Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Astronomy and Celestial Talk
Reply
Thread Tools Display Modes
Old 17th of May 2012 (Thu)   #1
swngdncr
Default eclipse, conflicting information re. need of solar filter
I'm seeing conflicting advice in various locations re. the need for a solar filter to photograph the eclipse. I see some posts saying it is essential, and others saying 'don't worry about it, we take pictures with the sun in it all the time.'
So my question is this, assuming a max. reach of 400mm on a crop sensor, can you get a good shot of the eclipse alone w/detail, or would the better approach be to go wider and try for a shot of the eclipse as the background of some interesting foreground? If so, would not a solar filter render all the foreground black? So, do you shoot instead with no filter, or an ND filter?
From what I can tell, unless you have a gargantuan lens or are shooting through a scope or other specialized equipment, you are talking about a relative small sphere, with little detail. Your not going to get a shot like this with 400-500mm, correct? :
http://www.space.com/15662-annular-s...uide-2012.html
With 400mm on a crop sensor, can you get a shot of the eclipse alone with enough detail to be interesting, and in this case, is a solar filter then required? Thanks in advance for your help.
Canon 50D, 70-200 f4, 70-200 f2.8, 17-40 f4, 24-105 f4, 1.4x & 2.0x TC
swngdncr is offline   Reply With Quote
Old 18th of May 2012 (Fri)   #2
hollis_f
hollis_f's Avatar
Default Re: eclipse, conflicting information re. need of solar filter
You sure can. Remember the Sun is about the same size in the sky as is the Moon, and there are loads of examples of Moon photos at 400mm. Here's my Sun image with a 100-400...
To fill the frame on an APS-C you'll need around 1500mm.
Yes. Definitely. You will need a proper filter specifically designed for shooting the Sun. An ordinary ND will not block enough IR.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawl of his free fish entitlement.
Gear Website
hollis_f is online now   Reply With Quote
Old 18th of May 2012 (Fri)   #3
5Dmaniac
5Dmaniac's Avatar
I have read that you need the solar filter before and after the total eclipse but you need to take it off when the full eclipse occurs.
5Dmaniac is offline   Reply With Quote
Old 18th of May 2012 (Fri)   #4
hollis_f
hollis_f's Avatar
This is true for a total eclipse, where the whole of the Sun's disc is covered by the Moon. But on Sunday the eclipse is partial or annular - not all of the Sun will be hidden. Even a small sliver of naked Sun can cause damage to eyes and optics when magnified by a big lens.
Gear Website
Old 18th of May 2012 (Fri)   #5
swngdncr
Thanks for the information, this is very helpful. I've got a welders #14 glass which after looking around on the net, I think I'll be able to rig into a solar filter. Going to try that today and see if I can get a setup that works and test it out. I realize I'll need to do some major adjustments PP to get the colors right, but it was the only option I had at this late juncture, and in my budget.
Yes. Definitely. You will need a proper filter specifically designed for shooting the Sun. An ordinary ND will not block enough IR.[/quote]
Old 18th of May 2012 (Fri)   #6
hollis_f
hollis_f's Avatar
Just make sure there's no way the filter can fall off during use.
Gear Website
Old 18th of May 2012 (Fri)   #7
sigma pi
sigma pi's Avatar
soooo a few ND filters and polarizer wont cut it?
Self important trumps all.
http://www.flickr.com/photos/themort...in/photostream
I live at 100 ISO street.
sigma pi is online now   Reply With Quote
Old 19th of May 2012 (Sat)   #8
Mike Deep
Mike Deep's Avatar
They will if you're not into the whole "continued use of eyesight" thing.
www.mikedeep.com | SportsShooter
AF: 1D Mk II | 30D | XT | 50/1.8 Mk I | Sigma 8-16 | Sigma 24-60/2.8 EX | 70-200/2.8 L | 100-400 L
MF: Zuiko 50/1.4 | Vivitar Series 1 90/2.5 | Tamron Adaptall-2 SP 300/2.8
FOR SALE: 70-200/4 L
Mike Deep is offline   Reply With Quote
Old 19th of May 2012 (Sat)   #9
CameraMan
CameraMan's Avatar
I like this idea best. There's so much going on during a solar eclipse especially if you're looking at the ground on a wooded lot. The interesting shapes made by the shadows is quite surreal. I would go this route. The sun will be down by me when this happens so I won't get to experience it this time around.
Atlanta Wedding Photographer | The Toys! | Facebook | Video | Flickr
“When words become unclear, I shall focus with photographs. When images become inadequate, I shall be content with silence.”
― Ansel Adams
CameraMan is offline   Reply With Quote
Old 19th of May 2012 (Sat)   #10
sigma pi
sigma pi's Avatar
I was going to live view and not look in the eye piece .... so I am good?
Thanks for the info. I guess Ill just look at every one elses pics
Old 19th of May 2012 (Sat)   #11
swngdncr
Still wondering, with the approach of the eclipse being the backdrop to an interesting foreground, so you are not zoomed in on the sun, what kind of filtering is needed? I did rig up a very successful solar filter by using silicon to attach it to a conkin 77mm adapter ring. I then just screw this on to the lens and get no light bleed or anything, but, it is so dark that you can't really get any foreground. If there is a silhouette against the sun itself, that is visible, but very tough to focus on the foreground, especially plant material with the wind blowing. Had trouble getting focus on the sun as well, but just not sure what to expect. This is sort of typical of some of the test shots I got this afternoon...
Old 20th of May 2012 (Sun)   #12
J0eybb
J0eybb's Avatar
This might be a dumb question. How is this any different than shooting a sunset?
T3i Kit | EF-S 18-55mm f/3.5-5.6 IS | EF 75-300mm f/4-5.6 III | EF-S 55-250mm f/4-5.6 IS | n00b
J0eybb is offline   Reply With Quote
Old 20th of May 2012 (Sun)   #13
hollis_f
hollis_f's Avatar
Lift your face up to the mid-day Sun. You can feel the warmth - that's the IR radiation, the stuff that can cause serious damage. Now (well, in several hour's time) turn your face to the setting Sun. You're unlikely to feel much warmth at all. That's because the IR light gets scattered and absorbed by the thicker layer of atmosphere. That's the main reason why you can shoot a sunset, or even look towards the setting Sun itself, and not have your sensor, or eyeballs, cooked.
Gear Website
Old 20th of May 2012 (Sun)   #14
J0eybb
J0eybb's Avatar
Thank You!
Old 30th of May 2012 (Wed)   #15
DanFaenza
Speaking of sunset, it appears that the Venus transit is going to be at it's best just before/at sunset here in FL. My question is what type of filter should I use so Venus is actually visible in front of the sun (if any filter at all)?
P.S. I'm thinking of making it a beach day that day and hang out for sunset, just fyi.
Dan
Dan Faenza Photography
DanFaenza is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Nd 10 stop filter- for solar eclipse Marcy Astronomy and Celestial 10 16th of May 2012 (Wed) 08:13
Solar Eclipse Adrena1in Astronomy and Celestial Talk 0 30th of December 2010 (Thu) 03:54
Solar Eclipse Exposed film Astronomy and Celestial 18 20th of April 2010 (Tue) 02:25
Solar Eclipse UgisB Wildlife 7 2nd of August 2008 (Sat) 02:45
Solar Eclipse Rosemarie General Photography Talk 17 4th of May 2005 (Wed) 19:26
