Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 21st of May 2012 (Mon)   #1
imposterjeff
Default friends wedding
Ok i had some friends that got married last year, i had never shot a wedding before i was just there as a guest and then there photographer didn't show up and i had my camera with me so i stepped up and did what any good friend would do, i kept telling my self if i can shoot a metal concert i can do this same chaos just not as loud. well this was the outcome the photographer showed up just really late but i kept shooting. let me know what you think for a first time (more than likely crap)
1
Oct012011_0079 by jeff shoots a canon, on Flickr
2
Oct012011_0127 by jeff shoots a canon, on Flickr
3
Oct012011_0235 by jeff shoots a canon, on Flickr
4
Oct012011_0251 by jeff shoots a canon, on Flickr
5
Oct012011_0332 by jeff shoots a canon, on Flickr
gripped 5Dmkii X2
35mm f/1.4L | canon 50mmf/1.4 | 85mm f/1.2L mkii | 135mm f/2L | B+W FILTERS
b800x2 | RADIOPOPPERS | modifiers
imposterjeff is offline   Reply With Quote
Old 22nd of May 2012 (Tue)   #2
HiepBuiPhotography
Default Re: friends wedding
Not bad for your first time =D I just had my first wedding a couple of days ago also!
However, first thing I noticed is that everything's too centered. You can crop #4 so that they're a little off-centered.
Hiep Bui Photography | Harrisburg Wedding Photographer
HiepBuiPhotography is online now   Reply With Quote
Old 22nd of May 2012 (Tue)   #3
rick_reno
Very nice, like3 and 5 best
rick_reno is offline   Reply With Quote
Old 22nd of May 2012 (Tue)   #4
imposterjeff
Thanks guys this was back in October so I had not as many great lenses. I shot it with a 70-200 and 50mm
gripped 5Dmkii X2
Old 23rd of May 2012 (Wed)   #5
auroraskye
auroraskye's Avatar
They aren't bad. Your exposure is pretty close and colors aren't far off. They could use a little editing tweaking (especially the black and whites, which feel flat and gray) but they do seem a little snapshottish. I can't view your EXIF but a narrower DOF would have helped. A 50mm and 70-200mm are more than acceptable lenses to do what needs to be done.
I am super cool n' stuff.
http://www.brandithompsonphotography.com
Like Me On Facebook
auroraskye is offline   Reply With Quote
Old 23rd of May 2012 (Wed)   #6
imposterjeff
this is true likei siad i had never done one so it was a complete first for me
gripped 5Dmkii X2
Old 25th of May 2012 (Fri)   #7
algphoto
Having been a first time and having done it on the fly I think you should be proud of yourself! I am sure the couple will be more than happy to have these shots.
If you spend a little bit more time in post you'll be able to make these shots pop.
Ashley
Visual Appeal Studios
on Facebook
algphoto is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #8
imposterjeff
yes i am going to re work them a bit more tomorrow on my day off and get them to them next week the actual photog sowed up midway through and you can see him in the second photograph getting the pictures from behind
gripped 5Dmkii X2
Old 25th of May 2012 (Fri)   #9
plawren53202
Especially considering the circumstances you described, I think these are quite good. Exposure, colors all that stuff is nice.
I would crop in on some of these...in 1, 2 and 3 the stuff around the sides just isn't doing anything for you, so I would probably crop in tighter on those. 3 is a good example of what someone above said about getting some more background blur. There is a little too much background detail givent the purpose of the shot. Your subjects are far enough away from the background (tree, building) so that with the right aperature you could get a nice blur going and eliminate the distractions of these details.
On the B&W, I agree that it is a little flat. Did you shoot in RAW? I think you should be able to play around with the contrast, blacks and brightness to get a little more contrast and pop to this. Since your starting colors and exposure were good, you should be able to retrieve a great B&W as well.
I don't go anywhere near photographing weddings, so kudos to you for doing a good job and a noble deed under, errr, less than desirable circumstances.
plawren53202 is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #10
imposterjeff
yes it was shot in raw and i shot it pretty much at f5.6 or so i think for the one of the bride and her dad coming down i know have a 135L which if i had it before it would be quite a bit better
gripped 5Dmkii X2
Old 26th of May 2012 (Sat)   #11
ChunkyDA
ChunkyDA's Avatar
Is that the "Pro" bouncing his flash off the trees in #2?
It's hard to tell if these are in focus but at least they got some pictures of their wedding. Looks like they have an adventurous like ahead.
ChunkyDA is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
My friends wedding David83 Weddings and Other Family Events 14 12th of November 2011 (Sat) 00:52
Friends Wedding gerstoscar Weddings and Other Family Events 20 10th of July 2011 (Sun) 21:13
Friends wedding martyinco Weddings and Other Family Events 2 14th of December 2010 (Tue) 11:12
friends wedding jamows Weddings and Other Family Events 10 4th of April 2008 (Fri) 19:37
Friends wedding! geofftelforduk People 9 1st of August 2005 (Mon) 20:01
