Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 2nd of June 2012 (Sat)   #1
Winwin
Default Lighting/flash brackets
I currently have a Bower ring flash. It's great, but problem is while it worked great for the 100L, now that I have a MP-E 65mm and I enjoy using it at 4-5x magnification, I always find that the flash gets in the way or bumps into whatever I'm taking a picture of, when I'm literally an inch away from my subject because of how it's positioned.
So I plan to buy a 580EX. I heard something about using some sort of bracket and transmitter so I can mount it slightly slanted to an angle. This is to direct the flash towards the subject, but still being able to put a somewhat large enough diffuser on it.
Anyone have a list/link(s) to stuff like that?
Win.
Rebel XSI, 100L Macro, MP-E 65mm f/2.8, EF-S 55-250, EF-S 18-55 IS I, 580EXII
Winwin is offline   Reply With Quote
Old 3rd of June 2012 (Sun)   #2
LordV
LordV's Avatar
Default Re: Lighting/flash brackets
Check this thread out for some ideas http://photography-on-the.net/forum/...d.php?t=142566
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is offline   Reply With Quote
Old 3rd of June 2012 (Sun)   #3
racketman
racketman's Avatar
most use an off camera flash cable rather than a transmitter, much cheaper. Obviously if you were going to use 2 flash guns the transmitter would be the answer.
Toby
Flickr collections
Gear
racketman is offline   Reply With Quote
Old 3rd of June 2012 (Sun)   #4
Idlefrog
Idlefrog's Avatar
I was researching the same issue yesterday. I wanted a bracket for my 430EX that enables me to move the flash forward when I used higher magnification and the lens gets longer.
After coming across the thread I have linked below I ordered a Kirk FB-8 flash bracket. I won't get it until Thursday so I can't confirm how well it works but it looks like it will do the job. There are a lot of pictures of it at the bottom of the thread I have linked.
Here is the link: CLICK ME
Andrew Reynolds
My Photos
Canon 60D, EF 100mm F2.8 IS L Macro, MP-E 65, EF-S 15-85mm, Tamron SP 70-300mm f/4-5.6 Di VC USD
Idlefrog is offline   Reply With Quote
Old 3rd of June 2012 (Sun)   #5
Idlefrog
Idlefrog's Avatar
Ironically with a cheaper camera like the 600D, 60D or 7D the camera could remotely fire that flash without the need of a separate remote system or a cable.
Andrew Reynolds
My Photos
Old 3rd of June 2012 (Sun)   #6
Madweasel
Madweasel's Avatar
Ha ha, I was going to say I've got the Kirk bracket, when I saw the link is to my own pics of it!
If you've got the funds, the MT-24EX is hard to beat when you get in really close.
Mark.
Madweasel is offline   Reply With Quote
Old 3rd of June 2012 (Sun)   #7
Lester Wareham
Moderator
Lester Wareham's Avatar
I have moved you to talk about macro.
Yes this is an issue sometimes with the twin flash around 4X and 5X.
On the other hand a large flash on a bracket gets in the way of bushes etc and I really miss the focus assist light feature of the twin flash.
Another alternative is the ring flash I guess as that is completely flat, but so can the lighting be plus those ring shaped highlights.
Like camera bags there is nothing that is perfect.
My Photography Home Page RSS Feed
MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair!
Macrophotography by LordV
Lester Wareham is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flash Brackets..Flash or Camera Rotator? 4mr4do4sho Small Flash and Studio Lighting 20 11th of February 2009 (Wed) 13:38
