FORUMS Photography Talk by Genre Weddings & Other Family Events Talk
Thread started 05 Jun 2012 (Tuesday) 11:28
Prev/next
Lighting for a Prom on a budget
Arte ­ Automobilistica
Devon UK
Jun 05, 2012 11:28 |  #1
Hi
I have been commissioned to shoot a prom and need to buy lights. Cash is extremely tight and I would like advice on the cheapest setup I can get away with.
NelPhotos.co.uk (external link)
Work: 7D + Sigma 100-300 4
Play: Kiss X4 + 15-85 IS + 10-22 + 50 1.8 II + Vivitar 1 70-210 3.5
EOS-M + 18-55 + FD 50 1.4 + FD 135 2.8 + Tamron 35-80 1A
G9, SX280 HS + CHDK, Casio EX-FH 100, Toshiba L505-144 & iPad 2
gonzogolf
dumb remark memorialized
Jun 05, 2012 11:32 |  #2
Give us a realistic target budget. We can suggest methods, some more likely to be successful than others but if you can say how much you are willing to spend we can get you the best gear for the money.
JohnThomas
JohnThomas's Avatar
Joined May 2012
Long Island, New York
Jun 05, 2012 11:37 |  #3
I'm assuming you're trying to get setup to do portraits with a backdrop off in a corner of the gymnasium, or out in the hallway..
Are you familiar with off-camera flash? if not, this is a bad time to learn.
I got into portraits with the following kit, and it worked respectably:
http://www.bhphotovide​o.com ..._Studio_Lighting_Ki​t.htmlexternal link
and this backdrop:
http://www.bhphotovide​o.com ...tand_with_Reversibl​e.htmlexternal link
After this kit, I stepped up to off-camera flash with (3) 580EX II
You can call me JT
jsantiniphotography.co​m
gonzogolf
Jun 05, 2012 11:39 |  #4
Keep in mind the OP is in the UK
frugivore
Toronto, Canada
Jun 05, 2012 11:42 |  #5
I think the cheapest light for lumens/dollar in a speedlight would be the YongNuo 560 at about $70. For a monolight, I'm guessing an Alien Bees B800 or B1600. You would want a stand and some radio triggers for those.
JohnThomas
JohnThomas's Avatar
Joined May 2012
Jun 05, 2012 11:59 |  #6
gonzogolf wrote in post #14534565external link
Ahh... I need to keep an on that. B&H might be a little impractical :)
You can call me JT
Devon UK
Jun 05, 2012 12:53 as a reply to JohnThomas's post |  #7
Hi
I was hoping to spend around £100. I was looking at this
http://www.ebay.co.uk ..._trksid=p3984.m1423​.l2649external link
but am open to use speedlights as I already have one with softbox. I am happy to buy secondhand.
I'll be shooting in a setaside area.
PS I've added UK to my profile :)
JohnThomas
JohnThomas's Avatar
Joined May 2012
Jun 05, 2012 13:16 |  #8
That's similar to what I started with. Definitely not the best solution, but may get you through the night. I'm not sure what your clients are hoping for.
It's also important to understand what level of light you'll be shooting under. If its decent, that kit may not be enough contrast. The kit I started with was used in a dark room and had 85w bulbs (vs. your 105w), which resulted in camera settings of f/4 @ 1/200 with ISO 1600.
You can call me JT
gonzogolf
Jun 05, 2012 13:33 |  #9
Arte Automobilistica wrote in post #14534884external link
Hi
Those continuous light kits are pretty terrible. Not enough power to get your shutter speed and DOF up enough to do a decent job. Spring for a second speedlite and a shoot through umbrella.
davisphotos
Portsmouth, NH
Jun 05, 2012 15:31 |  #10
Keep it simple, one light either in an umbrella or softbox, find a blank wall to use as a background. You won't get anything too great for £100, but I would definitely avoid the continuous light kits. A couple cheapo flash kits that might not suck too much:
http://www.amazon.co.u​k ...8&qid=1338928064&sr​=1-365external link
http://www.amazon.co.u​k ...8&qid=1338928219&sr​=1-478external link
http://www.amazon.co.u​k ...DRB7E/ref=pd_sim_sb​s_ce_2external link
Maine Wedding Photographer Andrew Davisexternal link
New England Commercial Photographyexternal link
Andrew Davis Photography Blogexternal link
Devon UK
Jun 05, 2012 15:51 as a reply to davisphotos's post |  #11
JohnThomas wrote in post #14535009external link
OOOOh not good. Lights are rejected!
gonzogolf wrote in post #14535102external link
I agree and it is very portable which I like.
What about a backdrop?
gonzogolf
Jun 05, 2012 15:53 |  #12
Arte Automobilistica wrote in post #14535693external link
Here in the states the backgrounds for proms are often a "set piece" something designed to fit the theme of the prom. I would start with a paper background if I had an option, then add some decorative bits if I wanted/needed to.
cpam.pix
Joined Apr 2011
Jun 05, 2012 17:08 |  #13
Do you have craigslist in the UK?
There are usually $200 strobe kits available used in my area. I've bought two sets that way (one was only $40). I now have a 4-5 light set with all the stands I need.
Maybe a king size flat sheet would work for a backdrop. Find a pattern that would be close to a theme. Clip it up or pick up a cheap background stand to look more professional.
1D-III with stuff to stick on it:
70-200L, 28-70L, 24-105L, 300L, 50, 10-17 fish, 2.0x TC
Image editing OK, encouraged, and expected. Thank you for helping me learn!
tim
Light Bringer
tim's Avatar
Wellington, New Zealand
Jun 05, 2012 18:52 |  #14
You need to tell us what you're trying to achieve before you can get any useful advice.
Also, it's a bit irresponsible taking a job to capture an important event when you don't have the gear and probably don't have the knowledge or experience to do it well. The only time that kind of behaviour is justified is if it's you or no-one else. How'd you get the gig?
1,418 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00171 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is krzych.g
940 guests, 512 members online
