Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Sports Talk
Reply
Thread Tools Display Modes
Old 23rd of May 2012 (Wed)   #1
BurtonC
Default Which equipment
I would like to get myself a canon camera setup with the right lense but I'm unsure what's the best options, I want to shoot combat sports (MMA, Thai boxing etc) it will mainly be in doors but thre could be some outdoors shooting.
I haven't got he biggest budget in the world and as I'm a hobbyist at he moment I was looking at the 4050/550 camera, which lense(s) would be the best options to capture the action with as little motion blur or noise as possible.
Any feedback is really appreciated.
BurtonC is offline   Reply With Quote
Old 23rd of May 2012 (Wed)   #2
facedodge
facedodge's Avatar
Default Re: Which equipment
The 60D has a better frame rate than the 550D.
You will need a fast lens. Depending on how far you are from the action, the 85mm 1.8 or 135 f/2L may be good choices. The 70-200 2.8 (Non-IS or IS Mark I) is a good lens with more flexibility (in case you are shooting from purchased seats)
Gear List | Feedback
facedodge is offline   Reply With Quote
Old 23rd of May 2012 (Wed)   #3
facedodge
facedodge's Avatar
What is your total budget?
Old 23rd of May 2012 (Wed)   #4
BurtonC
I could stretch to £1000 to get the camera body and first lense, I can always purchase extra lenses at later date
Old 23rd of May 2012 (Wed)   #5
facedodge
facedodge's Avatar
One thing that is always tough for newcomers to understand despite how often it is echo'd.... Lenses are more important than bodies.
Now, you don't need to get L glass, though some are good values right now (35L, 70-200 f/4, 135L, and 300 f/4L). The 85 1.8, 50 1.4, 100 f/2 Macro are all great non-L lenses.
Also if you are for sure getting an APS-C lens, the 17-55 f/2.8 is a great lens as well but will not fit on a full frame like the 5D.
I would buy a used body rather than a new 550D and spend the rest on glass.
Old 23rd of May 2012 (Wed)   #6
BurtonC
I understand lenses are more important then the body, reason I'd go for a newer body is that would last me longer technology wise rather than buying a 3 year old body etc
Which body would be best 550, 5D or 60D
Old 23rd of May 2012 (Wed)   #7
facedodge
facedodge's Avatar
The 550D has the same sensor as the 60D, but lacks build quality, tilt LCD, Frames per second and other features such as exposure bracketing, more cross type AF points, etc.
The 5D is a different beast. I assume you mean the 5Dc. The AF is the same as the 60D I think and has less FPS, but it's full frame which means 50mm = 50mm. The sensor collects more light, the depth of field is narrower and ISO's can be pushed much higher.
buying a used 5Dc would be better than either 60D or 550D for MY purposes. Yours might be different. 7D is best for sports, then 60D, then 550D.
Old 23rd of May 2012 (Wed)   #8
Biffbradford
Biffbradford's Avatar
For a tight budget, the 50mm f1.8 is an amazing lens. Don't let the low price fool you. I think everyone should have one in their bag.
My pictures: Flikr, John Wilke Photography, Peloton-Pix.Com , PelotonStar.Com
Canon 1D MkII N, 1D MkIII, various Canon and Tokina lenses.
Biffbradford is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #9
watt100
I agree, if you're on a tight budget the 50mm 1.8 will get you good indoor action pics
watt100 is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #10
CountryBoy
"Tired of Goldmember label"
CountryBoy's Avatar
I'd try the Canon 85mm 1.8 , fast and accurate Af . The only problem is it might not be wide enough , but that depends how close you are too the action . If not , grab the Canon 50mm 1.4 .
CountryBoy is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #11
kenjancef
kenjancef's Avatar
I agree on both. I have both lenses, and for shooting indoor basketball/volleyball in the winter, the 85 1.8 NEVER comes off! The 50 1.4 is a bit too wide for shooting hoops though. And both lenses are fairly inexpensive, but not sure what your idea of expensive is. Compared to their "L" equivalents, they are inexpensive.
kenjancef is offline   Reply With Quote
Old 29th of May 2012 (Tue)   #12
BurtonC
Thanks for all the advice, think I'll save up a few
More months, get a bit of a bigger budget and get a 7d with a standard, I'll hire the lenses recommended and then decide which ones to buy after testing them.
I've got a finpix s2970 bridge camera at the Moment as this is just a hobby and I have loads to learn.
Old 26th of August 2012 (Sun)   #13
ChrisRabior
I'd imagine this guy was quite disappointed in the lens recommendations.. which wouldn't surprise me in the least. I would have guessed SnapLocally's posts (which named the lenses he started out with) would have been a great place for this guy to get a feel for how these shows work.
I've shot a lot of fights.. and despite having a 70-200mm f/4L and 85mm f/1.8 along for the ride a few times (even in awesome lighting), I rarely have anything on my 7D where the short end is any 'closer' to the action than 28mm.
My Gear | My Alamy | My Website | MMA Photography
ChrisRabior is offline   Reply With Quote
Old 27th of August 2012 (Mon)   #14
tj3775
I second that...SnapLocally is the go to for MMA and Boxing
tj3775 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Equipment help NeilSim2010 General Photography Talk 3 26th of July 2010 (Mon) 00:08
lost equipment - finding equipment michelgauthierdesign General Photography Talk 21 8th of June 2010 (Tue) 10:32
What equipment should I take to NYC thampel09 Urban Life & Travel Talk 5 30th of July 2009 (Thu) 16:13
WTT Photo Equipment for Scuba Equipment ddmitchell Classifieds: Buy 0 5th of May 2009 (Tue) 17:54
Air to Air Equipment kevinbark The Business of Photography 6 11th of July 2006 (Tue) 17:20
