#1 |
After waiting until the very last moment to buy another Gitzo tripod prior to a trip to Yellowstone, I'm asking for help from other Gitzo owners who use lenses up to 400mm for wildlife. I have a Gitzo G2258 already and am happy with it, so I'm planning to stay with Gitzo. I've used it with my Canon 100-400, Canon 400mm and the 100mm f/2.8 Macro. I'm shooting a Canon 7D and my wife has a Canon 5D. If there are any forum members who can help me refine my search down to the best choice for my purposes, I'd very much appreciate hearing from you. I'm hoping to order the tripod by COB on Monday so I can get it by Friday at the latest.
Thanks!
Canon 7D, Canon 30D, Canon 50mm f/1.4, Canon 17-40 f/4 L, Canon 100mm f/2.8 Macro USM, Canon EF 24-70mm f/2.8 L, Canon EF-S 10-22mm f/3.5-4.5 USM, Canon 100-400mm 4.5/5.6 IS L, Canon 400mm F5.6L, Set of Kenko Extension Tubes, Canon 580EX Galleries at: http://www.pbase.com/rfredrick |
| sponsored links |
#2 |
-POTN's Three legged Support-
If you want to stick with Gitzo then their rating is I believe a 3-series for a 400mm lens. So say something like their GT3541. I have the GT3541 with a Markins Q20 head and LOVE it! SUPER stable with a 400mm f/5.6L on it when I had one.
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\ GIVE a man a fish and he'll eat for a day. TEACH a man to fish and he'll eat for a lifetime. |
#3 |
I just bought the GItzo 3542L Systemic tripod. Check the Gitzo.us site. It's a series 3 tripod, which as ben points out, is supposed to be used with a lens up to 400mm, which is the longest I have now and plan to have for a while. I like to shoot panoramas and got a leveling head for the tripod, which interchanges with the flat base that comes with the sticks.
Also having an M20 (now called Q20) made up by Markins with a lever quick release supplied by Really Right Stuff. Not here yet, awaiting the UPS man.
Jay Portfolio 5D III | 5D II | 7D | Powershot S100 | 24-105L | 100-400L | 16-35 f/2.8L II | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L| 35mm f/1.4L | 580 EX II | 600 EX-RT | Feisol 3441T/ Markins Q3t II/ Markins lever QR/ RRSL bracket | Gitzo 3542L, Markins Q20, RRS lever QR | Gitzo 5561T monopod, RRS MH-02 LR | Lowepro Deluxe Harness, Util belt. |
| sponsored links |
#4 |
Being on the shorter side I use the 3531S. I don't need the extra height from an L or XL. Since the tripod is one of the shorter models, I go with 3 leg segments. Work for both me and the wife.
We both shoot landscape and wildlife. The 100-400 lens is a natural fit for that tripod and a good ballhead/clamp combo such as RRS 55 with QR clamp.
Canon EOS 5DIII | 24-105f4L | 17-40f4L | 100-400 f/4.5-5.6L | 100 f2.8L Macro | Canon EOS 7D | Tamron AF 18-270 f/3.5-6.3 Di II VC PZD| Canon Speedlite 580EXII | Gitzo GT-3531S | RRS BH-55 | Lexar 32GB 600x & 1000x CF cards | Lexar USB 3 reader www.ourimages.net |
#5 |
weight-wise, the 3-series is probably overkill for a relatively compact lens like that. I don't use either of those products but I use a comparable size 300mm f4 on a tripod that is the same specs as a gitzo 1-series 154x. Although, ideally, if you don't need to carry it long distances and want the best quality, the 3s probably are best as everyone is saying.
I guess gitzo rates everything based on the weight but also based on lens length just because of increased vibrations with higher magnification of the long glass.
Gear |
#6 | |
#7 |
My thanks and much appreciation to ben_r, tvphotog, MCAsan and elogical for taking time to provide suggestions regarding my last minute tripod purchase. I ordered the following from B&H this morning:
Gitzo GT3541L Tripod Kirk BH-1 Ballhead And because our PowerShot SD850 gave up the ghost recently, I ordered a Powershot S100 plus an extra battery and a couple of memory cards. Things have been hectic here while we're preparing for our trip so I really value getting thoughtful advice from experienced forum members. Ron
#8 | |
#9 |
I have been using the Gitzo 2542L and Acratech GV2 head
http://www.bhphotovideo.com/c/produc...mbal_Head.html I use it for the 5d3/70-200MII, which is heavier than the 7D/400mm. I have not had issues and they work extremely well together. The 3 series is about 1.5 lbs heavier than my 2 series Gitzo.
just a few of my thoughts... Pierre |
#10 | |
I will be in Yellowstone myself at the end of the month for 3 weeks. |
#11 |
Sorry I got to this thread a bit late!
The Gitzo GT3541L is overkill for your longest lens. I have used my 600 F4is on 2 to 5 series and ended up buying a 3530Ls as (imo) the best compromise. However fear not! You will be delighted with your tripod and it will easily cope with any future needs! Whilst the 3 series is bigger/stronger than you need now you can NEVER have a tripod that is too rigid and it is still pretty light! Also should you start to delve into the stupidly expensive SuperTeles then I am certain you won't be replacing your support (I have the heaviest and my 3 series is just fine!). The extra rigidity is great for macro work as well. P.S. Beware Gitzo stuff is overpriced but strangely addictive - I swore I would never waste that much money on a tripod - oops! I tried one! Now I am poor - but happy as I have 4!!!
Life is for living, cameras are to capture it (one day I will learn how!). Gear: A bit more now........... |
#12 | |
#13 | |
#14 |
You can never have too much support. The Gitzo 2012 spec sheet shows Gitzo 3 and 4-series to be good for 400mm lenses, so the 3-series is actually at the lower end of the 400mm spectrum as far as Gitzo is concerned.
Maybe a 4 or a 5-series might be overkill for a light(ish) 400mm lens but is that a problem? When he gets his 600mm lens sometime in the future he won't have to buy a new tripod...
~Peter |
#15 |
Formerly known as Bluedog_XT
I had a Gitzo GT2830 3-Section Basalt Tripod (Series 2) that was outstanding with the 400mm f/5.6. Bit cheaper than the CF model but nothing shy of quality construction and still light weight in design.
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS Canon PowerShot S95 MY PBASE GALLERY Last edited by Tsmith : 15th of May 2012 (Tue) at 22:38. |
| Thread Tools | |
| Display Modes | |
| Which RSS ballhead for Gitzo tripod and Canon 100-400 | Jdesign | Accessories & Storage | 20 | 6th of November 2009 (Fri) 13:14 |
| Gitzo 2430 tripod w/Canon 300mm 2.8 ok? | 4g63photo | Accessories & Storage | 5 | 29th of June 2008 (Sun) 14:04 |
| Gitzo tripod without ballhead and Canon 40D with grip? | lsquare | Accessories & Storage | 7 | 16th of May 2008 (Fri) 00:18 |
