Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Performing Arts Talk
Reply
Thread Tools Display Modes
Old 27th of May 2012 (Sun)   #1
RishabhSood
Default Concert - Autofocus goes Haywire
Hello,
I'm doing music photography from the past 1 year and I'm facing 1 issue constantly almost every day, Whenever I'm behind the artist, The auto-focus goes haywire due to the bright on coming lights, I've tried keeping the focus point on the artist itself but still it doesn't help much. The focus always end up somewhere else.
I use a Canon 60D with Sigma 50 mm 1.4, Tamron 17-55 2.8. Tamron 28-75mm 2.8.
Please help how to keep the focus on the artist, here is on such example:
RishabhSood is offline   Reply With Quote
Old 27th of May 2012 (Sun)   #2
EL_PIC
EL_PIC's Avatar
Default Re: Concert - Autofocus goes Haywire
Auto Focus often fails in extreme bright light and darkness.
This is why the lenes also manual focus.
Nice effect tho ...
EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Canon DSLR - Nikon SLR - Phase One 60MP MFDSLR
http://www.myspace.com/eltexasphotographer Musical Portfolio and History of Photo BLOG
http://www.musecube.com/el_pic/
EL_PIC is offline   Reply With Quote
Old 28th of May 2012 (Mon)   #3
RishabhSood
Nice effect tho ...
The artists move enough to fail the manual focus
Old 28th of May 2012 (Mon)   #4
watt100
Originally Posted by RishabhSood View Post
Hello,
use the focus assist beam from an external flash (but not use the flash)
watt100 is offline   Reply With Quote
Old 28th of May 2012 (Mon)   #5
RichSoansPhotos
RichSoansPhotos's Avatar
+1.
Bodies: Canon 50D, Canon 5DMKII
Lenses: Canon 50mm 1.8, Canon 85mm 1.8 USM,
Canon 16-35mm 2.8L USM II Canon 24-70mm 2.8L USM, Canon 70-200mm 2.8L IS USM II
Compact: Canon G12
RichSoansPhotos is offline   Reply With Quote
Old 29th of May 2012 (Tue)   #6
scumdee
I also find that focusing on a high contrast point like the edge of the t-shirt / neckline really helps too. The AF assist beam will increase AF accuracy too, just remember to set the flash to 'do not fire', you can easily set that on the 60D by going to the 'external flash control' menu.
Flickr | Dundee Band Photographer
scumdee is offline   Reply With Quote
Old 30th of May 2012 (Wed)   #7
René Damkot
Moderator
René Damkot's Avatar
Yeah. AF needs contrast. Always use a hood, think about not using a "protection" filter: All flare lowers contrast.
Although in this case, focusing on the face should not have been a problem IMO.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 30th of May 2012 (Wed)   #8
DennisW1
DennisW1's Avatar
AI-Servo mode. There's usually enough movement from the performers that one-shot mode will fail you.
DennisW1 is offline   Reply With Quote
Old 30th of May 2012 (Wed)   #9
RichSoansPhotos
AI Servo makes it much harder to get a sharp image in a dark performance. So, no I wouldn't use AI Servo
Compact: Canon G12
Old 30th of May 2012 (Wed)   #10
René Damkot
Moderator
Also depends on camera and lens used, and of course how (much) the subject is moving.
On my 1D3, I tend to use mostly AiServo with longer focal lengths (80-200mm and 85/1.8) and mostly One Shot on my 17-35L. I find my Sigma 50mm/1.4 and EF 28/1.8 handle AI Servo quite well on short to medium distances, so with those it depends on circumstances.
Bottom line: Get to know your gear.
MySpace
Get Colormanaged
Twitter
Old 30th of May 2012 (Wed)   #11
RichSoansPhotos
The 1D cameras do have a better focus system than Canon's other range of cameras, this is why they put it in the 7D and 5D3. Yes, good point is to get to know the gear
Compact: Canon G12
Old 14th of September 2012 (Fri)   #12
snyder17315
I'd suggest AI Servo, spot metering, and center focus point. Combine that with a wide aperture, high ISO and fast shutter speed and you're good to go.
My baseline settings before I leave the house to shoot a concert (with the 5D MK II):
1. Manual mode
2. Spot metering
3. AI Servo
4. Continuous Burst
5. ISO 1600
6. Widest lens aperture (usually 2.8 as i'm using the 24-70 and 70-200)
7. Center AF point
8. 1/200 shutter speed
As i'm shooting I'll make adjustments depending on the light, but always with shutter speed as the priority. So maybe the ISO goes to 3200 or even 6400. Sure it gets a little noisy, but noise can be fixed in post and a great, somewhat noisy (but sharp) shot is better than a clean, blurry, not so great shot.
5D MK II
EF 50mm 1.8 | EF 85mm 1.8 | EF 24-70L | EF 70-200L 2.8 IS II
www.jrobertsnyderphotography.com
snyder17315 is offline   Reply With Quote
Old 14th of September 2012 (Fri)   #13
joeblack2022
Just to point out I don't think the focus assist beam will fire in AI-Servo, in case you were planning on this combination.
Joel | Canon 7D | Canon 50D
joeblack2022 is offline   Reply With Quote
Old 5th of October 2012 (Fri)   #14
rejay14
rejay14's Avatar
1. Manual mode
2. Spot metering
3. AI Servo
4. Continuous Burst
5. ISO 1600
7. Center AF point
I concur. Servo in every shot for me. No idea why your colours are so saturated (blue/red)...If noise gets too bad, make it a B&W shot. They are timeless. All shots here on a 5dIII and 7d (17-55, 70-200 2.8 is II, 24-105)
http://photography-on-the.net/forum/....php?t=1233506
5D III, 7D, 40D, 70-200 2.8L IS II ,70-200L F4, 24-105L, 100mm L 2.8 IS, 17-55 2.8, Rebel XT, 50mm 1.4, 17-85, Pixma 9500 II, Pixma 9000 II, Think Tank Airport Accelerator v2.0, 580 EX IIx3, 2x430 EX II, Yongnuo 565, Yongnuo 622C triggers.
rejay14 is offline   Reply With Quote
Old 7th of October 2012 (Sun)   #15
sspellman
sspellman's Avatar
1) Use center point focus only-much more accurate
2) Pick high contrast focus targets such as eyes, or pick a better target in the same focal plane such as the knobs on the DJ mixer
3) Canon lenses generally focus better and faster.
4) Focus manually
ScottSpellmanMedia.com [photography]
sspellman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
HAYWIRE web series shot on a T2i LuFaiNe Digital Video 0 31st of October 2010 (Sun) 00:39
Issue with 40D autofocus with autofocus search turned off mama2girls&boy Canon EOS Digital Cameras 0 20th of May 2010 (Thu) 16:49
tammy autofocus issue at concert pregnantcowlady Performing Arts 6 25th of August 2008 (Mon) 12:21
Center autofocus OR regular autofocus? WildWolf Canon EOS Digital Cameras 15 29th of November 2006 (Wed) 13:39
Diffuse Glow seems to have gone haywire. jimox RAW, Post Processing and Printing 2 10th of September 2006 (Sun) 18:11
