Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 5th of December 2005 (Mon)   #1
kstrieg
Unhappy PowerShot A85 flash is too bright... HELP!
Hello- I need some help from someone who know a little more about digital cameras than me. After happily using my Canon Rebel for several years, I researched digital cameras and found the Power Shot A85 to meet my needs. Nothing fancy but supposed to take very good pictures with out a lot of work.
Since day one I have been disappointed with this camera due to the crazy bright flash. Everything I take is over exposed... especially when I'm trying to take pictures of people. It is especially bad at night when the lighting isn't so good. I have tried getting very far away and zooming in, sometimes this works but what a pain. I have tried reading the owner's manual and using different modes. I tried to use the night mode inside but it's always blurry because it stays open longer. Maybe I'm not doing something right? I don't want to use the manual setting, that's why I bought an automatic camera, so I don't have to mess with that. Is there a setting I can use to lessen the flash? Is there anything I can do? This camera cost me a lot of money and I'm about ready to toss it... please help!
Thanks in advance!
kstrieg is offline   Reply With Quote
Old 6th of December 2005 (Tue)   #2
nidus_22
nidus_22's Avatar
Default Re: PowerShot A85 flash is too bright... HELP!
You can use the program mode and use the exposure compensation. set it to -1...in cases when u are using the flash.It is the first option in the functions. Also try using the "Indoors" settings in the special scene mode. Even then the highlights in the flash pictures are more, so u have to resort to PS. Yes, I do agree it is a pain.
In case you are using the night mode, you have to use a tripod. A very interesting effect can be created in the night mode, wherein you place the subject in darkness. Take the snap in night mode by holding the camera in hand and give it a little shake just after the flash is fired. The subject will be exposed correctly by the flash, and the background can be creatively blurred by the handshake. Try this...practice makes perfect.
Convey your findinds, as I use the same camera, actually the A75 - younger sibbling of the A 85.
nidus_22 is offline   Reply With Quote
Old 6th of December 2005 (Tue)   #3
Pixel9ine
Pixel9ine's Avatar
With an A85 on "M" mode, you can adjust flash intensity down from FULL to 2/3 and 1/3 power.
You may also want to change your light metering options to suit your shooting environment...
Andre B :: gearlist
www.pixel9ine.com
Pixel9ine is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Disassembly of Powershot A85 Markie Mapo Small Compact Digitals by Canon 4 28th of May 2009 (Thu) 22:09
Intervalometer for Powershot A85 imhotep Small Compact Digitals by Canon 4 19th of July 2006 (Wed) 18:36
Vivitar Digital Flash for Canon Powershot A85 A95 SD200 spelchek The POTN Lounge 12 2nd of December 2005 (Fri) 10:16
Vivitar Digital Flash for Canon Powershot A85 A95 SD200 spelchek Small Flash and Studio Lighting 1 30th of November 2005 (Wed) 19:40
Gallery (Powershot A85) yorktonite Presentation 1 10th of April 2005 (Sun) 22:59
