| sponsored links |
Thread Tools | Display Modes |
#1 |
So I have about a $1,200 dollar budget to get whatever I need for some serious product photography. I have done it before, but I used a 24x24in light tent with 3 continuous lights.
My ideal set-up would be a strobe on either side of the product, a continuous light boomed over top, and another continuous light from behind through some type of modifier. I already have a White Lightening x1600 and I'm trying to justify buying another strobe so that I can use two strobes, and two continuous lights. Assuming that I get color corrected bulbs that are the same as the flash-tubes inside my strobes (5,600 kelvins ?), could I use both types of lighting for product photography? I will be using some type of white paper for a continuous background, some white reflector sheets, and IDEALY (2) White Lightening strobes with either an attached reflector or a softbox, and (2) continuous lights with some sort of diffuser. Let me know if this sounds do-able!? Thanks! |
| sponsored links |
#2 | |
Master Flasher
You would need a really slow shutter speed to allow a very powerful continuous light to compete with even a weak flash unit. So, since you'll be using a tripod anyway, you may as well use continuous lighting all around.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#3 | |
Any recommendations on what continuous light to get? I was looking at this: http://www.bhphotovideo.com/c/produc..._Kit_with.html with some Impact/Paul C Buff stands. Any cheaper options that would be equal to the power from these? (NOT into homemade stuff - The company I'll be working with will be purchasing the equipment and they want good quality.) |
| sponsored links |
#4 |
Or does anyone have any helpful links that show what I can buy to make my life a little easier when it comes to product photography?
Lighting, modifiers, stands, what kind of paper, etc...? |
#5 |
Master Flasher
Really, three of these will light up your 24" light tent:
http://www.homedepot.com/buy/lightin...ght-52188.html Use incandescent (tungsten) bulbs. CFLs produce less heat, but their output spectrum sucks.
#6 | |
#7 |
Master Flasher
Ok let's back up and switch gears.
Something like this would work. http://www.cowboystudio.com/product_...esskitcase.htm
#8 |
Lights and modifiers I choose depend on what I'm shooting.
You are saying product photography but that is a meaningless term. The smallest product I've photographed was an ear ring. The largest was a farm implement that was 20 feet long and 8 feet wide. Then there are surface reflectivity considerations. 12x18x6 is a size that can be easily lit with either the lights Curtis suggests. But the modifiers etc. will be the key. Give us a hint.
David | digifotografi tutorials | dmwfotos website | testing & techniques blog Canon ETTL trigger sets for sale | Canon 300mm F4 IS L for sale |
#9 |
I do a supermarket project a few times a year, on-location for their on-line business. Lots of items of all different shapes/sizes/reflectivity etc. Compounding the issue for me is the fact that it's in a different state and I need to pack and transport 'the studio'.
I came up with a relatively simple set that works well for the job that consists of a medium Chimera bank light on a boom arm overhead, and 2 24X36 shoot-through panels that I position on the table s necessary. I also shoot on a plexi surface both to avoid the need for constant paper changing (it's food and not always dry) as well as the soft reflection it produces....but seamless would work as well. I made the panel frames and attached Roscolux diffusion material but I'd imagine there are pre-made alternatives. The thing that i like about this particular set up is it's flexibility. I can easily reposition the panels, and as easily move strobe heads closer or further away as I want or as required. For this particular job, we move quickly and the ability to make fast changes to the light is a big plus. It's not the most sophisticated lighting set up in the world, but it works.
My answer for most photography questions: "it depends...' |
#10 |
Depending on what type of product you are shooting, and how big or small your work area is, you can use something as simple as one or two flash with diffusers on them. Lighting doesn't have to be expensive, and it doesn't have to be tricky, most of the time the simplest things work the best.
How big are the products you're shooting, and how big is your work area??
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill My Gear - Flickr - Facebook Smoke Photography - Sound-Activated Paint |
#11 | |
Moderator
Browning .22 - A simple set-up using 1 light. Browning .22 - 3 light set-up Knife lighting problem Guess the lighting & see how close you can come to the set-up used.
FrankC - 20D, RAW, Manual everything... Classic Carz, Racing, Air Show, Flowers. www.FrankCizek.com Find the light... A few Car Lighting Tips, and MOVE YOUR FEET! Have you thought about making your own book? // Need an exposure crutch? |
| Thread Tools | |
| Display Modes | |
| Continuous Lighting good for product shots?? | drocpsu | Small Flash and Studio Lighting | 20 | 20th of December 2011 (Tue) 09:24 |
| Flash/STrobes vs Continuous Lighting | gdusek84 | Small Flash and Studio Lighting | 10 | 2nd of October 2008 (Thu) 22:20 |
| Mixing Strobe and Continuous Lighting | Hivoltage | Small Flash and Studio Lighting | 11 | 14th of January 2008 (Mon) 14:13 |
| Mixing Continous Lighting and Strobes... | Maui Kim | Small Flash and Studio Lighting | 3 | 29th of November 2007 (Thu) 14:11 |
| Lighting for product photography | leedslad | Small Flash and Studio Lighting | 16 | 3rd of July 2007 (Tue) 13:15 |
