Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 5th of December 2005 (Mon)   #1
SCMedic
Default What I shot during the storm today..
Having finally recieved my Rebel XT, I've set out in the last 3 days to learn how to use it. I played with it a bit today, and this is a couple of the indoor shots I took...
SCMedic is offline   Reply With Quote
Old 5th of December 2005 (Mon)   #2
nidus_22
nidus_22's Avatar
Default Re: What I shot during the storm today..
Are they too much yellow or is my screen not calibrated?
nidus_22 is offline   Reply With Quote
Old 5th of December 2005 (Mon)   #3
SCMedic
They are very yellow, but my post processing skills with photoshop are quite infintile.
Old 5th of December 2005 (Mon)   #4
RAitch
RAitch's Avatar
If you want to try it manually,
Add a curves adjustment layer
Switch to the red channel (drop down box)
Add a point in the middle and drag it to the bottom right corner until the greens look right (removing reds)
Switch to green channel
Drag a center point slightly toward the top-left corner to pop the greens a bit more.
Switch to blue channel
Drag a center point slightly toward the bottom right corner.
Red - Input:154 Output:81
Green - Input:122 Output:134
Blue - Input:126 Output:105
That's a starting point anyway.
Less control... try Image>Adjustment>Variations.
Then just keep clicking the picture around the edges that looks best balanced.
Change closer to fine for "fine tuning"
You can also try Auto Colour (yikes!)
RAitch is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A shot from the midwest ice storm banana Still Life, B/W & Experimental 7 26th of January 2007 (Fri) 22:11
Shot today SloNeZ600 Birds 1 6th of May 2006 (Sat) 18:33
Storm that passed through today planepics76 Nature & Landscapes 0 13th of April 2006 (Thu) 20:45
One last shot from today benf64 Wildlife 6 15th of January 2006 (Sun) 18:35
Tried chasing a storm today five-o Wildlife 7 5th of June 2005 (Sun) 19:22
