#1 |
i'm tempted to get the 100 f2.8 during the current rebate period and curious if uv, polarizer or nd filters are necessary, or helpful in specific situations for macro photography.
thanks in advance. |
| sponsored links |
#2 | |
Brian v.
http://www.flickr.com/photos/lordv/ http://www.lordv.smugmug.com/ Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056 Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits |
#3 |
I think most people do not use filters on their macro lenses, but that doesn't mean you should not try it. I did not ever use a filter on my 100mm, and the lens was constantly getting dirty as a result. I find it more difficult (and scary, given the cost of accidentally raking a sand grain across it) to clean the lens directly than to clean a filter. When I upgraded to the 180L macro, I put a filter on it, and I have not found that the images are degraded to a noticeable degree. Moreover, when using it as a telephoto on hikes in the wilderness, I like the security of knowing the glass is protected.
That said, if you do consider a filter, you will need to get an expensive one to avoid image degradation. I use B+W MRC UV filters. A lesser filter will likely cause image degradation. I can't comment on using a CP filter (although I do own one) for macro work, but I have seen people like Brian get some nice results using that strategy. It's not going to make or break your shots, though. |
| sponsored links |
#4 |
thanks Brian and Ryan for your input. I have a 77mm B&W CP so I could get a step up ring for that. A UV filter for lens protection is good advice for me as I tend to go out hiking and to the beach.
Mike |
#5 |
The only filter I ever use for macro is the CP one, and even that rarely unless something like water reflection is a real issue. It quite often does also help colors show up better, but at the same time it cuts the light down enough so that depth of field can be a problem.
| Thread Tools | |
| Display Modes | |
| Macro Filters on 28-90mm lens ?!? | NHoutz86 | Accessories & Storage | 1 | 7th of May 2011 (Sat) 19:16 |
| Closeup Macro Filters - Which lens would these work best with? | rushhour | Macro Talk | 15 | 9th of March 2010 (Tue) 14:37 |
| Canon T1i Kit Lens & Macro Filters & Accessories | CompactFlasher | Canon EOS Digital Cameras | 5 | 7th of October 2009 (Wed) 18:37 |
| A710is Lens Adapter and Filters/Macro Lens | pridash | Small Compact Digitals by Canon | 15 | 24th of July 2007 (Tue) 15:08 |
