Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Nature & Landscapes Talk
Reply
Thread Tools Display Modes
Old 23rd of April 2012 (Mon)   #1
Tweet
Tweet's Avatar
Default ND filter
I am new to filters. I kinda want a shing ray vari-n-duo. What do you guys think?
Paul Tweten | 5DmkII | 24-70mm 2.8L | 70-200mm 2.8L | 100mm 2.8 Macro | 50mm 1.8 II | Paul C. Buff stuff | G10
Tweet is offline   Reply With Quote
Old 23rd of April 2012 (Mon)   #2
argyle
argyle's Avatar
Default Re: ND filter
I use it. I like it. Get it (but get the thin version).
argyle is offline   Reply With Quote
Old 23rd of April 2012 (Mon)   #3
Harpo63
Harpo63's Avatar
If you're gonna get into filters, doing it by going top of the line right away and learning how to use it makes more sense than buying cheap then realizing you should have gone for better quality. The vari-duo is on my "next-to-buy list".
5D3 / 24-105 f/4L / 70-300mm f/4-5.6L / 50mm f/1.4 / 600EX-RT
Harpo63 is offline   Reply With Quote
Old 23rd of April 2012 (Mon)   #4
bps
The Singh-Ray Vari-Duo ND filter is excellent. It would be a fantastic purchase for a ND filter!
Bryan
My Gear List
bps is offline   Reply With Quote
Old 23rd of April 2012 (Mon)   #5
Tweet
Tweet's Avatar
How about the Tiffen ND... A little less expensive http://www.bhphotovideo.com/c/produc...l_Density.html
Old 23rd of April 2012 (Mon)   #6
argyle
argyle's Avatar
You're comparing apples to oranges...the S-R Vari-N-Duo includes an integral warming polarizer, the Tiffen does not. Tiffen is towards the lower end of the spectrum when it comes to filters...
Old 23rd of April 2012 (Mon)   #7
Tweet
Tweet's Avatar
Oh... I see. Well I don't want to sacrifice sharpness. Does Singh Ray make just a variable ND?
Old 24th of April 2012 (Tue)   #8
argyle
argyle's Avatar
Yes...its called the "Vari ND"...check their website for more info.
Old 24th of April 2012 (Tue)   #9
Tweet
Tweet's Avatar
Wow... that is extremely expensive. Ok. Thank you for your help so far. I am the type of person who needs everthing laid out. So other than the
Tiffen vairable nd
Fader brand ND
and the Singh Ray Vari ND
Are there any more options?
Old 24th of April 2012 (Tue)   #10
Tweet
Tweet's Avatar
I did a B&H search and narrowed down all the 77mm Variable ND filters. Here is the results: http://www.bhphotovideo.com/c/search...424+4294955264
Old 26th of April 2012 (Thu)   #11
MingTyhMaa
Has anyone regretted buying the 77mm filter size bc it causes a hard vignette at 17mm?
Consider a larger one with a stepup filter to future proof it?
Panasonic G5
P7-14, P12-35 f2.8, P45 macro, P35-100 f2.8, P100-300
Canon 60D + Tokina 100mm macro
MingTyhMaa is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anyplace that sells filter rings? (filter w/o actual filter in it) JonathanSQ Accessories & Storage 1 18th of August 2005 (Thu) 17:29
