Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 2nd of May 2012 (Wed)   #1
Adbailey121
Default Best trigger for EOS Speedlights
Hi,
looking at purchasing a trigger for my 430 ex ii without having to buy another flash and using it off camera.
Not too expensive would be best as i don't need a trigger to control more than two or three flashes at the same time.
Cheers
5d Mk II, Sigma 50 1.4, Canon 70 - 200L 2.8 USM, 430 ex II speedlite
Adbailey121 is offline   Reply With Quote
Old 2nd of May 2012 (Wed)   #2
chugger93
chugger93's Avatar
Default Re: Best trigger for EOS Speedlights
I use the yongnuo 603, purchased them months ago and haven't looked back. Although I don't think they work with ETTL capabilities, but cheap and effective!
Jon | jmbphotography |
5D MK II --- 24L II | 50L | 135L | Canon 85 F/1.8 | 430 EX II/Yongnou 560 Speedlites | Manfrotto 055XPROB Pro Tripod
chugger93 is offline   Reply With Quote
Old 2nd of May 2012 (Wed)   #3
dmward
RF 603s, as with most triggers are fire pulse only. Pixel HK, Odin, ControlTL, Radio Poppers are the only ones I know of that do ETTL but they are significantly more expensive.
dmward is offline   Reply With Quote
Old 2nd of May 2012 (Wed)   #4
SJRobbins
SJRobbins's Avatar
If you want ETTL, don't mind "line of sight" based (i.e. not RF, they don't actually need direct line of site), then the Yongnuo ST-E2 might be an option: https://thephotogadget.com/en/conten...rigger-canon-0 An RF based ETTL trigger pair will cost you more than another flash.
None ETTL RF options: Yongnuo 603s (although you will lose some sync speed), or the Cactus V5.
Canon 60D | Tamron 17-50mm f2.8 nonVC | Canon EF-S 60mm f2.8 Macro | Canon EF-S 55-250mm f4-5.6 IS | Canon 50mm f1.8 MkI | Carl Zeiss Jena DDR 135mm f3.5 | Loads of flashes 'n' stuff
flickr
SJRobbins is offline   Reply With Quote
Old 2nd of May 2012 (Wed)   #5
amirg
amirg's Avatar
If you don't need radio ETTL, I wholeheartedly recommend Phottix Strato II Multi. It has great build quality, allows grouping of remote flashes and has E-TTL pass-through on the transmit unit so you can still use an on-camera E-TTL flash for fill while using the remotes in manual. A transmitter/receiver set costs around $100. Bonus is that the receivers are also compatible with their newer Phottix Odin transmitter in manual mode.
Ottawa Wedding Photographer
amirg is offline   Reply With Quote
Old 2nd of May 2012 (Wed)   #6
amirg
amirg's Avatar
Oh and it uses AAA batteries which is a bonus. Here's the product info. page:
http://www.phottix.com/en/studio-acc...h-trigger.html
Old 2nd of May 2012 (Wed)   #7
HiepBuiPhotography
I use the Cactus V5s that I got from MPEX. They've served me well. They're non-ETTL though.
Hiep Bui Photography | Harrisburg Wedding Photographer
HiepBuiPhotography is offline   Reply With Quote
Old 2nd of May 2012 (Wed)   #8
SJRobbins
SJRobbins's Avatar
Interesting, I didn't know they were compatible with the Odin, I've never paid them much attention to be honest. I was always put off the Yongnuos because of the sync speed issues (and lack of locking), and put off the Cactus V5 because of the lack of flash wake up, but those Phottix ones seem to be pretty good from the spec list.
Can you get a clean 1/250 with them?
Edit: scratch that, they're not transceivers .. damn.. I thought they ticked all the boxes
flickr
Old 2nd of May 2012 (Wed)   #9
amirg
amirg's Avatar
Lol, you are asking for too much I guess. I get a clean 1/250 out of them on crop, need to try on my new 5D3 as well but they are one of the faster triggers out there. Much better than YongNuo for sure. They also can act as remote shutter release as well. Another bonus is that they come in the box with all kind of different connectors/adapters needed to connect to PC jack and/or strobes.
Old 2nd of May 2012 (Wed)   #10
SJRobbins
SJRobbins's Avatar
Yeah, I still haven't bought any RF triggers; partly because I haven't had a need, and partly because I want the moon on a stick
The Yongnuo sync issue appears to just be with Canons, which is irritating. I'm probably still leaning towards the Cactus to be honest, the wake up thing isn't that big of a deal for me. I prefer the idea of transceivers, they just make more sense if one goes down for some reason, or god forbid you leave the transmitter at home, you're not stuck.
flickr
Old 3rd of May 2012 (Thu)   #11
Adbailey121
Thanks for all of the input the PHOTTIX STRATO II MULTI 5-IN-1 sounds pretty much like what i am looking for
Thanks again.
Old 3rd of May 2012 (Thu)   #12
amirg
amirg's Avatar
Thanks again.
Good choice, these are very reliable with lots of features. The best of the manual triggers out there IMO.
Old 4th of May 2012 (Fri)   #13
SJRobbins
SJRobbins's Avatar
I'm leaning towards the Ojecoco ones now, feature wise they seem to tick all the boxes (including "hypersync"), and they're cheap-tastic.
http://dpanswers.com/roztr/content_show.php?id=347
flickr
Old 7th of May 2012 (Mon)   #14
iLvision
User is banned from forums
Best trigger system for Canon? Phottix Odins of course!
As I wrote a review on Amazon, I cannot stress enough how great Phottix Odin system is. It's simply the best out there. What's been said is true and all I have to say is that there is no better solution in terms of reliability and versality.
I can control all of my flashes straight from my transceiver. I can control 3 groups of flashes (in my case, it's three flashes) and set them to anywhere I want. I can leave two flashes for E-TTL and my third flash set to manual, etc
No more running around back and fourth trying to adjust the power or trying to turn off the flash. I can simply do everything straight on my camera. The range is also incredible!
Basically, It's like having PW Flex & mini, AC3 and PW Plus III all into one unit... and more!
Buy these things, you will not regret. Forget about PocketWizards.
iLvision is offline   Reply With Quote
Old 7th of May 2012 (Mon)   #15
amirg
amirg's Avatar
I agree. The only other feature I wish they had is TTL-passthrough.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Use Sekonic to trigger TT1 to trigger Skyport transmitter texshooter Small Flash and Studio Lighting 5 22nd of July 2009 (Wed) 04:45
Will the Interfit IR trigger work with speedlights? Mark1 Accessories & Storage 0 9th of August 2008 (Sat) 21:51
Can Rebel XT trigger Infinity Gadget wireless trigger? dr_who Small Flash and Studio Lighting 5 3rd of January 2008 (Thu) 17:14
How do I trigger 580 speedlights by light meter? 580's have no sync cord outlet. maclap Small Flash and Studio Lighting 17 11th of November 2005 (Fri) 01:53
