Thread started 26 May 2012 (Saturday) 20:23
Prev/next
Best Value - "Flat Top" - "No Column", Carbon Tripod?
babel_fish
babel_fish's Avatar
Seattle
May 26, 2012 20:23 |  #1
I've been sort of looking but I'm having a hard time actually finding a way to narrow searches on vendor sites to tripods that offer a flattop or no center column option.
My Needs:
Flat top - no center column
Equivalent leg diameter - at least 30mm
20lb + carry capacity
Carbon Fiber
4 section, can do 3 section but height maximum is more important.
61-63" height or higher
Budget:
$400
Where to start?
Any help out there?
"The time you enjoy wasting is not wasted time." -Bertrand Russell
"dude, are you even paying attention!,
Mike
tvphotog
tvphotog's Avatar
New York City
May 26, 2012 20:53 |  #2
babel_fish wrote in post #14489442external link
My Needs:
Carbon Fiber
Budget:
$400
Where to start?
Any help out there?
As far as I know, only Gitzo and Really Right Stuff have that kind of tripod, and your price will be double what you want to spend. Check Feisol.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Powershot S100 | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
Lowner
"I'm the original idiot"
Lowner's Avatar
Salisbury, UK.
May 27, 2012 06:28 as a reply to tvphotog's post |  #3
I am using a Manfrotto 055CXPRO3 with the centre column removed and the ballhead mounts on a simple alloy plug which simply replaces the centre column, it is locked in place using the centre column locking thumbscrew. The PRO3 is 3 section, but Manfrotto offer a PRO4 4 section version.
I'm happy to PM you pictures of it if interests you.
Richard
http://rcb4344.zenfoli​o.comexternal link
tvphotog
tvphotog's Avatar
New York City
May 27, 2012 07:37 |  #4
Check the Feisols at www.reallybigcameras.c​omexternal link. They have what you want at about $325. They're an excellent product, have good reviews here. I've got a 3441 travel model which is excellent.
Jay
sarahhj
Joined Sep 2009
Sussex, UK
May 27, 2012 10:13 |  #5
Hi Richard,
I am interested in your set up. I too have the 055CXPRO3 and currently use a short centre column - but your method might suit me better. Please could you post up or PM me your photos?
Canon 5D MkII | Samyang 14mm | TS-E 24mm f/3.5 L II | 16-35mm f/4L | Zeiss 2/50 | 70-200mm f/4L | Manfrotto | Lee, Hitech & Lucroit Filters | F-Stop Loka | Panasonic LX7
peter_n
peter_n's Avatar
Boston, MA
May 27, 2012 10:42 |  #6
Benro and Feisol are popular value brands. If you're a taller person the Feisols are better, smaller users often choose Benro. Whatever tripod you choose get one with anti-rotation leg locks. The Feisol model that looks near your requirements seems to be the CT3471external link; 37mm max leg , 26.5lbs max load, 60.6" max height, $414. The nearest Benro is the C3780Texternal link; 32.5mm max leg, 39.6lbs max load, 58.2" max height, $490. The Benro is a clone of the Gitzo 3541LS and takes Gitzo and RRS tripod accessories.
~Peter
Lowner
Lowner's Avatar
Salisbury, UK.
May 27, 2012 12:11 |  #7
sarahhj wrote in post #14491188 (external link)
Hi Richard,
Saraahhj,
2 images, the 1st is the hole in the tripod when the centre column is removed. The 2nd is the alloy plug screwed to the ballhead. The thumbscrew you should see on the trpod head rim locks everything together.
Richard
Lowner
Lowner's Avatar
Salisbury, UK.
May 27, 2012 12:12 as a reply to Lowner's post |  #8
This last shows the whole thing in use.
Richard
sarahhj
Joined Sep 2009
Sussex, UK
May 27, 2012 12:46 |  #9
Thank you Richard for the photos.
My tripod has the Q90 system (So the centre column can be placed horizontally)... I'm not sure if/how I can remove this to achieve your set up though. I guess I will have to continue with the short column.
Lowner
Lowner's Avatar
Salisbury, UK.
May 27, 2012 12:54 |  #10
sarahhj wrote in post #14491697 (external link)
No, you will be fine. My 055 used the same system. The assembly comes out as one complete unit but once its out it needs holding together just in case you ever want to replace it and I have used a few elastic bands around the two halves of the assembly. Its a very simple and quick matter to replace it back into the tripod, the only problem I'd have is I would need to transfer my ballhead across.
I've added another shot trying to show how the standard Manfrotto locking method plays right into our hands.
Richard
babel_fish
babel_fish's Avatar
Seattle
May 29, 2012 01:17 |  #11
Thank you everyone for all of your suggestions and ideas. I am looking into Feisol and Benro for new tripods and also I have found a few models of Gitzo that meet my requirements on the used market. Specifically the 1325 and 1548 (there is likely more).
Mike
msowsun
msowsun's Avatar
Oakville Ont. Canada
May 29, 2012 07:52 |  #12
Lowner wrote in post #14491559external link
Saraahhj,
Where did you find the 37mm alloy plug?
Mike Sowsun / S110 / SL1 / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 18-135mm STM / EF-S 55-250mm STM
5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS /
EF 70-200mm 2.8L IS Mk II / EF 1.4x II
Lowner
Lowner's Avatar
Salisbury, UK.
May 29, 2012 08:26 |  #13
msowsun wrote in post #14499550external link
Where did you find the alloy plug?
I experimented with a handmade GRP plug first, then when I was happy with the design a friend made me the alloy version.
In some ways the GRP version is better, for one thing its black, but I originally thought I needed a little platform on the plug. I've since decided that while pretty, it is actually pointlessly complicating the issue and a basic 37mm diameter round "lump" with a hole down the centre for a 3/8" screw is all I need. I've since modified it very slightly by adding a means of attaching a bungee cord so I can place my back pack under the tripod and connect the two.
Richard
msowsun
msowsun's Avatar
May 29, 2012 08:59 |  #14
Thanks, but what is "GRP"?
auto-clicker
May 29, 2012 09:24 as a reply to msowsun's post |  #15
GRP=Glass Reinforced Polymer
13,956 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00098 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is gkefalas
833 guests, 333 members online
