Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 24th of May 2012 (Thu)   #1
jonnie
Default Alternatives to DSLRs
Hello!
DSLRs are obviously hugely popular these days for the incredible quality of video that can be captured from them, combined with their size and price.
They do have their limitations though - and in this case I'm talking about their ability to film for long periods of time without hitting memory/time limits or overheating.
What sort of video cameras are a viable alternative (in regards to picture quality/portability) to the DSLR that can film for much longer durations?
Thanks!
jonnie is offline   Reply With Quote
Old 24th of May 2012 (Thu)   #2
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Default Re: Alternatives to DSLRs
Any "traditional" video camera would be the reasonable choice if you need to record for longer than the data block in a dSLR.
Some even use CF cards. All the major players (Canon, Sony, etc...) have options so it's really just a question of budget.
FlyingPhotog is offline   Reply With Quote
Old 24th of May 2012 (Thu)   #3
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
Comparable options are many, but will cost quite a bit more depending on what DSLR youre referring too. Thats why DSLR video has gotten so popular. Very good bang for the buck. Lets start by you telling us what your budget it like since thats normally the lowest common denominator deciding factor.
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\
ben_r_ is offline   Reply With Quote
Old 24th of May 2012 (Thu)   #4
Numenorean
How about this guy?
http://www.red.com/store/products/epic-m-2
Numenorean is offline   Reply With Quote
Old 24th of May 2012 (Thu)   #5
FlyingPhotog
Cream of the "Prop"
Or you can still use your EF lenses with THIS.
Old 24th of May 2012 (Thu)   #6
charro callado
charro callado's Avatar
Sony FS100 - uses SD cards with no recording time limit
Black magic cinema camera - uses SSDs with no recording time limit (i think) AND 2.5k resolution AND EF mount (!!!)
Alternatively, you can use a DSLR with a clean HDMI out and use an external HDMI recorder with no limit (also has the benefit of bypassing internal codecs in favor of less or no compression).
charro callado is offline   Reply With Quote
Old 24th of May 2012 (Thu)   #7
MichaelVeraPhotography
Better off with a RED Scarlet in that price range, still can use your canon EF lenses.
http://www.red.com/products/scarlet
Canon 60D
18-135mm F/3.5-5.6 EF-S IS
60mm EF-S f/2.8 Macro USM
MichaelVeraPhotography is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #8
Salleke
Does the Canon 5D3 have the clean HDMI output?
Can you please give us a link to a decent HDMI recorder to use with a
(Canon) DSLR?
Thank you.
Salleke is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #9
FlyingPhotog
Cream of the "Prop"
Ridiculous...
C300 lets you just pop the CF card out of the camera and go to work (and you can do so while still recording to the second card!)
RED requires one of their dedicated workstations to transcode their proprietary media.
Don't really think the OP has any interest in dealing with the massive storage requirements associated with 4K digital cinema either.
Actually, the C300 is probably too rich for just about anyone except rental houses.
Old 25th of May 2012 (Fri)   #10
Channel One
Channel One's Avatar
Originally Posted by jonnie View Post
Hello!
Thanks!
I would recommend that you look into some of the Prosumer offerings by JVC and Panasonic.
http://www.bhphotovideo.com/c/produc...Camcorder.html
http://www.bhphotovideo.com/c/produc...ld_Memory.html
Wayne
Madness takes its toll, please have exact change.
NPPA Member SE region.
SMPTE Atlanta.
Channel One is offline   Reply With Quote
Old 25th of May 2012 (Fri)   #11
charro callado
(Canon) DSLR?
Thank you.
I don't think the 5d3 has a clean output. If it's like the 7d, it has some kind of information overlay. But I'm not sure.
I think the Atomos Ninja would be a good option as far as external recorders go.
Old 19th of June 2012 (Tue)   #12
J_O_S_H_U_A
J_O_S_H_U_A's Avatar
Correct the 5D3 does NOT have a clean HDMI out.
I am not a fan of the ATAMOS products because they dont take XLR in so you are spending $1000 + and still have to record separatate audio.
I think that the KiPro mini is a MUCH better solution if you already have a monitor, or if you wanna go all out, go with the sound devices PIX240.
7D | 24-105 f4L | 200 f/2.8L | 17-40 f4L | Zeiss Planar*T 50/1.7 | Zeiss Distagon*T 28/2.8 | Zuiko 28/2.8
MM#1848633
J_O_S_H_U_A is offline   Reply With Quote
Old 19th of June 2012 (Tue)   #13
ben_r_
ben_r_'s Avatar
Uh, even shooting with $100K cameras people take in separate audio. With proper audio gear the results are always better. The only reason some situations/people dont do separate audio is cost or convenience (which obviously has its price).
Old 19th of June 2012 (Tue)   #14
charro callado
Yeah, I would think that if you're going through the trouble to bypass internal video codecs, the production probably warrants a sound guy with dedicated equipment to match.
Old 19th of June 2012 (Tue)   #15
ben_r_
ben_r_'s Avatar
Man, people run dual systems at all levels of the game. Really has nothing to do with the level invested in. Almost any external recorder and microphone are better than any cameras built in. On board audio is like on board flash, dont use it! Now, its there, and people certainly do, as I mentioned before mostly due to cost or they simply cant have it external, but the results are always going to be better getting it off the camera.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Are DSLRs on their way out? Some seem to think so. obsoletepower Photography Industry News 54 26th of January 2012 (Thu) 11:56
New To DSLRs Tsunami_Tsurfer Canon EOS Digital Cameras 17 5th of July 2009 (Sun) 09:50
New to DSLRs Cavediver Canon EOS Digital Cameras 12 29th of January 2009 (Thu) 14:32
Why we use dSLRs instead of P&S? Muggles Canon EOS Digital Cameras 60 8th of May 2007 (Tue) 11:31
