Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Astronomy and Celestial Talk
Reply
Thread Tools Display Modes
Old 21st of May 2012 (Mon)   #1
nu8reed
Default Stacking question
I had a question regarding bias and flat frames. Assuming I use the same camera, ISO, lens and focal length, can I use the same bias and flat frames? Wouldn't the flat frames always be the same for a particular lens? How would it be different from correcting vignetting with lens correction in lightroom or peripheral illumination correction in DPP?
After reading the DSS FAQ, I understand light, dark and flat frames, but I do not understand how bias frames work.
nu8reed is offline   Reply With Quote
Old 22nd of June 2012 (Fri)   #2
A.S.I.G.N. Observatory
A.S.I.G.N. Observatory's Avatar
Default Re: Stacking question
Flat frames not only correct vignetting, but also any dust motes in your imaging train.
Australian Wildlife Photographer
BA Photography
ASIGN Observatory II
A.S.I.G.N. Observatory is offline   Reply With Quote
Old 26th of June 2012 (Tue)   #3
jannefoo
LR lens correction profiles vary wildly in quality. Some are acceptable, some borderline unusable.
Compare these, first two images with two different LR profiles and then a flat field corrected image:
(Unusable)
(Acceptable)
(Perfect correction with flat field)
jannefoo is offline   Reply With Quote
Old 3rd of July 2012 (Tue)   #4
nu8reed
[img]
(Unusable)
[img]
(Acceptable)
[img]
Nice.
To reword my previous question, if you are using the same lens, with the same settings, could you use the same flat frames? Or is it better to take new flat, dark or bias frames every time?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Question about Lightroom stacking... Mahgnillig RAW, Post Processing and Printing 8 5th of September 2011 (Mon) 14:40
Stacking question? markley Astronomy and Celestial Talk 5 12th of December 2010 (Sun) 20:57
a question about focus stacking nuffi Macro Talk 4 1st of February 2010 (Mon) 03:51
Stacking question. u8myufo RAW, Post Processing and Printing 5 16th of June 2008 (Mon) 05:39
Focus stacking question OEH Macro 5 3rd of May 2008 (Sat) 03:25
