Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 21st of May 2012 (Mon)   #1
brantfordbandit
brantfordbandit's Avatar
Default sx 40 macro
I used to have an s2 is which had super macro, but i cant seem to find this feature with my new sx 40?
www.markephotography.com
brantfordbandit is offline   Reply With Quote
Old 21st of May 2012 (Mon)   #2
T.J.
Default Re: sx 40 macro
Hi brantfordbandit,
the SX40 has only one macro mode, not two as in earlier models. I haven't owned any of these earlier ones, but as I understand, the two former modes have been merged into this one which combines both. You get as close with this one, as you did with the former two. The camera is also able to focus on objects, even as near as touching the lens.
Hope this helps, otherwise please ask again.
/T.J.
T.J. is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Macro: dedicated Macro 100mm lens vs 70-300 macro lenses?? nekrosoft13 Canon EF and EF-S Lenses 4 16th of June 2010 (Wed) 18:40
Macro Lens without Macro, Help! (Tamron AF 75-300mm f/4.0-5.6 LD Macro Autofocus) janapriya Canon EF and EF-S Lenses 6 21st of May 2007 (Mon) 22:47
EF-S 60mm f/2.8 Macro vs. EF 100mm f/2.8 Macro vs. EF 50mm f/2.5 Compact Macro mephetic436 Canon EF and EF-S Lenses 10 27th of November 2005 (Sun) 14:22
