Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Performing Arts Talk
Reply
Thread Tools Display Modes
Old 27th of April 2012 (Fri)   #1
RichSoansPhotos
RichSoansPhotos's Avatar
Default What would you do?
If you had three accreditation/photo passes for the same night?
Would you weigh up the possibility of something coming out of one i.e. a deal with the band on the basis you might or might not tour with them?
I am stuck in this quandary where I have got myself three photo passes, obviously can only be at one place at a time, unless I was like Superman.
One is of a musician whose music I don't particularly like, the other two is musician/band I've never heard of.
Bodies: Canon 50D, Canon 5DMKII
Lenses: Canon 50mm 1.8, Canon 85mm 1.8 USM,
Canon 16-35mm 2.8L USM II Canon 24-70mm 2.8L USM, Canon 70-200mm 2.8L IS USM II
Compact: Canon G12
RichSoansPhotos is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
