#1 |
I recently took a trip to the Minnesota Zoo and snapped some shots. A lot of them I had to shoot through glass panels and the images turned out blue and fuzzy. I was able to correct it to a certain acceptable level in photoshop cs5, but does anyone have any suggestions as to how they approach this. Below is an example of what I was able to do, is there more I can do, or is this the best I can get it?
Before [IMG] [/IMG]After [IMG] [/IMG]
It's never gonna be a perfect picture to everyone...but I'm okay with that. Canon T3i 18-55mm, 55-250mm |
| sponsored links |
#2 |
I have been to the Minnesota Zoo and allot of their glass panels are scratched up or full of handprints, nothing can be done about that. If however you are shooting through a clean panel the main problem is glare and reflections on the panel and this will rob you of contrast. A polarizer will help quite a bit with that but keep in mind you will lose two stops of light with a polarizer.
7D 50D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm 1.4 TC 2X TC 580EX 430 EX II MT 24 EX |
#3 |
Also, you'll want to get your lens right up against the glass, if possible - of course, this limits your framing and composition a little bit. You may also want to try bracketing your shots and combining them with a little HDR.
But yeah, most zoos use a glass polymer that's stronger, but also susceptible to scuffs, scratches, and handprints.
- Chim Canon 5D Mark II; EF 16-35mm f/2.8L; EF 100mm f/2.8L IS Macro; EF 70-200mm f/4L IS Sony NEX 5N; E 16mm f/2.8; E 30mm Macro f/3.5; E 18-55 f/3.5-5.6; Ultra Wide Converter x0.75; Fisheye Converter; Nauticam NA-NEX5N Underwater Housing |
| sponsored links |
#4 |
I read about getting your lens right up against the glass when shooting, and that helped a lot especially with reflections. Does the before and after look acceptable for a portfolio?
#5 |
I think it looks a lot better, but maybe a little too saturated for my tastes.
#6 |
Taking shots through glass can be a challenge but I quite like these two shots , first one was with the lens against the glass , the second one was from a distance.
Olympus OMD EM-5 12-50 , 25 F1.4 , 60 F2.8 Macro , 75 F1.8 , Tripod 3LT Brian , Lee Seven5 . |
#7 |
| Thread Tools | |
| Display Modes | |
| Shooting through glass | fritz1 | General Photography Talk | 6 | 22nd of February 2010 (Mon) 02:53 |
| Shooting through glass | M5Man | Canon EF and EF-S Lenses | 9 | 27th of May 2008 (Tue) 20:08 |
| shooting glass | David Omer | Critique Corner | 0 | 5th of May 2008 (Mon) 11:54 |
| Shooting glass??? | photojag | Small Flash and Studio Lighting | 15 | 22nd of December 2007 (Sat) 19:57 |
| Shooting through Glass | alpine62uk | Canon EOS Digital Cameras | 13 | 12th of October 2004 (Tue) 10:28 |
