography-on-the.net/forum/...d.php?t=766644
If you are attempting to take the night sky, start by using your widest aperture and widest focal length, ie at 18mm.
30 seconds will be a little bit long for untrack image at 18mm, so reduce your shutter speed to around 20s. ISO up to 1600 should be fine to get you started but remember to use live view at 10x to focus accurately.
500D, Speedlite 430EX II, Lens : 15-85mm; 50mm F1.8 II; 100mm F2.8L IS Macro; 70-200mm F4L; Samyang 8mm F3.5
U/W : G11, OEM Housing, Inon S2000, Inon D4 Tray, Inon UCL-165 Close up lens
Astro : Modded 1100D, ES 80ED, Skywatcher HEQ5 Mount, Astrotrac TT320X-AG, Astronomik CLS Clip in filter
cyberon is offline   Reply With Quote
Old 22nd of April 2012 (Sun)   #8
canadave
You don't need to fill it out completely, but at least your location would be helpful. Takes literally 10 seconds to do....
Canon 60D
- EF-S 18-55mm
ƒ3.5-5.6 IS • Tamron AF 70-300mm ƒ4-5.6 SP Di VC USD XLD • Pentax SMC-M 50mm ƒ1.4 (via adapter)
- Kenko Teleplus MC4 DG 2x teleconverter
- Manfrotto 055XPROB • Manfrotto 496RC2
canadave is offline   Reply With Quote
Old 22nd of April 2012 (Sun)   #9
z0diac
As what Tiberius said.. I would open my aperture up a bit and lower the ISO. Raising the ISO is always my last resort, unless I want a large DOF and have to stop it down.
But this will help ESPECIALLY on long exposures. Higher ISO = grainier pictures, and those grains really show up more on long exposures.
Canon T2i / 70-200 2.8 IS II / 10-22mm / 50mm 1.8 / 18-200mm / 18-55mm / 55-250mm / 1.4x extender / filters / tripod / monopod / lightning trigger / Nikon Coolpix P90
z0diac is offline   Reply With Quote
Old 23rd of April 2012 (Mon)   #10
cyberon
cyberon's Avatar
Generally when shooting the night sky, DOF plays very little in the equation as you are focusing on a distant object.
ISO up to 1600 is generally fine for such images, the 60D can handle that! Remember that you are shooting an untracked image so already limited by your shutter speed to prevent trailing. Therefore any bit that helps in increasing exposure is good like ISO (up to a point) and aperture.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What's wrong with my Flickr or what am I doing wrong? LowriderS10 General Photography Talk 10 14th of December 2010 (Tue) 14:34
Wrong EXIF or something is wrong with the lens? alpha_1976 Canon EF and EF-S Lenses 15 12th of November 2010 (Fri) 07:21
Wrong Lens, Wrong Settings, Bad Timing ScootersDaddy General Photography Talk 21 23rd of June 2009 (Tue) 20:33
white balance - is it wrong to want to be wrong? artyboy RAW, Post Processing and Printing 10 17th of May 2008 (Sat) 09:47
YMCA Indoor Volleyball - wrong lens or maybe my settings are wrong? laurielozano Sports 17 7th of May 2007 (Mon) 15:25
