#1 |
Doing IT and along with several years in data recovery has provided me with some advantages in securing my data. But that does not mean that technology hasn't changed. Im curious to see the types of drives, data servers, Backup software or network drives people are using? Brands, type, and use are great
Currently Im running a data server with 4 - 500gb Sata II drives with Raid5, with a backup server with another 4 - 500g Sata II drives ( No Raid). Along with this is a 3rd backup Cloud Server Drive ( Nice of Google to Provided a 100gb free storage for android Developers). As for my 4th backup this is off site at my business location. Also on a good note my contract is finally up for Restricted Data Recovery for government industry's so I can now go back to my public data Recovery with my own business. Brands that I have worked with and contain schematics for data recovery Western Digital - Good Drives, Main Boards and chips are decent quality Maxtor - Great Drives, uses a different manufacture now for Main board and Process Chip. Seagate - Trained and provided the 8 years experience. Provided the opportunity for Class 3 Data Recovery ( Micro Room and Drive Dismantling ) NOTE: Great Drives. INFO: Now here is some info that photog's should know: Using third party company's such as IOMEGA, Memorex, Buffalo Technology, and FANTOM DRIVES - can lead to problems. The issue is both the drives and controllers. All these companys purchase drives from WD, Maxtor, Seagate, and Hitachi in BULK ( Not tested and only 63% stock is guaranteed to work ). If you want proof, remove your drive from the case and go to the hard drive brands website and type in the serial ( P/N) and it will come up Bulk Shipment device and list the company. Nest issue is controllers, these company's will use OUTDATED controller software along with controllers that do not match the drive ( Example: Connecting a Sata II drive to a Sata controller - Brings down speed from 3gb/s to 1.5gb/s). Now this does not mean there all bad but does leave a high risk of failure. So if you have any questions about data recovery feel free to PM me, be more then happy to provide my certifications and such.
Canon T3i ( DryOS to Android Custom)- Canon 18-55mm IS kit lens, Minolta 50mm f1.2, Minolta 135mm. Google + https://plus.google.com/100227118899672172960 |
| sponsored links |
#2 |
Are you asking what drives we use?
I have one 1 TB and a 2TB Western Digital drive that backup all my data including photos. There's another 160 GB Western Digital passport drive that holds only photos, which is in a different location than my home. I don't use any online service except to hold the JPG images I want to share (my site is in my signature).
http://www.pbase.com/goldbough 5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4 |
#3 | |
| sponsored links |
#4 |
You can always get docking units and put an 'old' harddrive into it, from an external harddrive which had its interface electronics fail.
I did that with a Western Digital MyBook external USB unit which failed, in spite of it being babied and only powered up to back up files occasionally. I cut into the WD case, removed the WD harddrive and put it into a docking unit...it worked just fine, and I only had the (low) cost of the docking unit to make it all work.
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php Last edited by Wilt : 15th of May 2012 (Tue) at 00:09. |
#5 |
All my pictures live on a firewire drive. ALl of the projects get archived to a drobo. The best pictures get archived to S3. In other words, multiple levels of storage with all kinds of redundancy.
#6 |
"smells like turd"
I have 2x WD20EARX-00PASB0 (2TB) drives in my main machine for data, running 24x7 that does a sync once a day at 02:00hrs.
A third one I keep at work and every few weeks I bring home & swap with one of the other two drives. Haven't seen any issues in about 9 months (I had 3x 750G Seagate drives doing the same routine for about 3 years prior to getting the 2TB ones - didn't have any issues with them either) I've had different friends with different drives and no backup routines lose quite a bit of data over the years, always sad to see, but not an awful lot you can do about. I try and put stuff in perspective for them - drives fail, sooner or later they all do. Best be prepared.
canon camera stuff, canon lenses, Manfrotto "thingy", 1D MK II converted for IR TF posting: here |
#7 |
I'm running 2 WD Caviar Green 1TB drives in a D-Link NAS enclosure set to Raid1. I may switch it to Raid0 to have more space but worried about losing the redundancy. My system is set to sync the backup every night and has done well for the past 2 years. I would like to go cloud but my ISP is slow in my area.
~Dan 50D Gripped; 17-55mm f/2.8 IS USM; 85mm f/1.8; 50mm f/1.8; Tamron 18-270mm VC; 430EXII My Facebook Page |
#8 | |
Bodies: Canon 50D, Canon 5DMKII Lenses: Canon 50mm 1.8, Canon 85mm 1.8 USM, Canon 16-35mm 2.8L USM II Canon 24-70mm 2.8L USM, Canon 70-200mm 2.8L IS USM II Compact: Canon G12 |
#9 | |
#10 | |
I was looking at the D-Link Model last week, when I was building the server. hows the User Interface? Does the unit have a command console? Do the drives need to be Fat 32 for network access or will it except NTFS? Raid 0 is great if your using it on the computer that is editing, and processing photos, -- It will provide quick access to the data for all components. Now as for data protection there is where you come to the 50/50 mark. Raid O may provide quick access but data is slightly at risk. Thanks everyone for the information - Great Insight! Keep it comin.
Canon T3i ( DryOS to Android Custom)- Canon 18-55mm IS kit lens, Minolta 50mm f1.2, Minolta 135mm. Google + https://plus.google.com/100227118899672172960 Last edited by betatech : 17th of May 2012 (Thu) at 16:14. |
#11 | |
I have no complaints with the DNS-321. I mainly use it for back-up and some media streaming. So, I may just leave it as it is in RAiD1 and update to dual 2TB drives. I have it on a Linksys e2000 router with gigabit ports so transfers are really fast with my laptop which has an N300 wifi card.
#12 | |
....winded
Tony Two Canon cameras (5DC, 30D), three Canon lenses (24-105, 100-400, 100mm macro) Tony Long Photos on PBase Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here |
#13 | ||
Also.. What backup software is everyone using? I use the OLD SCHOOL C&P ( Copy and Paste ) but that is just my preference and I enjoy browsing the files. Now I have used retrospect, CA Arc Serve ( Great Program - but a PAIN to configure ), Seagate Backup, and a few 3rd Party. The issues I have had with the all these software types is backup verification or location of external Media if the Backup location is not working. Retrospect does really good for recovering backups but that has only been if the Backup will pass verification. Anyone experiencing the same issues or does someone have that Golden backup software I have been looking for?!
#14 |
"smells like turd"
I just use "Karens Replicator" to duplicate nightly between my internal drive & the one in the internal caddy.
(laughing hilariously at Arcserve! I haven't seen anything from CA that remotely resembles intuitive...)
#15 |
I use a software raid called FlexRAID (flexraid.com) to write parity to one spare drive on a nightly basis, and backup to an external usb drive around once a month... but what I was always looking for was a way to backup pictures while on vacation without lugging around my big laptop. What I did for backing up while travelling is pick myself up a small netbook that has a 250gb drive, nice screen (for reviewing pictures), and an SD slot.
60D | 15-85 | 50 1.4 | 28 1.8 | Σ 70-200 2.8 OS | 430EX II |
| Thread Tools | |
| Display Modes | |
| Travel Backup Options | Kid Colgan | Accessories & Storage | 19 | 5th of February 2011 (Sat) 12:56 |
| Backup Storage | dredwings3119 | Accessories & Storage | 15 | 11th of August 2009 (Tue) 23:56 |
| Backup options | ClydeD | The POTN Lounge | 3 | 26th of November 2007 (Mon) 19:43 |
| Do you backup your images on storage. | Shafique | General Photography Talk | 5 | 28th of September 2002 (Sat) 22:05 |
