#1 |
Howdy all
I still consider myself a noob as I've only been doing motorsports photography about 9 months, a question has been bothering me for a while, but I keep forgetting to ask, so here it is lol On a standard trackdays shoot, I tend to vary between ISO100 and 400 depending on the light, but do I need to? If my camera settings are capable of shooting in Tv with the shutter im using without maxing out the aperture, do I have to bump up the ISO? I usually move upto 200 for cloudy weather and 400 when it's getting abit darker, but if I stay at iso100 when it's cloudy, am I loosing detail? Camera gear is mostly my 550d + EF70-200mm F4L Thanks Ste
My 500px | 60D (Gripped) | 550D (Gripped) | EF70-200mm ƒ4L | Sigma 30mm ƒ/1.4 | Tamron 17-50mm ƒ/2.8 | Speedlite 560II | |
| sponsored links |
#2 |
human (barely) and bribable
The difference between ISO100 and ISO400 is so negligible that I would not worry. Set the ISO to whatever you need to get the shot. Low ISO, longer shutter speed if you want some motion blur. Higher ISO, short shutter speed if you want to freeze motion.
Not sure why, but call me JJ. Today is only yesterday's tomorrow. ::Flickr:: ::Gear:: |
#3 | |
The way you asked the question suggests that you feel you should be shooting at the higher ISOs for quality. The rule of thumb has always been to shoot at the lowest ISO you can that gives you the aperture you want for depth of field and a fast enough shutter speed. You normally only raise ISO when you need to do so, in order to obtain the settings you want with aperture and shutter speed. |
| sponsored links |
#4 |
Ok cool
Cheers guys I normally use the lowest ISO I can but when I was first learning to use a camera I was told to change the iso depending on weather. Was only unsure of whether I'd be losing quality is all, aperture wise, I only mainly side pan so the shallow DOF usually goes in my favour with a wider aperture, I've just learnt how to use a historgram correctly so I can shoot In manual as Tv with various metering modes let me down last weekend. Cheers again
#5 |
Stu i'm normally using the lowest ISO possible and even that is too bright for the shutter speeds im using. The only time i usually change the ISO is if i go indoors.
1D MK IV, 5D MKII, G11, 70-200mm f2.8 MK II L, 24-70mm f2.8 L, 580 EXII Drifted.com |
#6 |
Playing with fire
I shoot racing in very varied conditions (in late fall/winter we have only a few hours of daylight), so my ISO is all over the place. I always use the lowest ISO possible to get the shutter speeds I need, but if I have to go higher, I will do so without hesitation.
7D, some lenses and a box of kittens (also known as "The Gallery"). Woof. |
#7 |
Once I set my shutter speed, I typically set my ISO to allow me to have the aperture in the 8-10 range
#8 |
I'm getting more into motorsport and panning shots and I find typically 1/125-160,f8(ish) ISO 100 usually works to get wheel blur ( and frequently motion blur-but that's invariably my fault!)
Chris Canon 5D Mk2,Canon 7D, Canon 24-105L F4 IS,Canon 580 EX,.Canon 70-200 F4 L IS , Canon 100-400L IS, Canon 17-40L,Canon 60mm Macro,Canon 24mm TS-E Mk1 ,G12 |
#9 |
Location: Sittin on the beach, drinking rocket fuels - Oh yeah
Is there such thing as 'too low' an ISO?
Yep. It's when you can't get a fast enough shutter speed to get the shot you want when you're using the maximum aperture of the lens you're using.
Regards, Phil 2011/12 CAMS Gold Accredited Photographer | 2010 & 2011 V8 Supercars Aust. Accredited Photographer | 2008, '09, '10 South Aus. Rally Photographer of the Year | Catch Fence Photos - 2009 Photo of the Year "A bad day at the race track is better than a good day in the office" | www.freewebs.com/philwillmedia |
| Thread Tools | |
| Display Modes | |
| There really IS such a thing... | jgrussell | Birds | 13 | 15th of October 2010 (Fri) 18:26 |
| It's an Ant Thing II | orionmystery | Macro | 11 | 23rd of February 2010 (Tue) 22:32 |
| Thing One and Thing Two: Crane Barges. | AeroSmith | Urban Life & Travel | 2 | 24th of May 2007 (Thu) 12:12 |
| Green thing and a red thing | seanreed | Wildlife | 4 | 15th of January 2007 (Mon) 11:30 |
| San Francisco: A good thing and a bad thing | ayotnoms | Urban Life & Travel | 12 | 21st of June 2005 (Tue) 10:42 |
