Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 27th of April 2012 (Fri)   #1
Fenway
Default Is the 18-135 kit lens a Macro?
I was very fortunate to receive a 60D with an 18-135 kit lens. The lens is marked Macro 0.45m/1.5ft. I am curious to know if this lens will give acceptable results before looking into purchasing a dedicated Macro lens.
WayneW.
Fenway is offline   Reply With Quote
Old 28th of April 2012 (Sat)   #2
Larry Weinman
Default Re: Is the 18-135 kit lens a Macro?
This lens will get you close enough to photograph something about five inches wide and fill the frame but it is not a macro.
A macro lens used by itself will allow you to fill your frame with something about one and a half inches wide. Specialty lenses like the MPE-65 will allow you to fill your frame with objects much smaller then this. This is a very very basic explanation. All lens makers misuse the term macro on their lenses.
7D 50D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm 1.4 TC 2X TC 580EX 430 EX II MT 24 EX
Larry Weinman is offline   Reply With Quote
Old 28th of April 2012 (Sat)   #3
Fenway
Larry, thank you. My thought was that it being a BASIC kit lens it would allow you sample different aspects of photography but not suit that particular need.
Old 30th of April 2012 (Mon)   #4
HoT.Shek
HoT.Shek's Avatar
This lens gives you around 0.2x magnification, so, not really a macro.
350D (IR) 400D 5Dc 1Ds
Canon 50, 85mm F/1.8 │ 135L
Sigma 28mm F/1.8 │ 12-24mm popeye
Tamron 17-35mm F/2.8-4 │ 60mm F/2 Macro
HoT.Shek is offline   Reply With Quote
Old 30th of April 2012 (Mon)   #5
Preeb
Preeb's Avatar
Actually a true macro will give you an image which is life size on the sensor. For something which is 1.5 inches long, you would get less than half of it in the frame of a 1.6 crop body at closest focus. Any lens that gets less than 1:1 may get good close-ups, but it isn't really macro, no matter what the manufacturer may try to say. Closest focus on my 70-200 is 1.2 meters (about 4 feet), and it gets great close-ups, but they aren't macro.
The EF-S 60mm f2.8, the EF 100 and EF 100 L are all true macro lenses.
Rick
60D - EF-S 10-22 f3.5-f4.5 -- EF-S 17-55 f2.8 IS -- EF-S 60mm f2.8 Macro -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
Preeb is offline   Reply With Quote
Old 1st of May 2012 (Tue)   #6
gmillerf
Before jumping in an buying a macro lens, you should try a reverse ring, they're usually less than $10. Even though they're a bit cumbersome to use, you can get really good results without jumping all in.
gmillerf is offline   Reply With Quote
Old 3rd of May 2012 (Thu)   #7
tonylong
....winded
tonylong's Avatar
Heh! That's an approach, as long as you have a second lens!
But when I bought my first DSLR I already knew that I wanted to shoot Macros and so I just bought the 100 f/2.8 Macro -- it's now the "old" version but I still happily shoot with it!
Tony
Tony Long Photos on PBase
Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here
tonylong is offline   Reply With Quote
Old 3rd of May 2012 (Thu)   #8
gmillerf
You don't need a second lens to use a reverse ring.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Macro: dedicated Macro 100mm lens vs 70-300 macro lenses?? nekrosoft13 Canon EF and EF-S Lenses 4 16th of June 2010 (Wed) 18:40
Macro shots using Tilt lens - Please share your experience <Moved from Macro Photos> roli_bark Macro Talk 4 3rd of August 2009 (Mon) 07:10
Macro Lens without Macro, Help! (Tamron AF 75-300mm f/4.0-5.6 LD Macro Autofocus) janapriya Canon EF and EF-S Lenses 6 21st of May 2007 (Mon) 22:47
