FORUMS Photography Talk by Genre Macro Talk
Thread started 31 May 2012 (Thursday) 21:30
Extension Tubes and Fstop
ottem16
Joined Nov 2011
May 31, 2012 21:30 |  #1
Hello, I just received extension tubes and have been playing with them but I know I have to set the fstop on the lens before adding the tubes but I'm not sure how to do this. I have searched all over and can't find it.
My setup is a Canon T2i with a 50mm 1.8 lens.
Thank you in advance!
Paul ­ Bailey
Joined May 2012
Jun 01, 2012 04:10 |  #2
i also wondered how to do this and as far as i can tell after a little research you start with the camera and lens conencted normally (no Tubes) set the fstop in the camera settings then power off the camera remove the lens still set to whatever fstop you chose and fit the tubes then attach lens as no power reaches the lens so the fstop remains set i will try this method when my camera returns from hospital as its sick at the moment and i fear canon is performing major sergery on it..
Canon EOS 550D 18-55mm isII kit lens
Canon EF 75-300mm 1:4-5:6 III USM
Extention Tubes
+1,+2,+4,+10 Closeup Filters
Prior Planning And Preperation Prevents Poor Performance..:D
IanClark
Joined Apr 2012
Jun 01, 2012 05:21 |  #3
Yup, agree with Paul above. I also believe the trick is to set your Aperture with a regular lens attached to the camera.
Leaving the camera powered ON, disconnect your lens, attach your extension tubes and lens and you should be good.
I don't think there should be an issue with regards to the disconnecting and connecting of lenses with the camera on but I would take the normal precautions. Don't do it in the rain or dusty/windy environments.
Ian Clark
My Gallery on Smugmug (external link)
Kit List
Guari
Joined May 2012
Jun 01, 2012 05:23 |  #4
IanClark wrote in post #14515214 (external link)
Only problem is that disconnecting with the camera off, that means there is static on the surface of the sensor and dust will cling much more easily..
My blog (external link)
My FB page (external link)
LordV
Jun 01, 2012 05:35 |  #5
Just to clarify and assuming you have non communicating extension tubes, you do need the lens directly on the camera- set the aperture you want in say Av mode, press the DOF preview button and remove the lens whilst keeping the button depressed. The lens will keep the set aperture until it is connected normally again.
Brian v.
Macro Hints and tips
IanClark
Joined Apr 2012
Jun 01, 2012 07:18 |  #6
Ahh well spotted Brian. I'd forgotten about the ADEP button.
Ian Clark
Kit List
orionmystery
Jun 01, 2012 08:24 |  #7
I tried this with my Tamron 17-50mm, holding down the DOF preview button and releasing the lens. The aperture blades jammed and I had to send the lens in for repair.
Kurt, 70D, Laowa 15mm, 60mm/270EX & MPE65/MT24EX for full flash (external link), Sigma 150 +1.4x TC for natural light (external link).
Plan a macro/herping trip with us:
Borneo Herp Tour June 201 (external link)
Lester ­ Wareham
Moderator
Gallery: 2274 photos
Jun 01, 2012 11:46 |  #8
I'll move this to talk about.
To be honest I would pay a little more for tubes with electronic connections in.
My Photography Home Page (external link) RSS Feed (external link)
Macrophotography by LordV
1,751 views & 0 likes for this thread
Latest registered member is mashy
747 guests, 403 members online
