Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > Computers
Reply
Thread Tools Display Modes
Old 17th of May 2012 (Thu)   #1
iamdogdog
iamdogdog's Avatar
Default is this asus amd laptop good enough for lightroom and pse and maybe video editing?
http://www.bestbuy.ca/en-CA/product/...654432aba1en02
Processor
Processor Type AMD A6-3420
Processor Cores 4
Processor Speed 1.4 GHz
Processor Cache 1 MB
it said 1.4GHz but there are 4 of them, is this good enough?
Thanks.
60D | 17-55 | 30 1.4 | 580EXII | POTN
iamdogdog is offline   Reply With Quote
Old 17th of May 2012 (Thu)   #2
tim
Light Bringer
tim's Avatar
Default Re: is this asus amd laptop good enough for lightroom and pse and maybe video editing
CPU is 1/4 the speed of the previous gen (sandy bridge) i5, so no, not really.
http://www.cpubenchmark.net/cpu.php?...D+A6-3420M+APU
tim is offline   Reply With Quote
Old 18th of May 2012 (Fri)   #3
iamdogdog
iamdogdog's Avatar
thanks tim, my current laptop screen is dying on me and I will need to pull some trigger real soon.
What's your suggested spec for a laptop then?
cpu - i5? is i3 good enough? do I need to focus on the Ghz number?
RAM - I assume 4G is minimum nowadays, right?
Thanks.
Old 26th of May 2012 (Sat)   #4
th0rr
CPU speed is listed in Ghz (these days anyways) faster is better but so is the number of cores, as for RAM it seems 4G is standard but as cheap as RAM is these days you can always upgrade on the cheap later.
Personally for what you want to do, I'm not sure I would go with an i3. Video editing and rendering can be really taxing on a system, most video editing software will utilize all 4 cores if they're there. I believe i3's are dual core.
Another $100 and you can get
http://www.newegg.com/Product/Produc...82E16834230236
But if your budgets tight this might work
http://www.newegg.com/Product/Produc...82E16834246316
th0rr is offline   Reply With Quote
Old 26th of May 2012 (Sat)   #5
killwilly
killwilly's Avatar
If it is only the screen that is causing problems, you can replace the lamp. I replaced the one in my old Acer XP, which had been running 24/7 for 4 years connected to my weather station. It's perfect now, see link below.
http://lcdparts.net/adword/ccfl_lamp...FYpjfAod23CDaQ
Alan.
Canon 7D. Canon 15-85 EF-S Lens. Canon 55-250 EF-S Lens. Speedlite 430ex 11
Canon T90 SLR. + various FD lenses. Sigma APO 150-500mm F5-6.3 DG OS HSM - Bigmos.
killwilly is offline   Reply With Quote
Old 26th of May 2012 (Sat)   #6
john5189
My 1.6GHz chip,dual core with 4GB RAM and Vista 32bit runs CS5 and LR4 fine, a bit slow on some filters and cueing of tasks
So anything better than this is going to be faster.
4GB cant deal with A1 size images. And LR will crash if I cue too much.
64bit Win7 worth the extra in saved time.
john5189 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What laptop for editing 1080p HD video from PowerShot Elph 300 HS? Shobba Digital Video 2 30th of March 2011 (Wed) 10:50
Asus VH242, any good for editing? jacknimble Computers 1 25th of June 2010 (Fri) 01:01
Best Dell Laptop for NLE Video Editing / Photoshop HarrisonClicks Computers 5 21st of November 2009 (Sat) 09:11
Good software for video editing? sinitry23 RAW, Post Processing and Printing 22 2nd of January 2009 (Fri) 18:30
Good Laptop for Editing? Tumeg Computers 12 16th of October 2008 (Thu) 01:59
